[PATCH 1/2] bsps/riscv: Remove inaccurate statement about reliance on a boot loader
Hesham Almatary heshamelmatary at gmail.com
Tue Oct 25 18:04:03 UTC 2022
On Tue, 25 Oct 2022 at 18:59, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> I agree – I am working on a riscv BSP variant (Sipeed MAIX Bit with K210 CPU) where the RTEMS image can be flashed directly to the board and boots without a bootloader.
> I was also wondering if the statement “Each variant corresponds to a GCC multilib” is still accurate as BSP variants such as the FE310Arty and Microchip Polarfire are added?
I agree. It only applies to rv* BSPs. We should fix that.
> Thanks,
> Alan
> From: heshamelmatary at gmail.com
> Sent: Tuesday, October 25, 2022 1:48 PM
> To: devel at rtems.org
> Subject: [PATCH 1/2] bsps/riscv: Remove inaccurate statement about reliance on a boot loader
> From: Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
> The BSP is capable of initialising the hardware being the first software
> that takes control on hardware reset (after the bootrom). For instance,
> using on QEMU's  virt platforms, RTEMS runs as a bios without BBL.
> Similarily, RTEMS can also be run on harware/FPGA and loaded using
> GDB; the bootrom (or a GDB script) should just set the a0/a1 registers
> with the boot HART ID and DTB address respectively.
> user/bsps/bsps-riscv.rst | 4 +---
> 1 file changed, 1 insertion(+), 3 deletions(-)
> diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
> index 48e7ee7..224506d 100644
> --- a/user/bsps/bsps-riscv.rst
> +++ b/user/bsps/bsps-riscv.rst
> @@ -43,9 +43,7 @@ This BSP offers 15 variants:
> Each variant corresponds to a GCC multilib.  A particular variant reflects an
> ISA with ABI and code model choice.
> -The basic hardware initialization is not performed by the BSP.  A boot loader
> -with device tree support must be used to start the BSP, e.g. BBL.  The BSP must
> -be started im machine mode.
> +The BSP must be started im machine mode.
>  The reference platform for this BSP is the Qemu `virt` machine.
> 2.25.1
> devel mailing list
> devel at rtems.org
Hesham
