[rtems commit] psxrwlock01: Use an initilized lock for tests
Joel Sherrill
joel.sherrill at gmail.com
Fri Oct 7 13:36:31 UTC 2022
I think the ticket was targeting 5 as the milestone. You should push this
to 5 also if it applies.
On Fri, Oct 7, 2022, 12:15 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: 46f08961a22ff7ffc6196971c0ff04006689ded1
> Changeset:
> http://git.rtems.org/rtems/commit/?id=46f08961a22ff7ffc6196971c0ff04006689ded1
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Fri Oct 7 07:14:02 2022 +0200
> Close #4738.
> testsuites/psxtests/psxrwlock01/test.c | 28 ++++++++++++++++++++--------
> 1 file changed, 20 insertions(+), 8 deletions(-)
> diff --git a/testsuites/psxtests/psxrwlock01/test.c
> b/testsuites/psxtests/psxrwlock01/test.c
> index 5767aa7c07..f6954007c0 100644
> --- a/testsuites/psxtests/psxrwlock01/test.c
> +++ b/testsuites/psxtests/psxrwlock01/test.c
> @@ -454,10 +454,6 @@ int main(
> status = pthread_rwlock_timedrdlock( NULL, &abstime);
> rtems_test_assert( status == EINVAL );
> - puts( "pthread_rwlock_timedrdlock( &rwlock, NULL) -- EINVAL" );
> - status = pthread_rwlock_timedrdlock( &rwlock, NULL);
> - rtems_test_assert( status == EINVAL );
> puts( "pthread_rwlock_tryrdlock(NULL) -- EINVAL" );
> status = pthread_rwlock_tryrdlock(NULL);
> @@ -470,10 +466,6 @@ int main(
> status = pthread_rwlock_timedwrlock( NULL, &abstime );
> - puts( "pthread_rwlock_timedwrlock( &rwlock, NULL) -- EINVAL" );
> - status = pthread_rwlock_timedwrlock( &rwlock, NULL);
> puts( "pthread_rwlock_trywrlock(NULL) -- EINVAL" );
> status = pthread_rwlock_trywrlock(NULL);
> @@ -482,6 +474,26 @@ int main(
> status = pthread_rwlock_unlock(NULL);
> + status = pthread_rwlock_init( &rwlock, NULL );
> + rtems_test_assert( status == 0 );
> + status = pthread_rwlock_wrlock( &rwlock );
> + puts( "pthread_rwlock_timedrdlock( &rwlock, NULL) -- EINVAL" );
> + status = pthread_rwlock_timedrdlock( &rwlock, NULL);
> + rtems_test_assert( status == EINVAL );
> + puts( "pthread_rwlock_timedwrlock( &rwlock, NULL) -- EINVAL" );
> + status = pthread_rwlock_timedwrlock( &rwlock, NULL);
> + status = pthread_rwlock_unlock( &rwlock );
> + status = pthread_rwlock_destroy( &rwlock );
> /*************** BAD ID CHECK *****************/
> /* make a valid abstime */
> puts( "clock_gettime(CLOCK_REALTIME, &abstime) -- OK" );
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221007/b7f261fe/attachment.htm>
