Ping on ticket 4728 + patch
Alan Cudmore alan.cudmore at gmail.com
Fri Oct 28 19:34:41 UTC 2022
On Fri, Oct 28, 2022 at 8:07 AM Sebastian Huber
> On 22/10/2022 17:36, Alan Cudmore wrote:
> > On Thu, Oct 20, 2022 at 11:23 PM Alan Cudmore<alan.cudmore at gmail.com>  wrote:
> >> On Thu, Oct 20, 2022 at 2:13 AM Sebastian Huber
> >>> On 20/10/2022 03:48, Alan Cudmore wrote:
> >>>> On Wed, Oct 19, 2022 at 12:24 AM Sebastian Huber
> >>>>> On 18/10/2022 21:02, Alan Cudmore wrote:
> >>>>>> *From: *Sebastian Huber<mailto:sebastian.huber at embedded-brains.de>
> >>>>>> *Sent: *Tuesday, October 18, 2022 11:15 AM
> >>>>>> *To: *Alan Cudmore<mailto:alan.cudmore at gmail.com>;joel at rtems.org
> >>>>>> <mailto:joel at rtems.org>
> >>>>>> *Cc: *rtems-devel at rtems.org<mailto:devel at rtems.org>
> >>>>>> *Subject: *Re: Ping on ticket 4728 + patch
> >>>>>> On 18/10/2022 16:36, Alan Cudmore wrote:
> >>>>>>    > On Tue, Oct 18, 2022 at 9:55 AM Joel Sherrill<joel at rtems.org>   wrote:
> >>>>>>    >> On Tue, Oct 18, 2022 at 8:44 AM Alan
> >>>>>>    >>> The log does have the error, and I get it when building by hand too:
> >>>>>>    >>> start.o: in function `.L0 ':
> >>>>>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x5c):
> >>>>>>    >>> relocation truncated to fit: R_RISCV_GPREL_I against symbol
> >>>>>>    >>> `bsp_section_bss_size' defined in*ABS*  section in
> >>>>>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/rv32imafdc/testsuites/samples/minimum.exe
> >>>>>>    >>> collect2: error: ld returned 1 exit status
> >>>>>>    >> Hmmm.. that's weird. You should never get a truncation error linking
> >>>>>> minimum.exe.
> >>>>>>    >> It should always fit within the BSP's memory and not have any issues
> >>>>>> with branches
> >>>>>>    >> or calls needing fixup.
> >>>>>>    >> Unless the wrong type of branch/jump/call instruction is used at
> >>>>>> start.S:86, I have
> >>>>>>    >> no idea.If it's a form that assumes a short distance to the
> >>>>>> destination but is going
> >>>>>>    >> to a symbol outside start.S and thus could be further.
> >>>>>>    > Also, 6 of the samples such as hello.exe link without error.
> >>>>>>    > The rv32imafdc BSP variant does not have CPU_CFLAGS.
> >>>>>>    > rv32imafd links fine and has specific CPU_CFLAGS, rv32imafdc does not
> >>>>>>    > have the flags.
> >>>>>>    > (I'll research the gcc defaults and architecture differences next..)
> >>>>>>    > I get a similar error on the frdme310arty BSP but only on a specific
> >>>>>>    > POSIX testsuite executable:
> >>>>>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/../../../bsps/riscv/shared/start/start.S:86:(.bsp_start_text+0x28):
> >>>>>> /home/alan/rtems/test-build/rtems-tmp/build/riscv/frdme310arty/testsuites/validation/ts-validation-io-kernel.exe
> >>>>>> My off hand guess is that this is a tool chain issue on certain host
> >>>>>> systems. For example, I never got this error on our OpenSUSE machines.
> >>>>>> I can set up a OpenSUSE virtual machine and try it. I noticed the RSB
> >>>>>> documentation does not have a set of packages for OpenSUSE – I could
> >>>>>> send a docs patch after a successful build. What release do you use? Do
> >>>>>> you have a list of packages to install?
> >>>>> We use openSUSE Leap 15.3 and 15.4. To get the packages maybe try this:
> >>>>> zypper in -t pattern devel_C_C++ devel_python3
> >>>> I was able to set up an openSUSE Leap 15.4 (64 bit) VM and the above
> >>>> packages worked for the RSB build.
> >>>> Unfortunately, I still get the same link error for minimum.exe. Do you
> >>>> think this is a linker error? Is it worth trying a Clang build?
> >>> I am not really sure what it its, since I never got this error on one of
> >>> our machines.
> >>> What happens if you compile the attached files with:
> >>> riscv-rtems6-gcc start.S abs.S -Wl,-gc-sections
> >> This produces a.out without error. I can post the symbols or objdump
> >> header info if that would help.
> >> For the minimum.exe failure, I can add:
> >> volatile int x = 0;
> >> to the Init function and the error goes away.
> >> I can also get the error to go away if I add RTEMS_POSIX_API=True to config.ini
> >> I suspect that what I am doing is adding just enough code or data to
> >> move the bss symbol close enough to the global pointer. I can try to
> >> compare the map for minimum.exe for both the original and modified
> >> version that does link. The original version will produce an
> >> executable if I use -Wl,--noinhibit-exec
> > I have been looking for similar errors, and there are some interesting
> > bug reports and discussions for GNU ld on RISC-V such as this:
> > https://mail.gnu.org/archive/html/bug-binutils/2021-03/msg00164.html
> > But that discussion is over a year old.
> > I can eliminate both cases of the error that I see by adding
> > -Wl,--no-relax to the linker, which inhibits the linker based code
> > size optimization that is possibly causing this. The downside is that
> > the code size increases. minimum.exe code grows from 290431 to 292369
> > bytes for the rv32imafdc bsp variant.
> > Based on the binutils discussion, maybe there have been adjustments to
> > the link scripts needed to account for recent fixes in ld?
> > Is there a "default" set of ld scripts for each architecture? If so, I
> > can compare those to the RTEMS RISC-V ldscripts.
> I had this issue now for the first time on one of my machines. I checked
> in the following workaround:
> https://git.rtems.org/rtems/commit/?id=89ba2a9838558841c4f38283e84b99173790d61c
Thanks, all of the riscv BSPs built without error on my ubuntu host. I
not build all of the riscv BSPs on my OpenSUSE VM, but I did verify
that the BSPs I had trouble with now build.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
