[PATCH rtems-lwip v3 1/7] lwip.py: Change arch and bsp check method
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Sep 9 13:16:36 UTC 2022
On 9/9/2022 01:46, Chris Johns wrote:
> On 9/9/2022 2:52 am, Kinsey Moore wrote:
>> At some point, the lwIP build needs to get better about managing which BSPs it
>> supports, but that's not a task for you here and now.
> I think this is needed. Can lwip be built generically for a BSP that is not
> specific covered in a list?
lwIP is not currently buildable for BSPs that have not been explicitly
added to the build. The first step would be a mostly-unified lwipopts
that provides defaults that are overridable by BSP-specific or possibly
user-provided configuration. The only reason I see to allow this is if
we want to let users bring their own lwIP drivers without incorporating
them into the rtems-lwip integration repository.
> I ask because lwip has been added to the RSB 6/rtems-packages and I could not
> build the erc32 BSP stack because lwip had an error.
> I am fine with lwip being in ?/rtems-packages if it can be built for every bsp
> at some generic level.
I'll look into better management of BSP-specific configuration and
making a generic build available for BSPs that don't have a particular
configuration available.
Kinsey
