docs not building to PDF
Noor Aman nooraman5718 at gmail.com
Fri Oct 7 23:12:13 UTC 2022
I can confirm that the same is happening on my PC too.
$ uname -a
Linux lynx 5.15.72-1-lts #1 SMP Wed, 05 Oct 2022 12:15:15 +0000 x86_64
GNU/Linux
$ pip list
Package                       Version
absl-py                       1.2.0
alabaster                     0.7.12
appdirs                       1.4.4
astunparse                    1.6.3
autocommand                   2.2.1
Babel                         2.10.3
btrfsutil                     5.19.1
build                         0.8.0
cachetools                    5.2.0
chardet                       5.0.0
Cython                        0.29.32
distro                        1.7.0
docutils                      0.19
esbonio                       0.14.1
flatbuffers                   1.12
gast                          0.4.0
google-auth                   2.11.0
google-auth-oauthlib          0.4.6
google-pasta                  0.2.0
h5py                          3.7.0
idna                          3.4
imagesize                     1.4.1
importlib-metadata            4.9.0
inflect                       6.0.0
jaraco.context                4.1.2
jaraco.functools              3.5.2
jaraco.text                   3.9.1
Jinja2                        3.1.2
keras                         2.9.0
Keras-Preprocessing           1.1.2
latexcodec                    2.0.1
libclang                      14.0.6
libfdt                        1.6.1
Mako                          1.2.3
Markdown                      3.4.1
MarkupSafe                    2.1.1
more-itertools                8.13.0
numpy                         1.23.2
opt-einsum                    3.3.0
ordered-set                   4.1.0
packaging                     21.3
pep517                        0.13.0
pip                           22.2.2
pip-autoremove                0.10.0
py-cpuinfo                    8.0.0
pyasn1                        0.4.8
pyasn1-modules                0.2.8
pybtex                        0.24.0
pybtex-docutils               1.0.2
pycairo                       1.21.0
pydantic                      1.9.2
pygls                         0.12.1
Pygments                      2.13.0
PyGObject                     3.42.2
pyinotify                     0.9.6
pyparsing                     3.0.9
PyQt5                         5.15.7
PyQt5-sip                     12.11.0
PyQtWebEngine                 5.15.6
pyspellchecker                0.7.0
python-xlib                   0.31
pytz                          2022.1
PyYAML                        6.0
requests                      2.28.1
requests-oauthlib             1.3.1
rsa                           4.9
ruamel.yaml                   0.17.21
ruamel.yaml.clib              0.2.6
setuptools                    63.1.0
six                           1.16.0
smbus                         1.1
snowballstemmer               2.2.0
Sphinx                        5.2.3
sphinxcontrib-applehelp       1.0.2
sphinxcontrib-bibtex          2.5.0
sphinxcontrib-devhelp         1.0.2
sphinxcontrib-htmlhelp        2.0.0
sphinxcontrib-jsmath          1.0.1
sphinxcontrib-qthelp          1.0.3
sphinxcontrib-serializinghtml 1.1.5
system-monitoring-center      1.27.0
team                          1.0
tensorboard                   2.9.1
tensorboard-data-server       0.6.1
tensorboard-plugin-wit        1.8.1
tensorflow-io-gcs-filesystem  0.26.0
termcolor                     1.1.0
tomli                         2.0.1
trove-classifiers             2022.9.26
typeguard                     2.13.3
typing_extensions             4.3.0
urllib3                       1.26.12
On Fri, 7 Oct 2022 at 22:50, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I have been building the docs fairly regularly as part of pushing
> patches but it is not building PDF on the master for me.
> [62/62] Compiling build/filesystem/latex/filesystem.tex
> first pass on pdflatex
> 11:48:31 runner ['/usr/local/texlive/2019/bin/x86_64-linux/pdflatex',
> '-shell-escape', '-interaction=batchmode',
> '/home/joel/rtems-work/rtems-docs/build/filesystem/latex/filesystem.tex']
> This is pdfTeX, Version 3.14159265-2.6-1.40.20 (TeX Live 2019) (preloaded
> format=pdflatex)
>  \write18 enabled.
> entering extended mode
> Waf: Leaving directory `/home/joel/rtems-work/rtems-docs/build'
> Build failed
> Traceback (most recent call last):
>   File
> "/home/joel/rtems-work/rtems-docs/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py",
> line 180, in process
>     ret=self.run()
>   File
> "/home/joel/rtems-work/rtems-docs/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Tools/tex.py",
> line 204, in run
>     self.call_latex()
>   File
> line 234, in call_latex
>     self.check_status('error when calling latex',self.texfun())
>   File
> line 119, in check_status
>     raise Errors.WafError('%r command exit status %r'%(msg,retcode))
> waflib.Errors.WafError: 'error when calling latex' command exit status 1
> Any suggestions? Does this happen to anyone else?
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221008/8845c0c7/attachment.htm>
