[PATCH] score: Prevent an out of bounds warning
Sebastian Huber
Fri Sep 9 06:05:41 UTC 2022
Update #4702.
cpukit/score/src/percpudata.c | 9 +++++++--
1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/src/percpudata.c b/cpukit/score/src/percpudata.c
index c81c1b6a16..6b31ef3602 100644
--- a/cpukit/score/src/percpudata.c
+++ b/cpukit/score/src/percpudata.c
@@ -66,14 +66,19 @@ static void _Per_CPU_Data_initialize( void )
size = RTEMS_LINKER_SET_SIZE( _Per_CPU_Data );
if ( size > 0 ) {
+ char *data_begin;
const Memory_Information *mem;
Per_CPU_Control *cpu;
uint32_t cpu_index;
uint32_t cpu_max;
+ /* Prevent an out of bounds warning in the memcpy() below */
+ data_begin = RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data );
+ RTEMS_OBFUSCATE_VARIABLE( data_begin );
mem = _Memory_Get();
cpu = _Per_CPU_Get_by_index( 0 );
- cpu->data = RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data );
+ cpu->data = data_begin;
cpu_max = rtems_configuration_get_maximum_processors();
@@ -85,7 +90,7 @@ static void _Per_CPU_Data_initialize( void )
_Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_PER_CPU_DATA );
- memcpy( cpu->data, RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ), size);
+ memcpy( cpu->data, data_begin, size);
2.35.3
