[PATCH rtems-lwip v2 1/7] lwip.py: Change arch and bsp check method
Wed Sep 7 03:04:54 UTC 2022
On 7/9/2022 4:41 am, Kinsey Moore wrote:
> I'm not opposed to this change since it reduces repetition a bit, but
> was there a particular reason for it beyond that?
Yes there is. The arch/bsp checks ...
>> -    if bld.env.RTEMS_ARCH_BSP.startswith('arm-rtems6-tms570ls3137_hdk'):
... included the major version of RTEMS which breaks once we move to 7,
8 ....
And I have left `RTEMS_ARCH_BSP` in the environment but it is really an
internal working variable of rtems_waf.
>> -        drv_incl.append('uLan/ports/driver/tms570_emac')
>> -        drv_incl.append('uLan/ports/os')
>> driver_source.extend(walk_sources('uLan/ports/driver/tms570_emac'))
>> +    if arch == 'arm':
>> +        # These files will not compile for BSPs other than TMS570
>> +        if bsp.startswith('tms570ls3137_hdk'):
Duc, please make the check exact. A BSP name should be a one to match
and if you have to match more than one I suggest you use:
   if bsp in ['tms570ls3137_hdk', 'tms570ls3137_hdk.extra']:
