[PATCH] cpukit/libdebugger: Fix stepping on ARM architectures
chrisj at rtems.org
chrisj at rtems.org
Thu Oct 27 21:34:44 UTC 2022
Closes #4744
cpukit/libdebugger/rtems-debugger-arm.c | 808 +++++++++++++++---------
1 file changed, 495 insertions(+), 313 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-arm.c b/cpukit/libdebugger/rtems-debugger-arm.c
index ba01a860c8..cdc615ce64 100644
--- a/cpukit/libdebugger/rtems-debugger-arm.c
+++ b/cpukit/libdebugger/rtems-debugger-arm.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2016-2019 Chris Johns <chrisj at rtems.org>.
+ * Copyright (c) 2016-2022 Chris Johns <chrisj at rtems.org>.
* All rights reserved.
@@ -86,14 +86,26 @@
#define ARM_SWITCH_REG uint32_t arm_switch_reg
#define ARM_SWITCH_REG_ASM [arm_switch_reg] "=&r" (arm_switch_reg)
#define ARM_SWITCH_REG_ASM_L ARM_SWITCH_REG_ASM,
+ #define ASM_ARM_ASM ".align 2\n.arm\n"
#define ASM_ARM_MODE ".align 2\nbx pc\n.arm\n"
#define ASM_THUMB_MODE "add %[arm_switch_reg], pc, #1\nbx %[arm_switch_reg]\n.thumb\n"
+ #define ARM_THUMB_MODE() __asm__ volatile(ASM_THUMB_MODE : ARM_SWITCH_REG_ASM : :);
+ #define ARM_ARM_MODE() __asm__ volatile(ASM_ARM_MODE : : :);
#else
+#endif
+#ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
+#define ARM_SYNC_INST "isb\n"
+#else
#endif
@@ -287,29 +299,19 @@ static const size_t exc_offsets[2][5] =
static bool debug_session_active;
- * ARM debug hardware.
+ * ARM debug hardware. These variables are directly access
+ * from assembler so do not change types.
static int debug_version;
static void* debug_registers;
static int debug_revision;
-static bool debug_disable_ints;
+static int debug_disable_ints;
static int hw_breakpoints;
static int hw_watchpoints;
* Hardware break and watch points.
-typedef struct
- bool enabled;
- bool loaded;
- void* address;
- size_t length;
- CPU_Exception_frame* frame;
- uint32_t control;
- uint32_t value;
-} arm_debug_hwbreak;
#define ARM_HW_BREAKPOINT_MAX (16)
#define ARM_HW_WATCHPOINT_MAX (16)
@@ -327,8 +329,23 @@ typedef struct
#define ARM_HW_BP_PRIV_PL0_ONLY (0x02)
#define ARM_HW_BP_PRIV_ALL_MODES (0x03)
-static arm_debug_hwbreak hw_breaks[ARM_HW_BREAKPOINT_MAX];
-//static arm_debug_hwbreak hw_watches[ARM_HW_WATCHPOINT_MAX];
+ * A hw breakpoint has DBGBCR and DBGBVR registers. Allocate memory
+ * for each.
+ * Maintian the values ready to load into the hardware. The loader is
+ * a load of the value and then control for enabled BPs.
+static uint32_t hw_breaks[ARM_HW_BREAKPOINT_MAX * 2];
+ * The order in the array is important
+#define ARM_HWB_BCR(_bp) (hw_breaks[((_bp) * 2) + 1])
+#define ARM_HWB_VCR(_bp) (hw_breaks[(_bp) * 2])
+#define ARM_HWB_ENALBED(_bp) ((ARM_HWB_BCR(_bp) & 1) != 0)
+#define ARM_HWB_CLEAR(_bp) ARM_HWB_BCR(_bp) = 0; ARM_HWB_VCR(_bp) = 0
+#define ARM_HWB_CLEAR_ALL() memset(&hw_breaks[0], 0, sizeof(hw_breaks))
* Method of entry (MOE) to debug mode. Bits [5:2] of DBGDSCR.
@@ -439,6 +456,7 @@ arm_moe_label(uint32_t moe)
asm volatile( \
ASM_ARM_MODE \
ARM_CP_INSTR(mcr, _cp, _op1, val, _CRn, _CRm, _op2) \
+ ARM_SYNC_INST \
ASM_THUMB_MODE \
: ARM_SWITCH_REG_ASM \
: [val] "r" (_val)); \
@@ -449,6 +467,7 @@ arm_moe_label(uint32_t moe)
ARM_SWITCH_REG; \
asm volatile( \
ASM_ARM_MODE \
+ ARM_SYNC_INST \
ARM_CP_INSTR(mrc, _cp, _op1, val, _CRn, _CRm, _op2) \
ASM_THUMB_MODE \
: ARM_SWITCH_REG_ASM_L \
@@ -491,9 +510,21 @@ arm_moe_label(uint32_t moe)
* Read and write a memory mapped debug register. The register number is a word
* offset from the base address.
-#define ARM_MMAP_ADDR(reg) (((volatile uint32_t*) debug_registers) + (reg))
-#define ARM_MMAP_WRITE(reg, val) *ARM_MMAP_ADDR(reg) = (val); _ARM_Data_synchronization_barrier()
-#define ARM_MMAP_READ(reg) *ARM_MMAP_ADDR(reg)
+#define ARM_MMAP_ADDR(reg) \
+ (((volatile uint32_t*) debug_registers) + (reg))
+#define ARM_MMAP_WRITE(reg, val) *ARM_MMAP_ADDR(reg) = (val)
+#define ARM_MMAP_READ(reg) *ARM_MMAP_ADDR(reg)
+#define ARM_MMAP_WRITE_SYNC(reg, val) \
+ ARM_MMAP_WRITE(reg, val); \
+ _ARM_Data_synchronization_barrier(); \
+ _ARM_Instruction_synchronization_barrier()
+ * Debug hardware breakpoint registers.
+#define ARM_MMAP_DBGDSCR 34
+#define ARM_MMAP_DBGBCR 80
+#define ARM_MMAP_DBGBVR 64
static bool
arm_debug_authentication(uint32_t dbgauthstatus)
@@ -902,16 +933,17 @@ arm_debug_mmap_enable(rtems_debugger_target* target, uint32_t dbgdidr)
* which seems to make the debug hardware work.
if (ARM_MMAP_READ(1005) == 3) {
- ARM_MMAP_WRITE(1004, 0xC5ACCE55);
+ ARM_MMAP_WRITE_SYNC(1004, 0xC5ACCE55);
* Are we already in debug mode?
- val = ARM_MMAP_READ(34);
+ val = ARM_MMAP_READ(ARM_MMAP_DBGDSCR);
if ((val & (1 << 15)) == 0) {
rtems_debugger_printf("rtems-db: arm debug: enable debug mode\n");
- ARM_MMAP_WRITE(34, ARM_MMAP_READ(34) | (1 << 15));
+ ARM_MMAP_WRITE_SYNC(ARM_MMAP_DBGDSCR,
+ ARM_MMAP_READ(ARM_MMAP_DBGDSCR) | (1 << 15));
arm_debug_retries = 0;
@@ -1002,139 +1034,125 @@ arm_debug_probe(rtems_debugger_target* target)
static inline void
-arm_debug_break_setup(arm_debug_hwbreak* bp,
- uint32_t address,
- uint32_t type,
- uint32_t byte_address_select,
- uint32_t privilege)
+arm_debug_break_setup(int bp,
+ uint32_t address,
+ uint32_t type,
+ uint32_t byte_address_select,
+ uint32_t privilege)
- bp->control = (((type & 0xf) << 20) |
- ((byte_address_select & 0xf) << 5) |
- ((privilege & 0x3) << 1) | 1);
- bp->value = (intptr_t) address;
+ ARM_HWB_BCR(bp) = (((type & 0xf) << 20) |
+ ((byte_address_select & 0xf) << 5) |
+ ((privilege & 0x3) << 1) | 1);
+ ARM_HWB_VCR(bp) = (intptr_t) (address & (~3));
static void
-arm_debug_break_write_control(int bp, uint32_t control)
+arm_debug_break_c14_write_control(int bp, uint32_t control)
- if (bp < 15) {
- if (debug_registers != NULL) {
- ARM_MMAP_WRITE(80 + bp, control);
- else {
- switch (bp) {
- case 0:
- ARM_CP14_WRITE(control, 0, 0, 5);
- break;
- case 1:
- ARM_CP14_WRITE(control, 0, 1, 5);
- break;
- case 2:
- ARM_CP14_WRITE(control, 0, 2, 5);
- break;
- case 3:
- ARM_CP14_WRITE(control, 0, 3, 5);
- break;
- case 4:
- ARM_CP14_WRITE(control, 0, 4, 5);
- break;
- case 5:
- ARM_CP14_WRITE(control, 0, 5, 5);
- break;
- case 6:
- ARM_CP14_WRITE(control, 0, 6, 5);
- break;
- case 7:
- ARM_CP14_WRITE(control, 0, 7, 5);
- break;
- case 8:
- ARM_CP14_WRITE(control, 0, 8, 5);
- break;
- case 9:
- ARM_CP14_WRITE(control, 0, 9, 5);
- break;
- case 10:
- ARM_CP14_WRITE(control, 0, 10, 5);
- break;
- case 11:
- ARM_CP14_WRITE(control, 0, 11, 5);
- break;
- case 12:
- ARM_CP14_WRITE(control, 0, 12, 5);
- break;
- case 13:
- ARM_CP14_WRITE(control, 0, 13, 5);
- break;
- case 14:
- ARM_CP14_WRITE(control, 0, 14, 5);
- break;
- case 15:
- ARM_CP14_WRITE(control, 0, 15, 5);
- break;
+ switch (bp) {
+ case 0:
+ ARM_CP14_WRITE(control, 0, 0, 5);
+ break;
+ case 1:
+ ARM_CP14_WRITE(control, 0, 1, 5);
+ break;
+ case 2:
+ ARM_CP14_WRITE(control, 0, 2, 5);
+ break;
+ case 3:
+ ARM_CP14_WRITE(control, 0, 3, 5);
+ break;
+ case 4:
+ ARM_CP14_WRITE(control, 0, 4, 5);
+ break;
+ case 5:
+ ARM_CP14_WRITE(control, 0, 5, 5);
+ break;
+ case 6:
+ ARM_CP14_WRITE(control, 0, 6, 5);
+ break;
+ case 7:
+ ARM_CP14_WRITE(control, 0, 7, 5);
+ break;
+ case 8:
+ ARM_CP14_WRITE(control, 0, 8, 5);
+ break;
+ case 9:
+ ARM_CP14_WRITE(control, 0, 9, 5);
+ break;
+ case 10:
+ ARM_CP14_WRITE(control, 0, 10, 5);
+ break;
+ case 11:
+ ARM_CP14_WRITE(control, 0, 11, 5);
+ break;
+ case 12:
+ ARM_CP14_WRITE(control, 0, 12, 5);
+ break;
+ case 13:
+ ARM_CP14_WRITE(control, 0, 13, 5);
+ break;
+ case 14:
+ ARM_CP14_WRITE(control, 0, 14, 5);
+ break;
+ case 15:
+ ARM_CP14_WRITE(control, 0, 15, 5);
+ break;
static void
-arm_debug_break_write_value(int bp, uint32_t value)
+arm_debug_break_c14_write_value(int bp, uint32_t value)
- if (bp < 15) {
- ARM_MMAP_WRITE(64 + bp, value);
- else {
- switch (bp) {
- case 0:
- ARM_CP14_WRITE(value, 0, 0, 4);
- break;
- case 1:
- ARM_CP14_WRITE(value, 0, 1, 4);
- break;
- case 2:
- ARM_CP14_WRITE(value, 0, 2, 4);
- break;
- case 3:
- ARM_CP14_WRITE(value, 0, 3, 4);
- break;
- case 4:
- ARM_CP14_WRITE(value, 0, 4, 4);
- break;
- case 5:
- ARM_CP14_WRITE(value, 0, 5, 4);
- break;
- case 6:
- ARM_CP14_WRITE(value, 0, 6, 4);
- break;
- case 7:
- ARM_CP14_WRITE(value, 0, 7, 4);
- break;
- case 8:
- ARM_CP14_WRITE(value, 0, 8, 4);
- break;
- case 9:
- ARM_CP14_WRITE(value, 0, 9, 4);
- break;
- case 10:
- ARM_CP14_WRITE(value, 0, 10, 4);
- break;
- case 11:
- ARM_CP14_WRITE(value, 0, 11, 4);
- break;
- case 12:
- ARM_CP14_WRITE(value, 0, 12, 4);
- break;
- case 13:
- ARM_CP14_WRITE(value, 0, 13, 4);
- break;
- case 14:
- ARM_CP14_WRITE(value, 0, 14, 4);
- break;
- case 15:
- ARM_CP14_WRITE(value, 0, 15, 4);
- break;
+ switch (bp) {
+ case 0:
+ ARM_CP14_WRITE(value, 0, 0, 4);
+ break;
+ case 1:
+ ARM_CP14_WRITE(value, 0, 1, 4);
+ break;
+ case 2:
+ ARM_CP14_WRITE(value, 0, 2, 4);
+ break;
+ case 3:
+ ARM_CP14_WRITE(value, 0, 3, 4);
+ break;
+ case 4:
+ ARM_CP14_WRITE(value, 0, 4, 4);
+ break;
+ case 5:
+ ARM_CP14_WRITE(value, 0, 5, 4);
+ break;
+ case 6:
+ ARM_CP14_WRITE(value, 0, 6, 4);
+ break;
+ case 7:
+ ARM_CP14_WRITE(value, 0, 7, 4);
+ break;
+ case 8:
+ ARM_CP14_WRITE(value, 0, 8, 4);
+ break;
+ case 9:
+ ARM_CP14_WRITE(value, 0, 9, 4);
+ break;
+ case 10:
+ ARM_CP14_WRITE(value, 0, 10, 4);
+ break;
+ case 11:
+ ARM_CP14_WRITE(value, 0, 11, 4);
+ break;
+ case 12:
+ ARM_CP14_WRITE(value, 0, 12, 4);
+ break;
+ case 13:
+ ARM_CP14_WRITE(value, 0, 13, 4);
+ break;
+ case 14:
+ ARM_CP14_WRITE(value, 0, 14, 4);
+ break;
+ case 15:
+ ARM_CP14_WRITE(value, 0, 15, 4);
+ break;
@@ -1143,7 +1161,7 @@ arm_debug_dbgdscr_read(void)
uint32_t val;
else {
ARM_CP14_READ(val, 0, 1, 0);
@@ -1155,7 +1173,7 @@ static void
arm_debug_dbgdscr_write(uint32_t val)
- ARM_MMAP_WRITE(34, val);
+ ARM_MMAP_WRITE_SYNC(ARM_MMAP_DBGDSCR, val);
else {
ARM_CP14_WRITE(val, 0, 1, 0);
@@ -1171,35 +1189,30 @@ arm_debug_method_of_entry(void)
static void
arm_debug_disable_interrupts(void)
- debug_disable_ints = true;
+ debug_disable_ints = 1;
static void
-arm_debug_commit_interrupt_disable(void)
+arm_debug_enable_interrupts(void)
- if (debug_disable_ints) {
- arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() | (1 << 11));
- debug_disable_ints = false;
+ arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() & ~(1 << 11));
static void
-arm_debug_enable_interrupts(void)
+arm_debug_break_clear(int bp)
- arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() & ~(1 << 11));
+ rtems_interrupt_lock_context lock_context;
+ rtems_interrupt_lock_acquire(&target_lock, &lock_context);
+ ARM_HWB_CLEAR(bp);
+ rtems_interrupt_lock_release(&target_lock, &lock_context);
static void
-arm_debug_break_clear(void)
+arm_debug_break_clear_all(void)
- arm_debug_hwbreak* bp = &hw_breaks[0];
- int i;
- for (i = 0; i < hw_breakpoints; ++i, ++bp) {
- bp->enabled = false;
- bp->loaded = false;
+ ARM_HWB_CLEAR_ALL();
@@ -1211,58 +1224,81 @@ arm_debug_set_context_id(const uint32_t id)
#endif
- * You can only load the hardware breaks points when in the SVC mode or the
- * single step inverted break point will trigger.
static void
-arm_debug_break_load(void)
+arm_debug_break_unload(void)
- int i;
+ int i;
- if (bp->enabled && !bp->loaded) {
- arm_debug_set_context_id(0xdead1111);
- arm_debug_break_write_value(0, bp->value);
- arm_debug_break_write_control(0, bp->control);
- ++bp;
- for (i = 1; i < hw_breakpoints; ++i, ++bp) {
- bp->loaded = true;
- arm_debug_break_write_value(i, bp->value);
- arm_debug_break_write_control(i, bp->control);
+ if (debug_registers != NULL) {
+ for (i = 0; i < hw_breakpoints; ++i) {
+ ARM_MMAP_WRITE(ARM_MMAP_DBGBCR + i, 0);
+ ARM_MMAP_WRITE(ARM_MMAP_DBGBVR + i, 0);
+ } else {
+ arm_debug_break_c14_write_control(i, 0);
+ arm_debug_break_c14_write_value(i, 0);
static void
-arm_debug_break_unload(void)
- rtems_interrupt_lock_context lock_context;
- int i;
- rtems_interrupt_lock_acquire(&target_lock, &lock_context);
- arm_debug_set_context_id(0);
- arm_debug_break_write_control(i, 0);
+arm_debug_break_exec_enable(int bp, uintptr_t addr, bool thumb, bool step) {
+ uint32_t bas;
+ * See table C3-2 Effect of byte address selection on Breakpoint
+ * generation and "Instruction address comparision programming
+ * examples.
+ if (thumb) {
+ * Thumb
+ if ((addr & (1 << 1)) == 0) {
+ * Instruction address: DBGBVR[31:2]:00 BAS: 0bxx11 Mismatch: Miss
+ bas = 0x3; /* bxx11 */
+ else {
+ * Instruction address: DBGBVR[31:2]:10 BAS: 0b11xx Mismatch: Miss
+ bas = 0xc; /* b11xx */
- rtems_interrupt_lock_release(&target_lock, &lock_context);
+ else {
+ * ARM
+ * Instruction address: DBGBVR[31:2]:00 BAS: 0b1111 Mismatch: Miss
+ bas = 0xf; /* b1111 */
+ target_printk("[} break: addr:%08x bas:%x thumb:%s\n",
+ addr, bas, thumb ? "yes" : "no");
+ arm_debug_break_setup(
+ bp,
+ addr,
+ step ? ARM_HW_BP_UNLINKED_INSTR_MISMATCH : ARM_HW_BP_UNLINKED_INSTR_MATCH,
+ bas,
+ ARM_HW_BP_PRIV_PL0_SUP_SYS);
static void
arm_debug_break_dump(void)
#if TARGET_DEBUG
int i;
- if (bp->enabled) {
+ if (ARM_HWB_ENALBED(i)) {
target_printk("[} bp: %d: control: %08x addr: %08x\n",
- i, bp->control, bp->value);
+ i, ARM_HWB_BCR(i), ARM_HWB_VCR(i));
#endif
@@ -1314,6 +1350,8 @@ target_exception(CPU_Exception_frame* frame)
#if TARGET_DEBUG
#if ARM_CP15
const uint32_t ifsr = arm_cp15_get_instruction_fault_status();
+ const uint32_t dfsr = arm_cp15_get_data_fault_status();
+ const void* far = arm_cp15_get_fault_address();
#else
const uint32_t ifsr = 0;
#endif
@@ -1341,18 +1379,20 @@ target_exception(CPU_Exception_frame* frame)
target_printk("[} > frame = %08" PRIx32 \
" sig=%d vector=%u (%u) dbgdscr=%08" PRIx32 " moe=%s" \
- " ifsr=%08" PRIx32 " pra=%08x\n",
- (uint32_t) frame,
+ " far=%p ifsr=%08" PRIx32 " dfsr=%08" PRIx32
+ " exc-ret-pc=%08x\n", (uint32_t) frame,
rtems_debugger_target_exception_to_signal(frame),
frame->vector, mvector, dbgdscr, arm_moe_label(moe),
- ifsr, (intptr_t) frame->register_pc);
+ far, ifsr, dfsr, (intptr_t) frame->register_pc);
+ arm_debug_break_dump();
frame->register_pc = (void*) ((intptr_t) frame->register_pc - exc_offset);
target_print_frame(frame);
+ arm_debug_break_clear(0);
arm_debug_enable_interrupts();
- arm_debug_break_clear();
if (!debug_session_active)
_ARM_Exception_default(frame);
@@ -1373,9 +1413,15 @@ target_exception(CPU_Exception_frame* frame)
" PC = %08" PRIxPTR " CPSR = %08" PRIx32 "\n",
(uint32_t) frame, (intptr_t) frame->register_pc, FRAME_SR(frame));
- arm_debug_break_dump();
+ * Exception Handlers
+ * The entry and exit is all assembler and ARM code. This avoids any
+ * compiler related optimisations effecting the various pieces.
* Exception stack frame size.
@@ -1408,15 +1454,89 @@ target_exception(CPU_Exception_frame* frame)
#define EXCEPTION_ENTRY_EXC() \
__asm__ volatile( \
- ASM_ARM_MODE \
+ ASM_ARM_MODE /* force ARM mode for thumb systems */ \
"sub sp, %[frame_size]\n" /* alloc the frame and CPSR */ \
"stm sp, {r0-r12}\n" /* store r0-r12 */ \
- "sub sp, #4\n" \
- "str lr, [sp]\n" /* save the link reg */ \
- ASM_THUMB_MODE \
- : ARM_SWITCH_REG_ASM \
: [frame_size] "i" (EXCEPTION_FRAME_SIZE) \
- : "memory")
+ : "cc", "memory")
+ * Debugger entry
+ * Check if using debug registers else use CP14.
+ * Set all the break point registers to 0. Enable interrupts.
+#if ARM_CP15
+#define ARM_HW_BP_UNLOAD(_bp) \
+ "cmp r0, #" #_bp "\n" \
+ "ble 3f\n" \
+ "mcr p14, 0, r1, c0, c" #_bp ", 5\n" \
+ "mcr p14, 0, r1, c0, c" #_bp ", 4\n"
+#define ARM_DGB_ENABLE_INTS \
+ "mrc p14, 0, r1, c0, c1, 0\n" /* Get the DBGDSCR */ \
+ "bic r1, r1, #(1 << 11)\n" /* enable interrupts */ \
+ "mcr p14, 0, r1, c0, c1, 0\n" /* Set the DBGDSCR */
+#else
+#endif
+#define EXCEPTION_ENTRY_DEBUGGER() \
+ __asm__ volatile( \
+ /* Set up r0 and r1 */ \
+ "movw r0, #:lower16:hw_breakpoints\n" /* get the num hw breaks */ \
+ "movt r0, #:upper16:hw_breakpoints\n" \
+ "ldr r0, [r0]\n" /* r0 = hw_breakpoints */ \
+ "mov r1, #0\n" /* write zero */ \
+ /* Check if debug registers are being used */ \
+ "movw r2, #:lower16:debug_registers\n" /* get the debug regs */ \
+ "movt r2, #:upper16:debug_registers\n" \
+ "ldr r2, [r2]\n" /* r2 = debug_registers */ \
+ "cmp r2, #0\n" /* NULL? */ \
+ "beq 2f\n" /* if NULL use cp14 */ \
+ /* Debug registers */ \
+ "add r3, r2, %[dbgbvr] - 4\n" /* a3 = DBGBCR0, adjusted */ \
+ "add r2, r2, %[dbgbcr] - 4\n" /* a2 = DBGBVR0, adjusted */ \
+ "1:\n" \
+ "str r1, [r3, #4]!\n" /* Store DBGBVR, pre-indexed, modified */ \
+ "str r1, [r2, #4]!\n" /* Store DBGBCR, pre-indexed, modified */ \
+ "sub r0, r0, #1\n" /* one less */ \
+ "cmp r0, #0\n" /* all done? */ \
+ "bne 1b\n" \
+ "ldr r1, [r2, %[dbgdscr]]\n" /* Get the DBGDSCR */ \
+ "str r1, [r2, %[dbgdscr]]\n" /* Set the DBGDSCR */ \
+ "b 4f\n" \
+ /* CP14 */ \
+ "2:\n" \
+ ARM_HW_BP_UNLOAD(0) \
+ ARM_HW_BP_UNLOAD(1) \
+ ARM_HW_BP_UNLOAD(2) \
+ ARM_HW_BP_UNLOAD(3) \
+ ARM_HW_BP_UNLOAD(4) \
+ ARM_HW_BP_UNLOAD(5) \
+ ARM_HW_BP_UNLOAD(6) \
+ ARM_HW_BP_UNLOAD(7) \
+ ARM_HW_BP_UNLOAD(8) \
+ ARM_HW_BP_UNLOAD(9) \
+ ARM_HW_BP_UNLOAD(10) \
+ ARM_HW_BP_UNLOAD(11) \
+ ARM_HW_BP_UNLOAD(12) \
+ ARM_HW_BP_UNLOAD(13) \
+ ARM_HW_BP_UNLOAD(14) \
+ ARM_HW_BP_UNLOAD(15) \
+ "3:\n" \
+ ARM_DGB_ENABLE_INTS \
+ "4:\n" \
+ ARM_SYNC_INST \
+ : [dbgdscr] "i" (ARM_MMAP_DBGDSCR * sizeof(uint32_t)), \
+ [dbgbcr] "i" (ARM_MMAP_DBGBCR * sizeof(uint32_t)), \
+ [dbgbvr] "i" (ARM_MMAP_DBGBVR * sizeof(uint32_t)) \
+ : "cc", "r0", "r1", "r2", "r3", "memory")
* FPU entry. Conditionally D16 or D32 support.
@@ -1430,10 +1550,10 @@ target_exception(CPU_Exception_frame* frame)
"mov r3, #0\n" \
"mov r4, #0\n" \
"adds r6, r5, #128\n" \
- "3:\n" \
+ "1:\n" \
"stmia r5!, {r3-r4}\n" \
"cmp r5, r6\n" \
- "bne 3b\n"
+ "bne 1b\n"
#endif /* ARM_MULTILIB_VFP_D32 */
#define EXCEPTION_ENTRY_FPU(frame_fpu_size) \
"sub sp, %[frame_fpu_size]\n" /* size includes alignment size */ \
@@ -1453,9 +1573,6 @@ target_exception(CPU_Exception_frame* frame)
#define EXCEPTION_ENTRY_THREAD(_frame) \
__asm__ volatile( \
- ASM_ARM_MODE \
- "ldr lr, [sp]\n" /* recover the link reg */ \
- "add sp, #4\n" \
"add r0, sp, %[r0_r12_size]\n" /* get the sp in the frame */ \
"mrs r1, spsr\n" /* get the saved sr */ \
"mov r6, r1\n" /* stash it for later */ \
@@ -1468,7 +1585,7 @@ target_exception(CPU_Exception_frame* frame)
"mov r4, lr\n" /* get the link reg */ \
"msr cpsr, r2\n" /* back to exc mode */ \
"mov r5, lr\n" /* get the PRA */ \
- "stm r0, {r3-r6}\n" /* save into the frame */ \
+ "stm r0, {r3-r6}\n" /* save into the frame: sp,lr,pc,cpsr */ \
"sub r4, r3, %[frame_size]\n" /* destination address */ \
"mov r6, r4\n" /* save the frame */ \
"sub r4, #1\n" /* one before the start */ \
@@ -1491,8 +1608,7 @@ target_exception(CPU_Exception_frame* frame)
"bic r1, r1, %[psr_i]\n" /* clear irq mask, debug checks */ \
"msr cpsr, r1\n" /* restore the state with irq mask clear */ \
- ASM_THUMB_MODE \
- : ARM_SWITCH_REG_ASM_L \
[o_frame] "=r" (_frame) \
: [psr_t] "i" (ARM_PSR_T), \
[psr_i] "i" (ARM_PSR_I), \
@@ -1501,7 +1617,7 @@ target_exception(CPU_Exception_frame* frame)
[frame_size] "i" (EXCEPTION_FRAME_SIZE), \
[o_frame_fpu] "i" (EXCEPTION_FRAME_FPU_OFFSET), \
[frame_fpu_size] "i" (EXCEPTION_FRAME_FPU_SIZE + 4) \
- : "r0", "r1", "r2", "r3", "r4", "r5", "r6", "memory")
+ : "cc", "r0", "r1", "r2", "r3", "r4", "r5", "r6", "memory")
* FPU exit. Conditionally D16 or D32 support.
@@ -1537,9 +1653,8 @@ target_exception(CPU_Exception_frame* frame)
#define EXCEPTION_EXIT_THREAD(_frame) \
__asm__ volatile( \
- ASM_ARM_MODE \
"mov r0, %[i_frame]\n" /* get the frame */ \
- "ldr r0, [r0, %[frame_fpu]]\n" /* recover FPU frame pointer */ \
+ "ldr r0, [r0, %[frame_fpu]]\n" /* recover aligned FPU frame ptr */ \
EXCEPTION_EXIT_FPU(frame_fpu_size) \
"ldr r2, [sp, %[frame_cpsr]]\n" /* recover exc CPSR from thread */ \
"mov r0, sp\n" /* get the thread frame pointer */ \
@@ -1562,11 +1677,8 @@ target_exception(CPU_Exception_frame* frame)
"mov lr, r4\n" /* set the link reg */ \
"msr cpsr, r2\n" /* switch back to the exc's context */ \
"msr spsr, r6\n" /* set the thread's CPSR */ \
- "sub sp, #4\n" \
"mov lr, r5\n" /* get the PC */ \
- ASM_THUMB_MODE \
: [psr_i] "i" (ARM_PSR_I), \
[r0_r12_size] "i" (13 * sizeof(uint32_t)), \
[frame_cpsr] "i" (EXCEPTION_FRAME_SIZE - sizeof(uint32_t)), \
@@ -1574,19 +1686,135 @@ target_exception(CPU_Exception_frame* frame)
[frame_fpu] "i" (EXCEPTION_FRAME_FPU_OFFSET), \
[frame_fpu_size] "i" (EXCEPTION_FRAME_FPU_SIZE + 4), \
[i_frame] "r" (_frame) \
+ * Debugger exit
+ * Set all the break point registers to settgins. Disable interrupts
+ * if debug_disable_ints is true. Clear debug_disable_ints.
+#if ARM_CP15
+#define ARM_HW_BP_LOAD(_bp) \
+ "ble 5f\n" \
+ "ldm r1!, {r2-r3}\n" \
+ "mcr p14, 0, r2, c0, c" #_bp ", 4\n" /* value */ \
+ "mcr p14, 0, r3, c0, c" #_bp ", 5\n" /* control */
+#define ARM_DGB_DISABLE_INTS \
+ "mrc p14, 0, r4, c0, c1, 0\n" /* Get the DBGDSCR */ \
+ "orr r4, r4, #(1 << 11)\n" /* disable interrupts */ \
+ "mcr p14, 0, r4, c0, c1, 0\n" /* Set the DBGDSCR */
+#else
+#endif
+#define EXCEPTION_EXIT_DEBUGGER() \
+ /* Set up r0, r1, r4 and r5 */ \
+ "movw r1, #:lower16:hw_breaks\n" /* get the hw_breaks pointer */ \
+ "movt r1, #:upper16:hw_breaks\n" \
+ "movw r4, #:lower16:debug_disable_ints\n" /* get disable ints */ \
+ "movt r4, #:upper16:debug_disable_ints\n" \
+ "ldr r5, [r4]\n" \
+ "mov r3, #0\n" /* clear debug ints */ \
+ "str r3, [r4]\n" \
+ "beq 3f\n" /* if NULL use cp14 */ \
+ "cmp r5, #0\n" /* false? */ \
+ "beq 1f\n" /* if false do not set ints disable */ \
+ "ldr r4, [r2, %[dbgdscr]]\n" /* Get the DBGDSCR */ \
+ "str r4, [r2, %[dbgdscr]]\n" /* Set the DBGDSCR */ \
+ "1:\n" \
+ "2:\n" \
+ "ldm r1!, {r4-r5}\n" /* load vr and cr */ \
+ "str r4, [r3, #4]!\n" /* Store DBGBVR, pre-indexed, modified */ \
+ "str r5, [r2, #4]!\n" /* Store DBGBCR, pre-indexed, modified */ \
+ "sub r0, r0, #1\n" /* one less? */ \
+ "cmp r0, #1\n" /* all done? */ \
+ "bne 2b\n" \
+ "b 5f\n" \
+ /* CP14 */ \
+ "3:\n" \
+ "beq 4f\n" /* if false do not set ints disable */ \
+ ARM_DGB_DISABLE_INTS \
+ "4:\n" \
+ ARM_HW_BP_LOAD(0) \
+ ARM_HW_BP_LOAD(1) \
+ ARM_HW_BP_LOAD(2) \
+ ARM_HW_BP_LOAD(3) \
+ ARM_HW_BP_LOAD(4) \
+ ARM_HW_BP_LOAD(5) \
+ ARM_HW_BP_LOAD(6) \
+ ARM_HW_BP_LOAD(7) \
+ ARM_HW_BP_LOAD(8) \
+ ARM_HW_BP_LOAD(9) \
+ ARM_HW_BP_LOAD(10) \
+ ARM_HW_BP_LOAD(11) \
+ ARM_HW_BP_LOAD(12) \
+ ARM_HW_BP_LOAD(13) \
+ ARM_HW_BP_LOAD(14) \
+ ARM_HW_BP_LOAD(15) \
+ "5:\n" \
+ ARM_SYNC_INST \
+ : [disints] "X" (debug_disable_ints), /* make the sym available */ \
+ [dbgdscr] "i" (ARM_MMAP_DBGDSCR * sizeof(uint32_t)), \
+ : "cc", "r0", "r1", "r2", "r3", "r4", "r5", "memory")
#define EXCEPTION_EXIT_EXC() \
__asm__ volatile( \
- ASM_ARM_MODE \
- "add sp, #4\n" \
"ldm sp, {r0-r12}\n" /* restore the thread's context */ \
"add sp, %[frame_size]\n" /* free the frame */ \
"subs pc, lr, #0\n" /* return from the exc */ \
+ ARM_SYNC_INST \
- : "memory")
+ : "cc", "memory")
+#define ARM_PUSH_LR() \
+ "push {lr}\n" \
+#define ARM_POP_LR() \
+ "pop {lr}\n" \
+ * Entry and exit stacks
+#define EXCEPTION_ENTRY(_frame) \
+ EXCEPTION_ENTRY_EXC(); \
+ EXCEPTION_ENTRY_DEBUGGER(); \
+ EXCEPTION_ENTRY_THREAD(_frame); \
+ ARM_THUMB_MODE() \
+ ARM_PUSH_LR()
+#define EXCEPTION_EXIT(_frame) \
+ ARM_POP_LR(); \
+ ARM_ARM_MODE(); \
+ EXCEPTION_EXIT_THREAD(_frame); \
+ EXCEPTION_EXIT_DEBUGGER(); \
+ EXCEPTION_EXIT_EXC()
* This is used to catch faulting accesses.
@@ -1596,9 +1824,10 @@ static void __attribute__((naked))
arm_debug_unlock_abort(void)
- ARM_SWITCH_REG;
+ ARM_SWITCH_REGISTERS;
EXCEPTION_ENTRY_THREAD(frame);
+ ARM_SWITCH_BACK;
longjmp(unlock_abort_jmpbuf, -1);
#endif
@@ -1608,16 +1837,10 @@ target_exception_undefined_instruction(void)
ARM_SWITCH_REG;
- EXCEPTION_ENTRY_EXC();
- arm_debug_break_unload();
- arm_debug_enable_interrupts();
- EXCEPTION_ENTRY_THREAD(frame);
+ EXCEPTION_ENTRY(frame);
frame->vector = 1;
target_exception(frame);
- EXCEPTION_EXIT_THREAD(frame);
- arm_debug_commit_interrupt_disable();
- arm_debug_break_load();
- EXCEPTION_EXIT_EXC();
+ EXCEPTION_EXIT(frame);
@@ -1631,16 +1854,10 @@ target_exception_supervisor_call(void)
* this exception is used by the BKPT instruction in the prefetch abort
* handler to signal a TRAP.
frame->vector = 2;
@@ -1648,16 +1865,10 @@ target_exception_prefetch_abort(void)
ARM_SWITCH_REG;
frame->vector = 3;
@@ -1665,16 +1876,10 @@ target_exception_data_abort(void)
ARM_SWITCH_REG;
frame->vector = 4;
#if ARM_CP15
@@ -1776,13 +1981,13 @@ int
rtems_debugger_target_enable(void)
- debug_session_active = true;
+ arm_debug_break_clear_all();
rtems_debugger_target_set_mmu();
rtems_debugger_target_set_vectors();
+ debug_session_active = true;
return 0;
@@ -1795,8 +2000,9 @@ rtems_debugger_target_disable(void)
void* text_end;
#endif
+ debug_disable_ints = 0;
debug_session_active = false;
#if DOES_NOT_WORK
text_begin = &bsp_section_text_begin[0];
@@ -1979,57 +2185,13 @@ rtems_debugger_target_thread_stepping(rtems_debugger_thread* thread)
* 0. This is reserved for single stepping.
CPU_Exception_frame* frame = thread->frame;
- target_printk("[} stepping: %s\n", bp->enabled ? "yes" : "no");
+ target_printk("[} stepping: hbp[0] enabled: %s\n", ARM_HWB_ENALBED(0) ? "yes" : "no");
- if (!bp->enabled) {
+ if (!ARM_HWB_ENALBED(0)) {
const uint32_t addr = (intptr_t) frame->register_pc;
const bool thumb = (FRAME_SR(frame) & (1 << 5)) != 0 ? true : false;
- uint32_t bas;
- bp->enabled = true;
- bp->address = frame->register_pc;
- bp->frame = frame;
- bp->length = sizeof(uint32_t);
- if (thumb) {
- uint16_t instr = *((uint16_t*) frame->register_pc);
- switch (instr & 0xf800) {
- case 0xe800:
- case 0xf000:
- case 0xf800:
- break;
- default:
- bp->length = sizeof(uint16_t);
- break;
- * See table C3-2 Effect of byte address selection on Breakpoint
- * generation and "Instruction address comparision programming
- * examples.
- if (thumb) {
- if ((addr & (1 << 1)) == 0) {
- bas = 0x3; /* b0011 */
- else {
- bas = 0xc; /* b1100 */
- else {
- bas = 0xf; /* b1111 */
- arm_debug_break_setup(bp,
- addr & ~0x3,
- ARM_HW_BP_UNLINKED_INSTR_MISMATCH,
- bas,
- ARM_HW_BP_PRIV_PL0_SUP_SYS);
+ arm_debug_break_exec_enable(0, addr, thumb, true);
arm_debug_disable_interrupts();
@@ -2085,6 +2247,7 @@ rtems_debugger_target_hwbreak_insert(void)
int
rtems_debugger_target_hwbreak_remove(void)
+ target_printk("[} hbreak: remove: unload\n");
return 0;
@@ -2095,15 +2258,34 @@ rtems_debugger_target_hwbreak_control(rtems_debugger_target_watchpoint wp,
DB_UINT addr,
DB_UINT kind)
- * To do.
+ int i;
+ if (wp != rtems_debugger_target_hw_execute) {
+ errno = EIO;
+ return -1;
+ for (i = 1; i < hw_breakpoints; ++i) {
+ if (insert && !ARM_HWB_ENALBED(i)) {
+ arm_debug_break_exec_enable(i, addr, kind == 1, false);
+ break;
+ } else if (!insert && ARM_HWB_ENALBED(i) && ARM_HWB_VCR(i) == (addr & ~3)) {
+ arm_debug_break_clear(i);
+ break;
+ if (!insert && i == hw_breakpoints) {
+ errno = EIO;
+ return -1;
return 0;
int
rtems_debugger_target_cache_sync(rtems_debugger_target_swbreak* swbreak)
+ target_printk("[} cache: sync: %p\n", swbreak->address);
* Flush the data cache and invalidate the instruction cache.
2.37.1
