[PATCH rtems-lwip v2 1/7] lwip.py: Change arch and bsp check method
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Sep 6 18:41:59 UTC 2022
I'm not opposed to this change since it reduces repetition a bit, but
was there a particular reason for it beyond that?
Kinsey
On 9/6/2022 11:20, Duc Doan wrote:
> lwip.py | 30 +++++++++++++++++-------------
> 1 file changed, 17 insertions(+), 13 deletions(-)
> diff --git a/lwip.py b/lwip.py
> index 84eef2c..9db5348 100644
> --- a/lwip.py
> +++ b/lwip.py
> @@ -99,6 +99,8 @@ def build(bld):
> drv_incl = []
> arch_lib_path = rtems.arch_bsp_lib_path(bld.env.RTEMS_VERSION,
> bld.env.RTEMS_ARCH_BSP)
> + arch = rtems.arch(bld.env.RTEMS_ARCH_BSP)
> + bsp = rtems.bsp(bld.env.RTEMS_ARCH_BSP)
> with open('file-import.json', 'r') as cf:
> files = json.load(cf)
> for f in files['files-to-import']:
> @@ -118,27 +120,29 @@ def build(bld):
> sources.append(os.path.join(path, name))
> return sources
> - # These files will not compile for BSPs other than TMS570
> - if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-tms570ls3137_hdk'):
> - drv_incl.append('uLan/ports/driver/tms570_emac')
> - drv_incl.append('uLan/ports/os')
> - driver_source.extend(walk_sources('uLan/ports/driver/tms570_emac'))
> + if arch == 'arm':
> + # These files will not compile for BSPs other than TMS570
> + if bsp.startswith('tms570ls3137_hdk'):
> + drv_incl.append('uLan/ports/driver/tms570_emac')
> + drv_incl.append('uLan/ports/os')
> + driver_source.extend(walk_sources('uLan/ports/driver/tms570_emac'))
> + # These files will only compile for BeagleBone BSPs
> + if bsp.startswith('beaglebone'):
> + driver_source.extend(walk_sources('rtemslwip/beaglebone'))
> + drv_incl.append('rtemslwip/beaglebone')
> + drv_incl.append('cpsw/src/include')
> + driver_source.extend(walk_sources('cpsw/src'))
> - # These files will only compile for BeagleBone BSPs
> - if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-beaglebone'):
> - driver_source.extend(walk_sources('rtemslwip/beaglebone'))
> - drv_incl.append('rtemslwip/beaglebone')
> - drv_incl.append('cpsw/src/include')
> - driver_source.extend(walk_sources('cpsw/src'))
> # These files will only compile for BSPs on Xilinx hardware
> is_xilinx_bsp = False
> is_aarch64_bsp = False
> is_qemu = False
> - if bld.env.RTEMS_ARCH_BSP.startswith('aarch64-rtems6-xilinx_zynqmp'):
> + if arch == 'aarch64' and bsp.startswith('xilinx_zynqmp'):
> is_xilinx_bsp = True
> is_aarch64_bsp = True
> - if bld.env.RTEMS_ARCH_BSP.endswith('_qemu'):
> + if bsp.endswith('_qemu'):
> is_qemu = True
> if is_xilinx_bsp:
> drv_incl.extend(xilinx_drv_incl)
