docs not building to PDF
Sat Oct 8 14:30:26 UTC 2022
On Sat, Oct 8, 2022 at 7:24 AM Noor Aman <nooraman5718 at gmail.com> wrote:
> Hey Frank,
> I was able to find the issue which was causing the pdf to be not built
> properly.
> diff --git a/filesystem/trivial_ftp.rst b/filesystem/trivial_ftp.rst
> index 3ef8bba..eccd035 100644
> --- a/filesystem/trivial_ftp.rst
> +++ b/filesystem/trivial_ftp.rst
> @@ -280,10 +280,7 @@ application.  The mount point can be any directory.
> The name ``/tftp``
>  used in the figure serves only as an example.  The final unmounting and
>  remove directory steps are optional.
> -.. figure:: ../images/filesystem/tftpfs_usage.png
> -  :width: 90%
> -  :align: center
> -  :alt: TFTP Usage Diagram
> This png is causing issues. Removing these lines removed the error and the
> pdf was generated successfully. I hope this is helpful.
Thanks. I saw this email right as I was setting up to do a git bisect with
my
morning tea.
Two issues with this figure situation.
(1) We probably should not have png/jpg files without the corresponding
source.
(2) I have no idea how to fix this other than to remove the figure. It
looks like Frank's
text is referencing the figure so simply removing it isn't the best answer.
--joel
> Thanks,
> Noor
> On Sat, 8 Oct 2022 at 05:35, Chris Johns <chrisj at rtems.org> wrote:
>> On 8/10/2022 9:47 am, Chris Johns wrote:
>> > On 8/10/2022 10:12 am, Noor Aman wrote:
>> >> I can confirm that the same is happening on my PC too.
>> > Could you please bisect the repo to find the patch that broke things?
>> A simpler way to find the commit is to see the last build on
>> docs.rtems.org
>> which is 6.278550b and the next commit after 278550b is:
>> commit 23fc93bf648507ac417237c20069c4ab7c793251
>> Author: Frank Kühndel <frank.kuehndel at embedded-brains.de>
>> Date:   Thu Jun 9 15:21:05 2022 +0200
>>     TFTPFS: New documentation
>> Frank ?
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221008/32d03045/attachment.htm>
