docs not building to PDF
Frank Kühndel frank.kuehndel at embedded-brains.de
Tue Oct 11 08:12:58 UTC 2022
Hello Chris,
On 10/11/22 03:09, Chris Johns wrote:
> On 10/10/2022 9:22 pm, Frank Kühndel wrote:
>> images/filesystem/tftpfs_usage.png:
>> https://share.embedded-brains.de/index.php/s/fQ4WrLrqmBjcbwC
> I have a greyed out image I cannot clearly see?
The image has a transparent background. Some image viewers put a gray
pattern in the background in those case. The PDF has naturally a white
background on top of which the image is displayed.
>> images/filesystem/ftpfs_usage.svg:
>> https://share.embedded-brains.de/index.php/s/xk7kArkm6mbjcn2
>> The SVG file is the source for the PNG. Both files must be placed in the
>> images/filesystem folder.
> How is the SVG file created and how can it be edited?
I used Inkscape. It should be possible to edit it with (almost) any tool
that supports SVG. Your Web-Browser should be able to display SVG
directly when you point it to the file like for example:
file:///home/<user-name>/tftpfs_usage.svg
You can recreate the PNG with Inkscape on the command line with:
tftpfs_usage.svg
Greetings
Frank
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
fax:    +49-89-18 94 741 - 08
Registernummer: HRB 157899
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221011/ebdfbc62/attachment-0001.png>
