[PATCH] user: Document arm/fvp BSP
Sebastian Huber
Fri Sep 9 05:49:10 UTC 2022
Close #4202.
user/bsps/arm/fvp.rst | 39 +++++++++++++++++++++++++++++++++++++++
user/bsps/bsps-arm.rst | 1 +
2 files changed, 40 insertions(+)
create mode 100644 user/bsps/arm/fvp.rst
diff --git a/user/bsps/arm/fvp.rst b/user/bsps/arm/fvp.rst
new file mode 100644
index 0000000..a1e186a
--- /dev/null
+++ b/user/bsps/arm/fvp.rst
@@ -0,0 +1,39 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2022 embedded brains GmbH
+fvp (Fixed Virtual Platform)
+The BSP for the
+`Arm Fixed Virtual Platforms <https://developer.arm.com/Tools%20and%20Software/Fixed%20Virtual%20Platforms>`_
+offers one variant. You need a license from Arm to run the simulator. The
+`fvp_cortex_r52` variant supports a simulation of the Cortex-R52 processor.
+The BSP supports the SMP configuration.
+Run an Executable
+To run an executable on a single Cortex-R52 processor use:
+.. code-block:: none
+ FVP_BaseR_Cortex-R52x1 -C bp.vis.disable_visualisation=1 -a build/arm/fvp_cortex_r52/testsuites/samples/ticker.exe
+To run an executable on a four Cortex-R52 processors use:
+ FVP_BaseR_Cortex-R52x4 -C bp.vis.disable_visualisation=1 -a build/arm/fvp_cortex_r52/testsuites/samples/ticker.exe
+Clock Driver
+The clock driver uses the `ARMv7-AR Generic Timer`.
+Console Driver
+The console driver uses the
+`semihosting <https://developer.arm.com/documentation/dui0471/g/Semihosting/Semihosting-operations?lang=en>`_
+``SYS_READC`` and ``SYS_WRITEC`` system calls.
diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
index f1113e3..d9b5d01 100644
--- a/user/bsps/bsps-arm.rst
+++ b/user/bsps/bsps-arm.rst
@@ -14,6 +14,7 @@ arm (ARM)
arm/csb336.rst
arm/csb337.rst
arm/edb7312.rst
+ arm/fvp.rst
arm/gumstix.rst
arm/imx.rst
arm/imxrt.rst
2.35.3
