[PATCH rtems-docs v4] raspberrypi4.rst: Documentation for the new AArch64 Raspberry pi 4B BSP
Noor Aman
nooraman5718 at gmail.com
Fri Oct 7 05:16:27 UTC 2022
New patch sent with new changes.
On Fri, 7 Oct 2022 at 10:30, Mohd Noor Aman <nooraman5718 at gmail.com> wrote:
> This patch adds the relevant documentations required for booting the new
> BSP.
> JTAG support is added for debugging. I have built the HTML docs and
> verified
> them.
> user/bsps/aarch64/raspberrypi4.rst | 111 +++++++++++++++++++++++++++++
> user/bsps/bsps-aarch64.rst | 1 +
> 2 files changed, 112 insertions(+)
> create mode 100644 user/bsps/aarch64/raspberrypi4.rst
> diff --git a/user/bsps/aarch64/raspberrypi4.rst
> b/user/bsps/aarch64/raspberrypi4.rst
> new file mode 100644
> index 0000000..b36d47b
> --- /dev/null
> +++ b/user/bsps/aarch64/raspberrypi4.rst
> @@ -0,0 +1,111 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2022 Mohd Noor Aman
> +.. _BSP_aarch64_Raspberrypi_4:
> +Raspberry Pi 4B
> +The 'raspberrypi4b' BSP currently supports only the LP64 ABI. ILP32 is not
> +supported. Raspberry pi 4B all variants and Raspberry Pi 400 are
> supported. The
> +default bootloader which is used by the Raspbian OS or other OS can be
> used to
> +boot RTEMS. SMP is currently not supported.
> +Raspberry Pi 4B has 2 types of interrupt controller, GIC-400 (GICv2) and
> ARM
> +legacy generic controller. Both are supported. By default, raspberrypi 4B
> uses
> +ARM legacy generic controller. Set ``enable_gic=1`` in the ``config.txt``
> file
> +to enable GIC.
> +Clock Driver
> +The clock driver uses the `ARM Generic Timer`.
> +Console Driver
> +Raspberry pi 4B has 2 types of UARTs, ARM PL011 and Mini-uart. The PL011
> is a
> +capable, broadly 16550-compatible UART, while the mini UART has a reduced
> +feature set. The console driver supports the default Qemu emulated ARM
> PL011
> +PrimeCell UART as well as the physical ARM PL011 PrimeCell UART in the
> +raspberrypi hardware. Mini-uart is not supported.
> +Preparing to boot
> +Raspberry Pi uses a different mechanism to boot when compared with any
> ARM SoC.
> +First the GPU initializes, loads the bootloader (Raspberry pi firmware)
> and then
> +looks for the kernel img. This whole process is done by the GPU
> (VideoCore IV)
> +till the kernel is loaded. More information can be found on the
> `Raspberry pi
> +documentation page
> https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#boot-sequence
> >`_.
> +By default the arm64 mode looks for the ``kernel8.img``. Any other kernel
> can be
> +loaded by adding ``kernel=<img_name>`` to the ``config.txt`` file.
> +The Firmware files are required in order to boot RTEMS. The latest
> firmware can
> +be downloaded from the `Raspberry Pi Firmware Repository
> +<https://github.com/raspberrypi/firmware/>`_. USB boot is supported. All
> the
> +files (Firmwares and kernel) must be place in the FAT32 partition only.
> Add
> +``arm_64bit=1`` in the ``config.txt`` file in order to boot the BSP in
> 64bit
> +kernel mode.
> +UART Setup
> +Connect your serial device to the GPIO15 and GPIO14. Add the following to
> the
> +``config.txt`` file in order to use the PL011 UART0 and thus disabling the
> +default Mini-uart.
> +.. code-block:: none
> + # if user wants to enable GIC, uncomment the next line
> + # enable_gic=1
> + arm_64bit=1
> + dtoverlay = disable-bt
> + enable_uart=1
> +.. note::
> + The Raspberry Pi 4B and 400 have an additional four PL011 UARTs. They
> are not
> + supported.
> +Generating kernel image
> +The following steps show how to run ``hello.exe`` on the BSP. Other
> executables
> +can be processed in a similar way.
> +To create the kernel image:
> +.. code-block:: shell
> + $ aarch64-rtems at rtems-ver-major@-objcopy -Obinary hello.exe kernel8.img
> +Copy the kernel image to the SD card.
> +JTAG Setup
> +The Raspberry Pi 4 doesn't have dedicated JTAG pins. Instead, you must
> configure
> +the GPIO pins (GPIO22-GPIO27) to activate the JTAG functionality. The RPi
> 4
> +documentation refers to this as Alt4 functions of those pins. Alt5 does
> exist
> +too, which goes from GPIO4, 5, 6, 12 and 13. you can check this out from
> +`pinout.xyz <https://pinout.xyz/pinout/jtag#>`_ or `eLinux
> +<https://elinux.org/RPi_BCM2835_GPIOs>`_
> +One more thing to note on JTAG with Raspberry pi 4B is that, by default,
> All the
> +GPIO pins are pulled down, according to the `BCM2711 documentation
> +<https://datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf>`_.
> This
> +wasn't the case in the earlier models. So in order to let the data flow
> freely,
> +we will have to disable them.
> + # Disable pull downs
> + gpio=22-27=np
> + # Enable jtag pins (i.e. GPIO22-GPIO27)
> + enable_jtag_gpio=1
> diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
> index 933370f..f3aa15c 100644
> --- a/user/bsps/bsps-aarch64.rst
> +++ b/user/bsps/bsps-aarch64.rst
> @@ -9,3 +9,4 @@ aarch64 (AArch64)
> .. include:: aarch64/a72.rst
> .. include:: aarch64/xilinx-versal.rst
> .. include:: aarch64/xilinx-zynqmp.rst
> +.. include:: aarch64/raspberrypi4.rst
> \ No newline at end of file
> 2.38.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221007/d7e5c93b/attachment.htm>
