[PATCH] cpukit/libdebugger: Fix stepping on ARM architectures
Kinsey Moore kinsey.moore at oarcorp.com
Thu Oct 27 22:53:12 UTC 2022
I don't have something I can test this on at the moment, but I don't see
anything glaring that needs to be addressed. Thanks for fixing this, Chris!
On Thu, Oct 27, 2022 at 4:34 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Closes #4744
>  cpukit/libdebugger/rtems-debugger-arm.c | 808 +++++++++++++++---------
>  1 file changed, 495 insertions(+), 313 deletions(-)
> diff --git a/cpukit/libdebugger/rtems-debugger-arm.c
> b/cpukit/libdebugger/rtems-debugger-arm.c
> index ba01a860c8..cdc615ce64 100644
> --- a/cpukit/libdebugger/rtems-debugger-arm.c
> +++ b/cpukit/libdebugger/rtems-debugger-arm.c
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2016-2019 Chris Johns <chrisj at rtems.org>.
> + * Copyright (c) 2016-2022 Chris Johns <chrisj at rtems.org>.
>   * All rights reserved.
>   * Redistribution and use in source and binary forms, with or without
> @@ -86,14 +86,26 @@
>    #define ARM_SWITCH_REG       uint32_t arm_switch_reg
>    #define ARM_SWITCH_REG_ASM   [arm_switch_reg] "=&r" (arm_switch_reg)
>    #define ARM_SWITCH_REG_ASM_L ARM_SWITCH_REG_ASM,
> +  #define ASM_ARM_ASM          ".align 2\n.arm\n"
>    #define ASM_ARM_MODE         ".align 2\nbx pc\n.arm\n"
>    #define ASM_THUMB_MODE       "add %[arm_switch_reg], pc, #1\nbx
> %[arm_switch_reg]\n.thumb\n"
> +  #define ARM_THUMB_MODE()     __asm__ volatile(ASM_THUMB_MODE :
> ARM_SWITCH_REG_ASM : :);
> +  #define ARM_ARM_MODE()       __asm__ volatile(ASM_ARM_MODE : : :);
>  #else
> +#endif
> +#ifdef ARM_MULTILIB_HAS_BARRIER_INSTRUCTIONS
> +#define ARM_SYNC_INST  "isb\n"
> +#else
>  #endif
> @@ -287,29 +299,19 @@ static const size_t exc_offsets[2][5] =
>  static bool debug_session_active;
> - * ARM debug hardware.
> + * ARM debug hardware. These variables are directly access
> + * from assembler so do not change types.
>  static int   debug_version;
>  static void* debug_registers;
>  static int   debug_revision;
> -static bool  debug_disable_ints;
> +static int   debug_disable_ints;
>  static int   hw_breakpoints;
>  static int   hw_watchpoints;
>   * Hardware break and watch points.
> -typedef struct
> -  bool                 enabled;
> -  bool                 loaded;
> -  void*                address;
> -  size_t               length;
> -  CPU_Exception_frame* frame;
> -  uint32_t             control;
> -  uint32_t             value;
> -} arm_debug_hwbreak;
>  #define ARM_HW_BREAKPOINT_MAX (16)
>  #define ARM_HW_WATCHPOINT_MAX (16)
> @@ -327,8 +329,23 @@ typedef struct
>  #define ARM_HW_BP_PRIV_PL0_ONLY    (0x02)
>  #define ARM_HW_BP_PRIV_ALL_MODES   (0x03)
> -static arm_debug_hwbreak hw_breaks[ARM_HW_BREAKPOINT_MAX];
> -//static arm_debug_hwbreak hw_watches[ARM_HW_WATCHPOINT_MAX];
> + * A hw breakpoint has DBGBCR and DBGBVR registers. Allocate memory
> + * for each.
> + * Maintian the values ready to load into the hardware. The loader is
> + * a load of the value and then control for enabled BPs.
> +static uint32_t hw_breaks[ARM_HW_BREAKPOINT_MAX * 2];
> + * The order in the array is important
> +#define ARM_HWB_BCR(_bp) (hw_breaks[((_bp) * 2) + 1])
> +#define ARM_HWB_VCR(_bp) (hw_breaks[(_bp) * 2])
> +#define ARM_HWB_ENALBED(_bp) ((ARM_HWB_BCR(_bp) & 1) != 0)
> +#define ARM_HWB_CLEAR(_bp) ARM_HWB_BCR(_bp) = 0; ARM_HWB_VCR(_bp) = 0
> +#define ARM_HWB_CLEAR_ALL() memset(&hw_breaks[0], 0, sizeof(hw_breaks))
>   * Method of entry (MOE) to debug mode. Bits [5:2] of DBGDSCR.
> @@ -439,6 +456,7 @@ arm_moe_label(uint32_t moe)
>      asm volatile(                                          \
>        ASM_ARM_MODE                                         \
>        ARM_CP_INSTR(mcr, _cp, _op1, val, _CRn, _CRm, _op2)  \
> +      ARM_SYNC_INST                                        \
>        ASM_THUMB_MODE                                       \
>        : ARM_SWITCH_REG_ASM                                 \
>        : [val] "r" (_val));                                 \
> @@ -449,6 +467,7 @@ arm_moe_label(uint32_t moe)
>      ARM_SWITCH_REG;                                        \
>      asm volatile(                                          \
>        ASM_ARM_MODE                                         \
> +      ARM_SYNC_INST                                        \
>        ARM_CP_INSTR(mrc, _cp, _op1, val, _CRn, _CRm, _op2)  \
>        ASM_THUMB_MODE                                       \
>        : ARM_SWITCH_REG_ASM_L                               \
> @@ -491,9 +510,21 @@ arm_moe_label(uint32_t moe)
>   * Read and write a memory mapped debug register. The register number is
> a word
>   * offset from the base address.
> -#define ARM_MMAP_ADDR(reg)       (((volatile uint32_t*) debug_registers)
> + (reg))
> -#define ARM_MMAP_WRITE(reg, val) *ARM_MMAP_ADDR(reg) = (val);
> _ARM_Data_synchronization_barrier()
> -#define ARM_MMAP_READ(reg)       *ARM_MMAP_ADDR(reg)
> +#define ARM_MMAP_ADDR(reg) \
> +  (((volatile uint32_t*) debug_registers) + (reg))
> +#define ARM_MMAP_WRITE(reg, val) *ARM_MMAP_ADDR(reg) = (val)
> +#define ARM_MMAP_READ(reg) *ARM_MMAP_ADDR(reg)
> +#define ARM_MMAP_WRITE_SYNC(reg, val) \
> +  ARM_MMAP_WRITE(reg, val); \
> +  _ARM_Data_synchronization_barrier(); \
> +  _ARM_Instruction_synchronization_barrier()
> + * Debug hardware breakpoint registers.
> +#define ARM_MMAP_DBGDSCR 34
> +#define ARM_MMAP_DBGBCR  80
> +#define ARM_MMAP_DBGBVR  64
>  static bool
>  arm_debug_authentication(uint32_t dbgauthstatus)
> @@ -902,16 +933,17 @@ arm_debug_mmap_enable(rtems_debugger_target* target,
> uint32_t dbgdidr)
>         * which seems to make the debug hardware work.
>        if (ARM_MMAP_READ(1005) == 3) {
> -        ARM_MMAP_WRITE(1004, 0xC5ACCE55);
> +        ARM_MMAP_WRITE_SYNC(1004, 0xC5ACCE55);
>         * Are we already in debug mode?
> -      val = ARM_MMAP_READ(34);
> +      val = ARM_MMAP_READ(ARM_MMAP_DBGDSCR);
>        if ((val & (1 << 15)) == 0) {
>          rtems_debugger_printf("rtems-db: arm debug: enable debug mode\n");
> -        ARM_MMAP_WRITE(34, ARM_MMAP_READ(34) | (1 << 15));
> +        ARM_MMAP_WRITE_SYNC(ARM_MMAP_DBGDSCR,
> +                            ARM_MMAP_READ(ARM_MMAP_DBGDSCR) | (1 << 15));
>          arm_debug_retries = 0;
> @@ -1002,139 +1034,125 @@ arm_debug_probe(rtems_debugger_target* target)
>  static inline void
> -arm_debug_break_setup(arm_debug_hwbreak* bp,
> -                      uint32_t           address,
> -                      uint32_t           type,
> -                      uint32_t           byte_address_select,
> -                      uint32_t           privilege)
> +arm_debug_break_setup(int      bp,
> +                      uint32_t address,
> +                      uint32_t type,
> +                      uint32_t byte_address_select,
> +                      uint32_t privilege)
> -  bp->control = (((type & 0xf) << 20) |
> -                 ((byte_address_select & 0xf) << 5) |
> -                 ((privilege & 0x3) << 1) | 1);
> -  bp->value = (intptr_t) address;
> +  ARM_HWB_BCR(bp) = (((type & 0xf) << 20) |
> +                     ((byte_address_select & 0xf) << 5) |
> +                     ((privilege & 0x3) << 1) | 1);
> +  ARM_HWB_VCR(bp) = (intptr_t) (address & (~3));
>  static void
> -arm_debug_break_write_control(int bp, uint32_t control)
> +arm_debug_break_c14_write_control(int bp, uint32_t control)
> -  if (bp < 15) {
> -    if (debug_registers != NULL) {
> -      ARM_MMAP_WRITE(80 + bp, control);
> -    else {
> -      switch (bp) {
> -      case 0:
> -        ARM_CP14_WRITE(control, 0, 0, 5);
> -        break;
> -      case 1:
> -        ARM_CP14_WRITE(control, 0, 1, 5);
> -        break;
> -      case 2:
> -        ARM_CP14_WRITE(control, 0, 2, 5);
> -        break;
> -      case 3:
> -        ARM_CP14_WRITE(control, 0, 3, 5);
> -        break;
> -      case 4:
> -        ARM_CP14_WRITE(control, 0, 4, 5);
> -        break;
> -      case 5:
> -        ARM_CP14_WRITE(control, 0, 5, 5);
> -        break;
> -      case 6:
> -        ARM_CP14_WRITE(control, 0, 6, 5);
> -        break;
> -      case 7:
> -        ARM_CP14_WRITE(control, 0, 7, 5);
> -        break;
> -      case 8:
> -        ARM_CP14_WRITE(control, 0, 8, 5);
> -        break;
> -      case 9:
> -        ARM_CP14_WRITE(control, 0, 9, 5);
> -        break;
> -      case 10:
> -        ARM_CP14_WRITE(control, 0, 10, 5);
> -        break;
> -      case 11:
> -        ARM_CP14_WRITE(control, 0, 11, 5);
> -        break;
> -      case 12:
> -        ARM_CP14_WRITE(control, 0, 12, 5);
> -        break;
> -      case 13:
> -        ARM_CP14_WRITE(control, 0, 13, 5);
> -        break;
> -      case 14:
> -        ARM_CP14_WRITE(control, 0, 14, 5);
> -        break;
> -      case 15:
> -        ARM_CP14_WRITE(control, 0, 15, 5);
> -        break;
> +  switch (bp) {
> +    case 0:
> +      ARM_CP14_WRITE(control, 0, 0, 5);
> +      break;
> +    case 1:
> +      ARM_CP14_WRITE(control, 0, 1, 5);
> +      break;
> +    case 2:
> +      ARM_CP14_WRITE(control, 0, 2, 5);
> +      break;
> +    case 3:
> +      ARM_CP14_WRITE(control, 0, 3, 5);
> +      break;
> +    case 4:
> +      ARM_CP14_WRITE(control, 0, 4, 5);
> +      break;
> +    case 5:
> +      ARM_CP14_WRITE(control, 0, 5, 5);
> +      break;
> +    case 6:
> +      ARM_CP14_WRITE(control, 0, 6, 5);
> +      break;
> +    case 7:
> +      ARM_CP14_WRITE(control, 0, 7, 5);
> +      break;
> +    case 8:
> +      ARM_CP14_WRITE(control, 0, 8, 5);
> +      break;
> +    case 9:
> +      ARM_CP14_WRITE(control, 0, 9, 5);
> +      break;
> +    case 10:
> +      ARM_CP14_WRITE(control, 0, 10, 5);
> +      break;
> +    case 11:
> +      ARM_CP14_WRITE(control, 0, 11, 5);
> +      break;
> +    case 12:
> +      ARM_CP14_WRITE(control, 0, 12, 5);
> +      break;
> +    case 13:
> +      ARM_CP14_WRITE(control, 0, 13, 5);
> +      break;
> +    case 14:
> +      ARM_CP14_WRITE(control, 0, 14, 5);
> +      break;
> +    case 15:
> +      ARM_CP14_WRITE(control, 0, 15, 5);
> +      break;
>  static void
> -arm_debug_break_write_value(int bp, uint32_t value)
> +arm_debug_break_c14_write_value(int bp, uint32_t value)
> -  if (bp < 15) {
> -      ARM_MMAP_WRITE(64 + bp, value);
> -    else {
> -      switch (bp) {
> -      case 0:
> -        ARM_CP14_WRITE(value, 0, 0, 4);
> -        break;
> -      case 1:
> -        ARM_CP14_WRITE(value, 0, 1, 4);
> -        break;
> -      case 2:
> -        ARM_CP14_WRITE(value, 0, 2, 4);
> -        break;
> -      case 3:
> -        ARM_CP14_WRITE(value, 0, 3, 4);
> -        break;
> -      case 4:
> -        ARM_CP14_WRITE(value, 0, 4, 4);
> -        break;
> -      case 5:
> -        ARM_CP14_WRITE(value, 0, 5, 4);
> -        break;
> -      case 6:
> -        ARM_CP14_WRITE(value, 0, 6, 4);
> -        break;
> -      case 7:
> -        ARM_CP14_WRITE(value, 0, 7, 4);
> -        break;
> -      case 8:
> -        ARM_CP14_WRITE(value, 0, 8, 4);
> -        break;
> -      case 9:
> -        ARM_CP14_WRITE(value, 0, 9, 4);
> -        break;
> -      case 10:
> -        ARM_CP14_WRITE(value, 0, 10, 4);
> -        break;
> -      case 11:
> -        ARM_CP14_WRITE(value, 0, 11, 4);
> -        break;
> -      case 12:
> -        ARM_CP14_WRITE(value, 0, 12, 4);
> -        break;
> -      case 13:
> -        ARM_CP14_WRITE(value, 0, 13, 4);
> -        break;
> -      case 14:
> -        ARM_CP14_WRITE(value, 0, 14, 4);
> -        break;
> -      case 15:
> -        ARM_CP14_WRITE(value, 0, 15, 4);
> -        break;
> +  switch (bp) {
> +    case 0:
> +      ARM_CP14_WRITE(value, 0, 0, 4);
> +      break;
> +    case 1:
> +      ARM_CP14_WRITE(value, 0, 1, 4);
> +      break;
> +    case 2:
> +      ARM_CP14_WRITE(value, 0, 2, 4);
> +      break;
> +    case 3:
> +      ARM_CP14_WRITE(value, 0, 3, 4);
> +      break;
> +    case 4:
> +      ARM_CP14_WRITE(value, 0, 4, 4);
> +      break;
> +    case 5:
> +      ARM_CP14_WRITE(value, 0, 5, 4);
> +      break;
> +    case 6:
> +      ARM_CP14_WRITE(value, 0, 6, 4);
> +      break;
> +    case 7:
> +      ARM_CP14_WRITE(value, 0, 7, 4);
> +      break;
> +    case 8:
> +      ARM_CP14_WRITE(value, 0, 8, 4);
> +      break;
> +    case 9:
> +      ARM_CP14_WRITE(value, 0, 9, 4);
> +      break;
> +    case 10:
> +      ARM_CP14_WRITE(value, 0, 10, 4);
> +      break;
> +    case 11:
> +      ARM_CP14_WRITE(value, 0, 11, 4);
> +      break;
> +    case 12:
> +      ARM_CP14_WRITE(value, 0, 12, 4);
> +      break;
> +    case 13:
> +      ARM_CP14_WRITE(value, 0, 13, 4);
> +      break;
> +    case 14:
> +      ARM_CP14_WRITE(value, 0, 14, 4);
> +      break;
> +    case 15:
> +      ARM_CP14_WRITE(value, 0, 15, 4);
> +      break;
> @@ -1143,7 +1161,7 @@ arm_debug_dbgdscr_read(void)
>    uint32_t val;
>    else {
>      ARM_CP14_READ(val, 0, 1, 0);
> @@ -1155,7 +1173,7 @@ static void
>  arm_debug_dbgdscr_write(uint32_t val)
> -    ARM_MMAP_WRITE(34, val);
> +    ARM_MMAP_WRITE_SYNC(ARM_MMAP_DBGDSCR, val);
>    else {
>      ARM_CP14_WRITE(val, 0, 1, 0);
> @@ -1171,35 +1189,30 @@ arm_debug_method_of_entry(void)
>  static void
>  arm_debug_disable_interrupts(void)
> -  debug_disable_ints = true;
> +  debug_disable_ints = 1;
>  static void
> -arm_debug_commit_interrupt_disable(void)
> +arm_debug_enable_interrupts(void)
> -  if (debug_disable_ints) {
> -    arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() | (1 << 11));
> -    debug_disable_ints = false;
> +  arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() & ~(1 << 11));
>  static void
> -arm_debug_enable_interrupts(void)
> +arm_debug_break_clear(int bp)
> -  arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() & ~(1 << 11));
> +  rtems_interrupt_lock_context lock_context;
> +  rtems_interrupt_lock_acquire(&target_lock, &lock_context);
> +  ARM_HWB_CLEAR(bp);
> +  rtems_interrupt_lock_release(&target_lock, &lock_context);
>  static void
> -arm_debug_break_clear(void)
> +arm_debug_break_clear_all(void)
> -  arm_debug_hwbreak*           bp = &hw_breaks[0];
> -  int                          i;
> -  for (i = 0; i < hw_breakpoints; ++i, ++bp) {
> -    bp->enabled = false;
> -    bp->loaded = false;
> +  ARM_HWB_CLEAR_ALL();
> @@ -1211,58 +1224,81 @@ arm_debug_set_context_id(const uint32_t id)
>  #endif
> - * You can only load the hardware breaks points when in the SVC mode or
> the
> - * single step inverted break point will trigger.
>  static void
> -arm_debug_break_load(void)
> +arm_debug_break_unload(void)
> -  int                          i;
> +  int i;
> -  if (bp->enabled && !bp->loaded) {
> -    arm_debug_set_context_id(0xdead1111);
> -    arm_debug_break_write_value(0, bp->value);
> -    arm_debug_break_write_control(0, bp->control);
> -  ++bp;
> -  for (i = 1; i < hw_breakpoints; ++i, ++bp) {
> -      bp->loaded = true;
> -      arm_debug_break_write_value(i, bp->value);
> -      arm_debug_break_write_control(i, bp->control);
> +  if (debug_registers != NULL) {
> +    for (i = 0; i < hw_breakpoints; ++i) {
> +      ARM_MMAP_WRITE(ARM_MMAP_DBGBCR + i, 0);
> +      ARM_MMAP_WRITE(ARM_MMAP_DBGBVR + i, 0);
> +  } else {
> +      arm_debug_break_c14_write_control(i, 0);
> +      arm_debug_break_c14_write_value(i, 0);
>  static void
> -arm_debug_break_unload(void)
> -  rtems_interrupt_lock_context lock_context;
> -  int                          i;
> -  rtems_interrupt_lock_acquire(&target_lock, &lock_context);
> -  arm_debug_set_context_id(0);
> -    arm_debug_break_write_control(i, 0);
> +arm_debug_break_exec_enable(int bp, uintptr_t addr, bool thumb, bool
> step) {
> +  uint32_t bas;
> +   * See table C3-2 Effect of byte address selection on Breakpoint
> +   * generation and "Instruction address comparision programming
> +   * examples.
> +  if (thumb) {
> +     * Thumb
> +    if ((addr & (1 << 1)) == 0) {
> +       * Instruction address: DBGBVR[31:2]:00 BAS: 0bxx11 Mismatch: Miss
> +      bas = 0x3; /* bxx11 */
> +    else {
> +       * Instruction address: DBGBVR[31:2]:10 BAS: 0b11xx Mismatch: Miss
> +      bas = 0xc; /* b11xx */
> -  rtems_interrupt_lock_release(&target_lock, &lock_context);
> +  else {
> +     * ARM
> +     * Instruction address: DBGBVR[31:2]:00 BAS: 0b1111 Mismatch: Miss
> +    bas = 0xf; /* b1111 */
> +  target_printk("[} break: addr:%08x bas:%x thumb:%s\n",
> +                addr, bas, thumb ? "yes" : "no");
> +  arm_debug_break_setup(
> +    bp,
> +    addr,
> +    step ? ARM_HW_BP_UNLINKED_INSTR_MISMATCH :
> ARM_HW_BP_UNLINKED_INSTR_MATCH,
> +    bas,
> +    ARM_HW_BP_PRIV_PL0_SUP_SYS);
>  static void
>  arm_debug_break_dump(void)
>  #if TARGET_DEBUG
>    int                i;
> -    if (bp->enabled) {
> +    if (ARM_HWB_ENALBED(i)) {
>        target_printk("[} bp: %d: control: %08x addr: %08x\n",
> -                    i, bp->control, bp->value);
> +                    i, ARM_HWB_BCR(i), ARM_HWB_VCR(i));
>  #endif
> @@ -1314,6 +1350,8 @@ target_exception(CPU_Exception_frame* frame)
>  #if TARGET_DEBUG
>  #if ARM_CP15
>    const uint32_t ifsr = arm_cp15_get_instruction_fault_status();
> +  const uint32_t dfsr = arm_cp15_get_data_fault_status();
> +  const void* far = arm_cp15_get_fault_address();
>  #else
>    const uint32_t ifsr = 0;
>  #endif
> @@ -1341,18 +1379,20 @@ target_exception(CPU_Exception_frame* frame)
>    target_printk("[} > frame = %08" PRIx32 \
>                  " sig=%d vector=%u (%u) dbgdscr=%08" PRIx32 " moe=%s" \
> -                " ifsr=%08" PRIx32 " pra=%08x\n",
> -                (uint32_t) frame,
> +                " far=%p ifsr=%08" PRIx32 " dfsr=%08" PRIx32
> +                " exc-ret-pc=%08x\n", (uint32_t) frame,
>                  rtems_debugger_target_exception_to_signal(frame),
>                  frame->vector, mvector, dbgdscr, arm_moe_label(moe),
> -                ifsr, (intptr_t) frame->register_pc);
> +                far, ifsr, dfsr, (intptr_t) frame->register_pc);
> +  arm_debug_break_dump();
>    frame->register_pc = (void*) ((intptr_t) frame->register_pc -
> exc_offset);
>    target_print_frame(frame);
> +  arm_debug_break_clear(0);
>    arm_debug_enable_interrupts();
> -  arm_debug_break_clear();
>    if (!debug_session_active)
>      _ARM_Exception_default(frame);
> @@ -1373,9 +1413,15 @@ target_exception(CPU_Exception_frame* frame)
>                  " PC = %08" PRIxPTR " CPSR = %08" PRIx32 "\n",
>                  (uint32_t) frame, (intptr_t) frame->register_pc,
> FRAME_SR(frame));
> -  arm_debug_break_dump();
> + * Exception Handlers
> + * The entry and exit is all assembler and ARM code. This avoids any
> + * compiler related optimisations effecting the various pieces.
>   * Exception stack frame size.
> @@ -1408,15 +1454,89 @@ target_exception(CPU_Exception_frame* frame)
>  #define EXCEPTION_ENTRY_EXC()                                           \
>    __asm__ volatile(                                                     \
> -    ASM_ARM_MODE                                                        \
> +    ASM_ARM_MODE                 /* force ARM mode for thumb systems */ \
>      "sub  sp, %[frame_size]\n"           /* alloc the frame and CPSR */ \
>      "stm  sp, {r0-r12}\n"                            /* store r0-r12 */ \
> -    "sub  sp, #4\n"                                                     \
> -    "str  lr, [sp]\n"                           /* save the link reg */ \
> -    ASM_THUMB_MODE                                                      \
> -    : ARM_SWITCH_REG_ASM                                                \
>      : [frame_size] "i" (EXCEPTION_FRAME_SIZE)                           \
> -    : "memory")
> +    : "cc", "memory")
> + * Debugger entry
> + * Check if using debug registers else use CP14.
> + * Set all the break point registers to 0. Enable interrupts.
> +#if ARM_CP15
> +#define ARM_HW_BP_UNLOAD(_bp)                                           \
> +    "cmp r0, #" #_bp "\n"                                               \
> +    "ble 3f\n"                                                          \
> +    "mcr p14, 0, r1, c0, c" #_bp ", 5\n"                                \
> +    "mcr p14, 0, r1, c0, c" #_bp ", 4\n"
> +#define ARM_DGB_ENABLE_INTS                                             \
> +    "mrc   p14, 0, r1, c0, c1, 0\n"               /* Get the DBGDSCR */ \
> +    "bic   r1, r1, #(1 << 11)\n"                /* enable interrupts */ \
> +    "mcr   p14, 0, r1, c0, c1, 0\n"               /* Set the DBGDSCR */
> +#else
> +#endif
> +#define EXCEPTION_ENTRY_DEBUGGER()                                      \
> +  __asm__ volatile(                                                     \
> +    /* Set up r0 and r1 */                                              \
> +    "movw  r0, #:lower16:hw_breakpoints\n"  /* get the num hw breaks */ \
> +    "movt  r0, #:upper16:hw_breakpoints\n"                              \
> +    "ldr   r0, [r0]\n"                        /* r0 = hw_breakpoints */ \
> +    "mov   r1, #0\n"                                   /* write zero */ \
> +    /* Check if debug registers are being used */                       \
> +    "movw  r2, #:lower16:debug_registers\n"    /* get the debug regs */ \
> +    "movt  r2, #:upper16:debug_registers\n"                             \
> +    "ldr   r2, [r2]\n"                       /* r2 = debug_registers */ \
> +    "cmp   r2, #0\n"                                        /* NULL? */ \
> +    "beq    2f\n"                                /* if NULL use cp14 */ \
> +    /* Debug registers */                                               \
> +    "add   r3, r2, %[dbgbvr] - 4\n"        /* a3 = DBGBCR0, adjusted */ \
> +    "add   r2, r2, %[dbgbcr] - 4\n"        /* a2 = DBGBVR0, adjusted */ \
> +    "1:\n"                                                              \
> +    "str   r1, [r3, #4]!\n"   /* Store DBGBVR, pre-indexed, modified */ \
> +    "str   r1, [r2, #4]!\n"   /* Store DBGBCR, pre-indexed, modified */ \
> +    "sub   r0, r0, #1\n"                                 /* one less */ \
> +    "cmp   r0, #0\n"                                    /* all done? */ \
> +    "bne   1b\n"                                                        \
> +    "ldr   r1, [r2, %[dbgdscr]]\n"                /* Get the DBGDSCR */ \
> +    "str   r1, [r2, %[dbgdscr]]\n"                /* Set the DBGDSCR */ \
> +    "b     4f\n"                                                        \
> +    /* CP14 */                                                          \
> +    "2:\n"                                                              \
> +    ARM_HW_BP_UNLOAD(0)                                                 \
> +    ARM_HW_BP_UNLOAD(1)                                                 \
> +    ARM_HW_BP_UNLOAD(2)                                                 \
> +    ARM_HW_BP_UNLOAD(3)                                                 \
> +    ARM_HW_BP_UNLOAD(4)                                                 \
> +    ARM_HW_BP_UNLOAD(5)                                                 \
> +    ARM_HW_BP_UNLOAD(6)                                                 \
> +    ARM_HW_BP_UNLOAD(7)                                                 \
> +    ARM_HW_BP_UNLOAD(8)                                                 \
> +    ARM_HW_BP_UNLOAD(9)                                                 \
> +    ARM_HW_BP_UNLOAD(10)                                                \
> +    ARM_HW_BP_UNLOAD(11)                                                \
> +    ARM_HW_BP_UNLOAD(12)                                                \
> +    ARM_HW_BP_UNLOAD(13)                                                \
> +    ARM_HW_BP_UNLOAD(14)                                                \
> +    ARM_HW_BP_UNLOAD(15)                                                \
> +    "3:\n"                                                              \
> +    ARM_DGB_ENABLE_INTS                                                 \
> +    "4:\n"                                                              \
> +    ARM_SYNC_INST                                                       \
> +    : [dbgdscr] "i" (ARM_MMAP_DBGDSCR * sizeof(uint32_t)),              \
> +      [dbgbcr] "i" (ARM_MMAP_DBGBCR * sizeof(uint32_t)),                \
> +      [dbgbvr] "i" (ARM_MMAP_DBGBVR * sizeof(uint32_t))                 \
> +    : "cc", "r0", "r1", "r2", "r3", "memory")
>   * FPU entry. Conditionally D16 or D32 support.
> @@ -1430,10 +1550,10 @@ target_exception(CPU_Exception_frame* frame)
>      "mov    r3, #0\n"                                                   \
>      "mov    r4, #0\n"                                                   \
>      "adds   r6, r5, #128\n"                                             \
> -    "3:\n"                                                              \
> +    "1:\n"                                                              \
>      "stmia  r5!, {r3-r4}\n"                                             \
>      "cmp    r5, r6\n"                                                   \
> -    "bne    3b\n"
> +    "bne    1b\n"
>  #endif /* ARM_MULTILIB_VFP_D32 */
>  #define EXCEPTION_ENTRY_FPU(frame_fpu_size)                             \
>      "sub    sp, %[frame_fpu_size]\n" /* size includes alignment size */ \
> @@ -1453,9 +1573,6 @@ target_exception(CPU_Exception_frame* frame)
>  #define EXCEPTION_ENTRY_THREAD(_frame)                                  \
>    __asm__ volatile(                                                     \
> -    ASM_ARM_MODE                                                        \
> -    "ldr  lr, [sp]\n"                        /* recover the link reg */ \
> -    "add  sp, #4\n"                                                     \
>      "add  r0, sp, %[r0_r12_size]\n"       /* get the sp in the frame */ \
>      "mrs  r1, spsr\n"                            /* get the saved sr */ \
>      "mov  r6, r1\n"                            /* stash it for later */ \
> @@ -1468,7 +1585,7 @@ target_exception(CPU_Exception_frame* frame)
>      "mov  r4, lr\n"                              /* get the link reg */ \
>      "msr  cpsr, r2\n"                            /* back to exc mode */ \
>      "mov  r5, lr\n"                                   /* get the PRA */ \
> -    "stm  r0, {r3-r6}\n"                      /* save into the frame */ \
> +    "stm  r0, {r3-r6}\n"       /* save into the frame: sp,lr,pc,cpsr */ \
>      "sub  r4, r3, %[frame_size]\n"            /* destination address */ \
>      "mov  r6, r4\n"                                /* save the frame */ \
>      "sub  r4, #1\n"                          /* one before the start */ \
> @@ -1491,8 +1608,7 @@ target_exception(CPU_Exception_frame* frame)
>      "bic  r1, r1, %[psr_i]\n"        /* clear irq mask, debug checks */ \
>      "msr  cpsr, r1\n"       /* restore the state with irq mask clear */ \
> -    ASM_THUMB_MODE                                                      \
> -    : ARM_SWITCH_REG_ASM_L                                              \
>        [o_frame] "=r" (_frame)                                           \
>      : [psr_t] "i" (ARM_PSR_T),                                          \
>        [psr_i] "i" (ARM_PSR_I),                                          \
> @@ -1501,7 +1617,7 @@ target_exception(CPU_Exception_frame* frame)
>        [frame_size] "i" (EXCEPTION_FRAME_SIZE),                          \
>        [o_frame_fpu] "i" (EXCEPTION_FRAME_FPU_OFFSET),                   \
>        [frame_fpu_size] "i" (EXCEPTION_FRAME_FPU_SIZE + 4)               \
> -    : "r0", "r1", "r2", "r3", "r4", "r5", "r6", "memory")
> +    : "cc", "r0", "r1", "r2", "r3", "r4", "r5", "r6", "memory")
>   * FPU exit. Conditionally D16 or D32 support.
> @@ -1537,9 +1653,8 @@ target_exception(CPU_Exception_frame* frame)
>  #define EXCEPTION_EXIT_THREAD(_frame)                                   \
>    __asm__ volatile(                                                     \
> -    ASM_ARM_MODE                                                        \
>      "mov  r0, %[i_frame]\n"                         /* get the frame */ \
> -    "ldr  r0, [r0, %[frame_fpu]]\n"     /* recover FPU frame pointer */ \
> +    "ldr  r0, [r0, %[frame_fpu]]\n" /* recover aligned FPU frame ptr */ \
>      EXCEPTION_EXIT_FPU(frame_fpu_size)                                  \
>      "ldr  r2, [sp, %[frame_cpsr]]\n" /* recover exc CPSR from thread */ \
>      "mov  r0, sp\n"                  /* get the thread frame pointer */ \
> @@ -1562,11 +1677,8 @@ target_exception(CPU_Exception_frame* frame)
>      "mov  lr, r4\n"                              /* set the link reg */ \
>      "msr  cpsr, r2\n"            /* switch back to the exc's context */ \
>      "msr  spsr, r6\n"                       /* set the thread's CPSR */ \
> -    "sub  sp, #4\n"                                                     \
>      "mov  lr, r5\n"                                    /* get the PC */ \
> -    ASM_THUMB_MODE                                                      \
>      : [psr_i] "i" (ARM_PSR_I),                                          \
>        [r0_r12_size] "i" (13 * sizeof(uint32_t)),                        \
>        [frame_cpsr] "i" (EXCEPTION_FRAME_SIZE - sizeof(uint32_t)),       \
> @@ -1574,19 +1686,135 @@ target_exception(CPU_Exception_frame* frame)
>        [frame_fpu] "i" (EXCEPTION_FRAME_FPU_OFFSET),                     \
>        [frame_fpu_size] "i" (EXCEPTION_FRAME_FPU_SIZE + 4),              \
>        [i_frame] "r" (_frame)                                            \
> + * Debugger exit
> + * Set all the break point registers to settgins. Disable interrupts
> + * if debug_disable_ints is true. Clear debug_disable_ints.
> +#if ARM_CP15
> +#define ARM_HW_BP_LOAD(_bp)                                             \
> +    "ble 5f\n"                                                          \
> +    "ldm r1!, {r2-r3}\n"                                                \
> +    "mcr p14, 0, r2, c0, c" #_bp ", 4\n"                    /* value */ \
> +    "mcr p14, 0, r3, c0, c" #_bp ", 5\n"                  /* control */
> +#define ARM_DGB_DISABLE_INTS                                            \
> +    "mrc   p14, 0, r4, c0, c1, 0\n"               /* Get the DBGDSCR */ \
> +    "orr   r4, r4, #(1 << 11)\n"               /* disable interrupts */ \
> +    "mcr   p14, 0, r4, c0, c1, 0\n"               /* Set the DBGDSCR */
> +#else
> +#endif
> +#define EXCEPTION_EXIT_DEBUGGER()                                       \
> +    /* Set up r0, r1, r4 and r5 */                                      \
> +    "movw  r1, #:lower16:hw_breaks\n"   /* get the hw_breaks pointer */ \
> +    "movt  r1, #:upper16:hw_breaks\n"                                   \
> +    "movw  r4, #:lower16:debug_disable_ints\n"   /* get disable ints */ \
> +    "movt  r4, #:upper16:debug_disable_ints\n"                          \
> +    "ldr   r5, [r4]\n"                                                  \
> +    "mov   r3, #0\n"                             /* clear debug ints */ \
> +    "str   r3, [r4]\n"                                                  \
> +    "beq   3f\n"                                 /* if NULL use cp14 */ \
> +    "cmp   r5, #0\n"                                       /* false? */ \
> +    "beq   1f\n"                 /* if false do not set ints disable */ \
> +    "ldr   r4, [r2, %[dbgdscr]]\n"                /* Get the DBGDSCR */ \
> +    "str   r4, [r2, %[dbgdscr]]\n"                /* Set the DBGDSCR */ \
> +    "1:\n"                                                              \
> +    "2:\n"                                                              \
> +    "ldm   r1!, {r4-r5}\n"                         /* load vr and cr */ \
> +    "str   r4, [r3, #4]!\n"   /* Store DBGBVR, pre-indexed, modified */ \
> +    "str   r5, [r2, #4]!\n"   /* Store DBGBCR, pre-indexed, modified */ \
> +    "sub   r0, r0, #1\n"                                /* one less? */ \
> +    "cmp   r0, #1\n"                                    /* all done? */ \
> +    "bne   2b\n"                                                        \
> +    "b     5f\n"                                                        \
> +    /* CP14 */                                                          \
> +    "3:\n"                                                              \
> +    "beq   4f\n"                 /* if false do not set ints disable */ \
> +    ARM_DGB_DISABLE_INTS                                                \
> +    "4:\n"                                                              \
> +    ARM_HW_BP_LOAD(0)                                                   \
> +    ARM_HW_BP_LOAD(1)                                                   \
> +    ARM_HW_BP_LOAD(2)                                                   \
> +    ARM_HW_BP_LOAD(3)                                                   \
> +    ARM_HW_BP_LOAD(4)                                                   \
> +    ARM_HW_BP_LOAD(5)                                                   \
> +    ARM_HW_BP_LOAD(6)                                                   \
> +    ARM_HW_BP_LOAD(7)                                                   \
> +    ARM_HW_BP_LOAD(8)                                                   \
> +    ARM_HW_BP_LOAD(9)                                                   \
> +    ARM_HW_BP_LOAD(10)                                                  \
> +    ARM_HW_BP_LOAD(11)                                                  \
> +    ARM_HW_BP_LOAD(12)                                                  \
> +    ARM_HW_BP_LOAD(13)                                                  \
> +    ARM_HW_BP_LOAD(14)                                                  \
> +    ARM_HW_BP_LOAD(15)                                                  \
> +    "5:\n"                                                              \
> +     ARM_SYNC_INST                                                      \
> +    : [disints] "X" (debug_disable_ints),  /* make the sym available */ \
> +      [dbgdscr] "i" (ARM_MMAP_DBGDSCR * sizeof(uint32_t)),              \
> +    : "cc", "r0", "r1", "r2", "r3", "r4", "r5", "memory")
>  #define EXCEPTION_EXIT_EXC()                                            \
>    __asm__ volatile(                                                     \
> -    ASM_ARM_MODE                                                        \
> -    "add  sp, #4\n"                                                     \
>      "ldm  sp, {r0-r12}\n"            /* restore the thread's context */ \
>      "add  sp, %[frame_size]\n"                     /* free the frame */ \
>      "subs pc, lr, #0\n"                       /* return from the exc */ \
> +    ARM_SYNC_INST                                                       \
> -    : "memory")
> +    : "cc", "memory")
> +#define ARM_PUSH_LR()                                                   \
> +    "push {lr}\n"                                                       \
> +#define ARM_POP_LR()                                                    \
> +    "pop {lr}\n"                                                        \
> + * Entry and exit stacks
> +#define EXCEPTION_ENTRY(_frame)                   \
> +  EXCEPTION_ENTRY_EXC();                          \
> +  EXCEPTION_ENTRY_DEBUGGER();                     \
> +  EXCEPTION_ENTRY_THREAD(_frame);                 \
> +  ARM_THUMB_MODE()                                \
> +  ARM_PUSH_LR()
> +#define EXCEPTION_EXIT(_frame)                    \
> +  ARM_POP_LR();                                   \
> +  ARM_ARM_MODE();                                 \
> +  EXCEPTION_EXIT_THREAD(_frame);                  \
> +  EXCEPTION_EXIT_DEBUGGER();                      \
> +  EXCEPTION_EXIT_EXC()
>   * This is used to catch faulting accesses.
> @@ -1596,9 +1824,10 @@ static void __attribute__((naked))
>  arm_debug_unlock_abort(void)
> -  ARM_SWITCH_REG;
> +  ARM_SWITCH_REGISTERS;
>    EXCEPTION_ENTRY_THREAD(frame);
> +  ARM_SWITCH_BACK;
>    longjmp(unlock_abort_jmpbuf, -1);
>  #endif
> @@ -1608,16 +1837,10 @@ target_exception_undefined_instruction(void)
>    ARM_SWITCH_REG;
> -  EXCEPTION_ENTRY_EXC();
> -  arm_debug_break_unload();
> -  arm_debug_enable_interrupts();
> -  EXCEPTION_ENTRY_THREAD(frame);
> +  EXCEPTION_ENTRY(frame);
>    frame->vector = 1;
>    target_exception(frame);
> -  EXCEPTION_EXIT_THREAD(frame);
> -  arm_debug_commit_interrupt_disable();
> -  arm_debug_break_load();
> -  EXCEPTION_EXIT_EXC();
> +  EXCEPTION_EXIT(frame);
> @@ -1631,16 +1854,10 @@ target_exception_supervisor_call(void)
>     * this exception is used by the BKPT instruction in the prefetch abort
>     * handler to signal a TRAP.
>    frame->vector = 2;
> @@ -1648,16 +1865,10 @@ target_exception_prefetch_abort(void)
>    ARM_SWITCH_REG;
>    frame->vector = 3;
> @@ -1665,16 +1876,10 @@ target_exception_data_abort(void)
>    ARM_SWITCH_REG;
>    frame->vector = 4;
>  #if ARM_CP15
> @@ -1776,13 +1981,13 @@ int
>  rtems_debugger_target_enable(void)
> -  debug_session_active = true;
> +  arm_debug_break_clear_all();
>    rtems_debugger_target_set_mmu();
>    rtems_debugger_target_set_vectors();
> +  debug_session_active = true;
>    return 0;
> @@ -1795,8 +2000,9 @@ rtems_debugger_target_disable(void)
>    void*                        text_end;
>  #endif
> +  debug_disable_ints = 0;
>    debug_session_active = false;
>  #if DOES_NOT_WORK
>    text_begin = &bsp_section_text_begin[0];
> @@ -1979,57 +2185,13 @@
> rtems_debugger_target_thread_stepping(rtems_debugger_thread* thread)
>       * 0. This is reserved for single stepping.
>      CPU_Exception_frame* frame = thread->frame;
> -    target_printk("[} stepping: %s\n", bp->enabled ? "yes" : "no");
> +    target_printk("[} stepping: hbp[0] enabled: %s\n", ARM_HWB_ENALBED(0)
> ? "yes" : "no");
> -    if (!bp->enabled) {
> +    if (!ARM_HWB_ENALBED(0)) {
>        const uint32_t addr = (intptr_t) frame->register_pc;
>        const bool     thumb = (FRAME_SR(frame) & (1 << 5)) != 0 ? true :
> false;
> -      uint32_t       bas;
> -      bp->enabled = true;
> -      bp->address = frame->register_pc;
> -      bp->frame = frame;
> -      bp->length = sizeof(uint32_t);
> -      if (thumb) {
> -        uint16_t instr = *((uint16_t*) frame->register_pc);
> -        switch (instr & 0xf800) {
> -        case 0xe800:
> -        case 0xf000:
> -        case 0xf800:
> -          break;
> -        default:
> -          bp->length = sizeof(uint16_t);
> -          break;
> -       * See table C3-2 Effect of byte address selection on Breakpoint
> -       * generation and "Instruction address comparision programming
> -       * examples.
> -      if (thumb) {
> -        if ((addr & (1 << 1)) == 0) {
> -          bas = 0x3; /* b0011 */
> -        else {
> -          bas = 0xc; /* b1100 */
> -      else {
> -        bas = 0xf; /* b1111 */
> -      arm_debug_break_setup(bp,
> -                            addr & ~0x3,
> -                            ARM_HW_BP_UNLINKED_INSTR_MISMATCH,
> -                            bas,
> -                            ARM_HW_BP_PRIV_PL0_SUP_SYS);
> +      arm_debug_break_exec_enable(0, addr, thumb, true);
>        arm_debug_disable_interrupts();
> @@ -2085,6 +2247,7 @@ rtems_debugger_target_hwbreak_insert(void)
>  int
>  rtems_debugger_target_hwbreak_remove(void)
> +  target_printk("[} hbreak: remove: unload\n");
>    return 0;
> @@ -2095,15 +2258,34 @@
> rtems_debugger_target_hwbreak_control(rtems_debugger_target_watchpoint wp,
>                                        DB_UINT
> addr,
>                                        DB_UINT
> kind)
> -   * To do.
> +  int                          i;
> +  if (wp != rtems_debugger_target_hw_execute) {
> +    errno = EIO;
> +    return -1;
> +  for (i = 1; i < hw_breakpoints; ++i) {
> +    if (insert && !ARM_HWB_ENALBED(i)) {
> +      arm_debug_break_exec_enable(i, addr, kind == 1, false);
> +      break;
> +    } else if (!insert && ARM_HWB_ENALBED(i) && ARM_HWB_VCR(i) == (addr &
> ~3)) {
> +      arm_debug_break_clear(i);
> +      break;
> +  if (!insert && i == hw_breakpoints) {
> +    errno = EIO;
> +    return -1;
>    return 0;
>  int
>  rtems_debugger_target_cache_sync(rtems_debugger_target_swbreak* swbreak)
> +  target_printk("[} cache: sync: %p\n", swbreak->address);
>     * Flush the data cache and invalidate the instruction cache.
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221027/d1a3600a/attachment-0001.htm>
