[PATCH v2 06/13] score: Add CPU_THREAD_LOCAL_STORAGE_VARIANT
Sebastian Huber
Fri Oct 7 04:23:50 UTC 2022
On 07.10.22 05:44, Chris Johns wrote:
> On 6/10/2022 7:23 pm, Sebastian Huber wrote:
>> +#if CPU_THREAD_LOCAL_STORAGE_VARIANT == 10
>> + tls_data = (void *)
>> + RTEMS_ALIGN_UP( (uintptr_t) tls_area + sizeof( *tcb ), alignment );
>> + tcb = (TLS_Thread_control_block *) ((char *) tls_data - sizeof( *tcb ));
>> + return_value = tls_data;
>> +#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 11
>> + tcb_size = RTEMS_ALIGN_UP( sizeof( *tcb ), alignment );
>> + RTEMS_ALIGN_UP( (uintptr_t) tls_area + tcb_size, alignment );
>> + tcb = (TLS_Thread_control_block *) ((char *) tls_data - tcb_size);
>> + return_value = tcb;
>> +#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 20
>> + alignment_2 = RTEMS_ALIGN_UP( alignment, CPU_SIZEOF_POINTER );
>> + tls_area = (void *) RTEMS_ALIGN_UP( (uintptr_t) tls_area, alignment_2 );
>> + size = _TLS_Get_size();
>> + ((char *) tls_area + RTEMS_ALIGN_UP( size, alignment_2 ));
>> + tls_data = (char *) tcb - RTEMS_ALIGN_UP( size, alignment );
>> +#else
>> +#error "unexpected CPU_THREAD_LOCAL_STORAGE_VARIANT value"
> What are the expected values? I can see 10, 11, 20.
> Can this please be changed to something readable? For example:
> #if CPU_THREAD_LOCAL_STORAGE_VARIANT == CPU_THREAD_LOCAL_STORAGE_BLAH
> #elif CPU_THREAD_LOCAL_STORAGE_VARIANT == CPU_THREAD_LOCAL_STORAGE_BLAH_BLAH
This is documented in the no_cpu/cpuimpl.h. I think the numbers are all
right if you know the TLS variants. Otherwise we would have to add an
extra header file just for the CPU_THREAD_LOCAL_STORAGE_* defines.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
