docs not building to PDF
Fri Oct 7 17:19:44 UTC 2022
Hi
I have been building the docs fairly regularly as part of pushing
patches but it is not building PDF on the master for me.
[62/62] Compiling build/filesystem/latex/filesystem.tex
first pass on pdflatex
11:48:31 runner ['/usr/local/texlive/2019/bin/x86_64-linux/pdflatex',
'-shell-escape', '-interaction=batchmode',
'/home/joel/rtems-work/rtems-docs/build/filesystem/latex/filesystem.tex']
This is pdfTeX, Version 3.14159265-2.6-1.40.20 (TeX Live 2019) (preloaded
format=pdflatex)
 \write18 enabled.
entering extended mode
Waf: Leaving directory `/home/joel/rtems-work/rtems-docs/build'
Build failed
Traceback (most recent call last):
  File
"/home/joel/rtems-work/rtems-docs/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py",
line 180, in process
    ret=self.run()
  File
"/home/joel/rtems-work/rtems-docs/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Tools/tex.py",
line 204, in run
    self.call_latex()
  File
line 234, in call_latex
    self.check_status('error when calling latex',self.texfun())
  File
line 119, in check_status
    raise Errors.WafError('%r command exit status %r'%(msg,retcode))
waflib.Errors.WafError: 'error when calling latex' command exit status 1
Any suggestions? Does this happen to anyone else?
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221007/82954bb2/attachment-0001.htm>
