[PATCH rtems-docs v4] raspberrypi4.rst: Documentation for the new AArch64 Raspberry pi 4B BSP
Fri Oct 7 06:26:41 UTC 2022
Looks good. Thank you for your patience in getting the changes made.
On 7/10/2022 4:16 pm, Noor Aman wrote:
> New patch sent with new changes.
> On Fri, 7 Oct 2022 at 10:30, Mohd Noor Aman <nooraman5718 at gmail.com
> <mailto:nooraman5718 at gmail.com>> wrote:
>     This patch adds the relevant documentations required for booting the new BSP.
>     JTAG support is added for debugging. I have built the HTML docs and verified
>     them.
>      user/bsps/aarch64/raspberrypi4.rst | 111 +++++++++++++++++++++++++++++
>      user/bsps/bsps-aarch64.rst         |   1 +
>      2 files changed, 112 insertions(+)
>      create mode 100644 user/bsps/aarch64/raspberrypi4.rst
>     diff --git a/user/bsps/aarch64/raspberrypi4.rst
>     b/user/bsps/aarch64/raspberrypi4.rst
>     new file mode 100644
>     index 0000000..b36d47b
>     --- /dev/null
>     +++ b/user/bsps/aarch64/raspberrypi4.rst
>     @@ -0,0 +1,111 @@
>     +.. SPDX-License-Identifier: CC-BY-SA-4.0
>     +.. Copyright (C) 2022 Mohd Noor Aman
>     +.. _BSP_aarch64_Raspberrypi_4:
>     +Raspberry Pi 4B
>     +The 'raspberrypi4b' BSP currently supports only the LP64 ABI. ILP32 is not
>     +supported. Raspberry pi 4B all variants and Raspberry Pi 400  are
>     supported. The
>     +default bootloader which is used by the Raspbian OS or other OS can be used to
>     +boot RTEMS. SMP is currently not supported.
>     +Raspberry Pi 4B has 2 types of interrupt controller, GIC-400 (GICv2) and ARM
>     +legacy generic controller. Both are supported. By default, raspberrypi 4B uses
>     +ARM legacy generic controller. Set ``enable_gic=1`` in the ``config.txt`` file
>     +to enable GIC.
>     +Clock Driver
>     +The clock driver uses the `ARM Generic Timer`.
>     +Console Driver
>     +Raspberry pi 4B has 2 types of UARTs, ARM PL011 and Mini-uart. The PL011 is a
>     +capable, broadly 16550-compatible UART, while the mini UART has a reduced
>     +feature set. The console driver supports the default Qemu emulated ARM PL011
>     +PrimeCell UART as well as the physical ARM PL011 PrimeCell UART in the
>     +raspberrypi hardware. Mini-uart is not supported.
>     +Preparing to boot
>     +Raspberry Pi uses a different mechanism to boot when compared with any ARM SoC.
>     +First the GPU initializes, loads the bootloader (Raspberry pi firmware) and
>     then
>     +looks for the kernel img. This whole process is done by the GPU (VideoCore IV)
>     +till the kernel is loaded. More information can be found on the `Raspberry pi
>     +documentation page
>     +<https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#boot-sequence <https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#boot-sequence>>`_.
>     +By default the arm64 mode looks for the ``kernel8.img``. Any other kernel
>     can be
>     +loaded by adding ``kernel=<img_name>`` to the ``config.txt`` file.
>     +The Firmware files are required in order to boot RTEMS. The latest firmware can
>     +be downloaded from the `Raspberry Pi Firmware Repository
>     +<https://github.com/raspberrypi/firmware/
>     <https://github.com/raspberrypi/firmware/>>`_. USB boot is supported. All the
>     +files (Firmwares and kernel) must be place in the FAT32 partition only. Add
>     +``arm_64bit=1`` in the ``config.txt`` file in order to boot the BSP in 64bit
>     +kernel mode.
>     +UART Setup
>     +Connect your serial device to the GPIO15 and GPIO14. Add the following to the
>     +``config.txt`` file in order to use the PL011 UART0 and thus disabling the
>     +default Mini-uart.
>     +.. code-block:: none
>     +  # if user wants to enable GIC, uncomment the next line
>     +  # enable_gic=1
>     +  arm_64bit=1
>     +  dtoverlay = disable-bt
>     +  enable_uart=1
>     +.. note::
>     +  The Raspberry Pi 4B and 400 have an additional four PL011 UARTs. They are
>     not
>     +  supported.
>     +Generating kernel image
>     +The following steps show how to run ``hello.exe`` on the BSP. Other executables
>     +can be processed in a similar way.
>     +To create the kernel image:
>     +.. code-block:: shell
>     +  $ aarch64-rtems at rtems-ver-major@-objcopy -Obinary hello.exe kernel8.img
>     +Copy the kernel image to the SD card.
>     +JTAG Setup
>     +The Raspberry Pi 4 doesn't have dedicated JTAG pins. Instead, you must
>     configure
>     +the GPIO pins (GPIO22-GPIO27) to activate the JTAG functionality. The RPi 4
>     +documentation refers to this as Alt4 functions of those pins. Alt5 does exist
>     +too, which goes from GPIO4, 5, 6, 12 and 13. you can check this out from
>     +`pinout.xyz <http://pinout.xyz> <https://pinout.xyz/pinout/jtag#
>     <https://pinout.xyz/pinout/jtag#>>`_ or `eLinux
>     +<https://elinux.org/RPi_BCM2835_GPIOs <https://elinux.org/RPi_BCM2835_GPIOs>>`_
>     +One more thing to note on JTAG with Raspberry pi 4B is that, by default,
>     All the
>     +GPIO pins are pulled down, according to the `BCM2711 documentation
>     +<https://datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf
>     <https://datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf>>`_. This
>     +wasn't the case in the earlier models. So in order to let the data flow freely,
>     +we will have to disable them.
>     +  # Disable pull downs
>     +  gpio=22-27=np
>     +  # Enable jtag pins (i.e. GPIO22-GPIO27)
>     +  enable_jtag_gpio=1
>     diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
>     index 933370f..f3aa15c 100644
>     --- a/user/bsps/bsps-aarch64.rst
>     +++ b/user/bsps/bsps-aarch64.rst
>     @@ -9,3 +9,4 @@ aarch64 (AArch64)
>      .. include:: aarch64/a72.rst
>      .. include:: aarch64/xilinx-versal.rst
>      .. include:: aarch64/xilinx-zynqmp.rst
>     +.. include:: aarch64/raspberrypi4.rst
>     \ No newline at end of file
>     2.38.0
> devel mailing list
> devel at rtems.org
