[PATCH 1/2] bsps/riscv: Remove inaccurate statement about reliance on a boot loader
Hesham Almatary heshamelmatary at gmail.com
Mon Oct 31 11:44:28 UTC 2022
Hello,
I tried to push that but got an error message:
"remote: git_buildbot: ERROR: Could not connect to
buildbot.int.rtems.org:9899: Connection was refused by other side: 61:
Connection refused."
Please push if you're happy with the patch.
Cheers,
Hesham
On Tue, 25 Oct 2022 at 19:04, Hesham Almatary <heshamelmatary at gmail.com> wrote:
> On Tue, 25 Oct 2022 at 18:59, Alan Cudmore <alan.cudmore at gmail.com> wrote:
> > I agree – I am working on a riscv BSP variant (Sipeed MAIX Bit with K210 CPU) where the RTEMS image can be flashed directly to the board and boots without a bootloader.
> > I was also wondering if the statement “Each variant corresponds to a GCC multilib” is still accurate as BSP variants such as the FE310Arty and Microchip Polarfire are added?
> I agree. It only applies to rv* BSPs. We should fix that.
> > Thanks,
> > Alan
> > From: heshamelmatary at gmail.com
> > Sent: Tuesday, October 25, 2022 1:48 PM
> > To: devel at rtems.org
> > Subject: [PATCH 1/2] bsps/riscv: Remove inaccurate statement about reliance on a boot loader
> > From: Hesham Almatary <hesham.almatary at cl.cam.ac.uk>
> > The BSP is capable of initialising the hardware being the first software
> > that takes control on hardware reset (after the bootrom). For instance,
> > using on QEMU's  virt platforms, RTEMS runs as a bios without BBL.
> > Similarily, RTEMS can also be run on harware/FPGA and loaded using
> > GDB; the bootrom (or a GDB script) should just set the a0/a1 registers
> > with the boot HART ID and DTB address respectively.
> > user/bsps/bsps-riscv.rst | 4 +---
> > 1 file changed, 1 insertion(+), 3 deletions(-)
> > diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
> > index 48e7ee7..224506d 100644
> > --- a/user/bsps/bsps-riscv.rst
> > +++ b/user/bsps/bsps-riscv.rst
> > @@ -43,9 +43,7 @@ This BSP offers 15 variants:
> > Each variant corresponds to a GCC multilib.  A particular variant reflects an
> > ISA with ABI and code model choice.
> > -The basic hardware initialization is not performed by the BSP.  A boot loader
> > -with device tree support must be used to start the BSP, e.g. BBL.  The BSP must
> > -be started im machine mode.
> > +The BSP must be started im machine mode.
> >  The reference platform for this BSP is the Qemu `virt` machine.
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
> Hesham
Hesham
