[PATCH v2 06/13] score: Add CPU_THREAD_LOCAL_STORAGE_VARIANT
Fri Oct 7 04:31:46 UTC 2022
On 7/10/2022 3:23 pm, Sebastian Huber wrote:
> On 07.10.22 05:44, Chris Johns wrote:
>> On 6/10/2022 7:23 pm, Sebastian Huber wrote:
>>> +#if CPU_THREAD_LOCAL_STORAGE_VARIANT == 10
>>> +  tls_data = (void *)
>>> +    RTEMS_ALIGN_UP( (uintptr_t) tls_area + sizeof( *tcb ), alignment );
>>> +  tcb = (TLS_Thread_control_block *) ((char *) tls_data - sizeof( *tcb ));
>>> +  return_value = tls_data;
>>> +#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 11
>>> +  tcb_size = RTEMS_ALIGN_UP( sizeof( *tcb ), alignment );
>>> +    RTEMS_ALIGN_UP( (uintptr_t) tls_area + tcb_size, alignment );
>>> +  tcb = (TLS_Thread_control_block *) ((char *) tls_data - tcb_size);
>>> +  return_value = tcb;
>>> +#elif CPU_THREAD_LOCAL_STORAGE_VARIANT == 20
>>> +  alignment_2 = RTEMS_ALIGN_UP( alignment, CPU_SIZEOF_POINTER );
>>> +  tls_area = (void *) RTEMS_ALIGN_UP( (uintptr_t) tls_area, alignment_2 );
>>> +  size = _TLS_Get_size();
>>> +    ((char *) tls_area + RTEMS_ALIGN_UP( size, alignment_2 ));
>>> +  tls_data = (char *) tcb - RTEMS_ALIGN_UP( size, alignment );
>>> +#else
>>> +#error "unexpected CPU_THREAD_LOCAL_STORAGE_VARIANT value"
>> What are the expected values? I can see 10, 11, 20.
>> Can this please be changed to something readable? For example:
>> #if CPU_THREAD_LOCAL_STORAGE_VARIANT == CPU_THREAD_LOCAL_STORAGE_BLAH
>> #elif CPU_THREAD_LOCAL_STORAGE_VARIANT == CPU_THREAD_LOCAL_STORAGE_BLAH_BLAH
> This is documented in the no_cpu/cpuimpl.h. I think the numbers are all right if
> you know the TLS variants. Otherwise we would have to add an extra header file
> just for the CPU_THREAD_LOCAL_STORAGE_* defines.
Is the doco in this patch? I could not find it.
