[PATCH] user: Document arm/fvp BSP
Chris Johns
chrisj at rtems.org
Fri Sep 9 05:50:03 UTC 2022
Ok to push
Thanks
On 9/9/2022 3:49 pm, Sebastian Huber wrote:
> Close #4202.
> user/bsps/arm/fvp.rst | 39 +++++++++++++++++++++++++++++++++++++++
> user/bsps/bsps-arm.rst | 1 +
> 2 files changed, 40 insertions(+)
> create mode 100644 user/bsps/arm/fvp.rst
> diff --git a/user/bsps/arm/fvp.rst b/user/bsps/arm/fvp.rst
> new file mode 100644
> index 0000000..a1e186a
> --- /dev/null
> +++ b/user/bsps/arm/fvp.rst
> @@ -0,0 +1,39 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2022 embedded brains GmbH
> +fvp (Fixed Virtual Platform)
> +The BSP for the
> +`Arm Fixed Virtual Platforms <https://developer.arm.com/Tools%20and%20Software/Fixed%20Virtual%20Platforms>`_
> +offers one variant. You need a license from Arm to run the simulator. The
> +`fvp_cortex_r52` variant supports a simulation of the Cortex-R52 processor.
> +The BSP supports the SMP configuration.
> +Run an Executable
> +To run an executable on a single Cortex-R52 processor use:
> +.. code-block:: none
> + FVP_BaseR_Cortex-R52x1 -C bp.vis.disable_visualisation=1 -a build/arm/fvp_cortex_r52/testsuites/samples/ticker.exe
> +To run an executable on a four Cortex-R52 processors use:
> + FVP_BaseR_Cortex-R52x4 -C bp.vis.disable_visualisation=1 -a build/arm/fvp_cortex_r52/testsuites/samples/ticker.exe
> +Clock Driver
> +The clock driver uses the `ARMv7-AR Generic Timer`.
> +Console Driver
> +The console driver uses the
> +`semihosting <https://developer.arm.com/documentation/dui0471/g/Semihosting/Semihosting-operations?lang=en>`_
> +``SYS_READC`` and ``SYS_WRITEC`` system calls.
> diff --git a/user/bsps/bsps-arm.rst b/user/bsps/bsps-arm.rst
> index f1113e3..d9b5d01 100644
> --- a/user/bsps/bsps-arm.rst
> +++ b/user/bsps/bsps-arm.rst
> @@ -14,6 +14,7 @@ arm (ARM)
> arm/csb336.rst
> arm/csb337.rst
> arm/edb7312.rst
> + arm/fvp.rst
> arm/gumstix.rst
> arm/imx.rst
> arm/imxrt.rst
