docs not building to PDF
Noor Aman nooraman5718 at gmail.com
Sat Oct 8 17:53:42 UTC 2022
Hey Frank,
I was able to find the issue which was causing the pdf to be not built
properly.
diff --git a/filesystem/trivial_ftp.rst b/filesystem/trivial_ftp.rst
index 3ef8bba..eccd035 100644
--- a/filesystem/trivial_ftp.rst
+++ b/filesystem/trivial_ftp.rst
@@ -280,10 +280,7 @@ application.  The mount point can be any directory.
The name ``/tftp``
 used in the figure serves only as an example.  The final unmounting and
 remove directory steps are optional.
-.. figure:: ../images/filesystem/tftpfs_usage.png
-  :width: 90%
-  :align: center
-  :alt: TFTP Usage Diagram
This png is causing issues. Removing these lines removed the error and the
pdf was generated successfully. I hope this is helpful.
Thanks,
Noor
On Sat, 8 Oct 2022 at 05:35, Chris Johns <chrisj at rtems.org> wrote:
> On 8/10/2022 9:47 am, Chris Johns wrote:
> > On 8/10/2022 10:12 am, Noor Aman wrote:
> >> I can confirm that the same is happening on my PC too.
> > Could you please bisect the repo to find the patch that broke things?
> A simpler way to find the commit is to see the last build on
> docs.rtems.org
> which is 6.278550b and the next commit after 278550b is:
> commit 23fc93bf648507ac417237c20069c4ab7c793251
> Author: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> Date:   Thu Jun 9 15:21:05 2022 +0200
>     TFTPFS: New documentation
> Frank ?
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221008/1a96d71b/attachment.htm>
