[PATCH rtems-lwip v3 1/7] lwip.py: Change arch and bsp check method
Chris Johns
chrisj at rtems.org
Fri Sep 9 06:46:00 UTC 2022
On 9/9/2022 2:52 am, Kinsey Moore wrote:
> At some point, the lwIP build needs to get better about managing which BSPs it
> supports, but that's not a task for you here and now.
I think this is needed. Can lwip be built generically for a BSP that is not
specific covered in a list?
I ask because lwip has been added to the RSB 6/rtems-packages and I could not
build the erc32 BSP stack because lwip had an error.
I am fine with lwip being in ?/rtems-packages if it can be built for every bsp
at some generic level.
