[PATCH rtems-lwip v4 7/7] stm32: Convert to Unix line endings
Duc Doan dtbpkmte at gmail.com
Fri Sep 9 23:13:16 UTC 2022
This patch converts all files imported from ST to Unix line endings
using dos2unix.
 rtemslwip/stm32f4/lwipopts.h |  294 ++---
 stm32/driver/dp83848.c       | 1328 +++++++++++------------
 stm32/driver/dp83848.h       |  872 +++++++--------
 stm32/ethernetif.c           | 1972 +++++++++++++++++-----------------
 stm32/ethernetif.h           |  108 +-
 5 files changed, 2287 insertions(+), 2287 deletions(-)
diff --git a/rtemslwip/stm32f4/lwipopts.h b/rtemslwip/stm32f4/lwipopts.h
index aa6b95b..eec98c7 100644
--- a/rtemslwip/stm32f4/lwipopts.h
+++ b/rtemslwip/stm32f4/lwipopts.h
@@ -1,147 +1,147 @@
-/* USER CODE BEGIN Header */
-  * File Name          : Target/lwipopts.h
-  * Description        : This file overrides LwIP stack default configuration
-  *                      done in opt.h file.
-  * @attention
-  * Copyright (c) 2022 STMicroelectronics.
-  * All rights reserved.
-  * This software is licensed under terms that can be found in the LICENSE file
-  * in the root directory of this software component.
-  * If no LICENSE file comes with this software, it is provided AS-IS.
-/* USER CODE END Header */
-/* Define to prevent recursive inclusion --------------------------------------*/
-#ifndef __LWIPOPTS__H__
-#define __LWIPOPTS__H__
-/* Current version of LwIP supported by CubeMx: 2.1.2 -*/
-/* Within 'USER CODE' section, code will be kept by default at each generation */
-/* USER CODE BEGIN 0 */
-#include <stm32f4xx_hal.h>
-/* USER CODE END 0 */
-#ifdef __cplusplus
- extern "C" {
-#endif
-/* STM32CubeMX Specific Parameters (not defined in opt.h) ---------------------*/
-/* Parameters set in STM32CubeMX LwIP Configuration GUI -*/
-/*----- WITH_RTOS disabled (Since FREERTOS is not set) -----*/
-#define WITH_RTOS 1
-/*----- CHECKSUM_BY_HARDWARE disabled -----*/
-#define CHECKSUM_BY_HARDWARE 0
-/* LwIP Stack Parameters (modified compared to initialization value in opt.h) -*/
-/*----- Default value in ETH configuration GUI in CubeMx: 1524 -----*/
-#define ETH_RX_BUFFER_SIZE 1536
-/*----- Value in opt.h for NO_SYS: 0 -----*/
-#define NO_SYS 0
-/*----- Value in opt.h for SYS_LIGHTWEIGHT_PROT: 1 -----*/
-#define SYS_LIGHTWEIGHT_PROT 1
-/*----- Value in opt.h for MEM_ALIGNMENT: 1 -----*/
-#define MEM_ALIGNMENT 4
-/*----- Default Value for H7 devices: 0x30044000 -----*/
-//#define LWIP_RAM_HEAP_POINTER 0x20017f58
-/*----- Value supported for H7 devices: 1 -----*/
-#define LWIP_SUPPORT_CUSTOM_PBUF 1
-/*----- Value in opt.h for LWIP_ETHERNET: LWIP_ARP || PPPOE_SUPPORT -*/
-#define LWIP_ETHERNET 1
-/*----- Value in opt.h for LWIP_DNS_SECURE: (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) -*/
-#define LWIP_DNS_SECURE 7
-/*----- Value in opt.h for TCP_SND_QUEUELEN: (4*TCP_SND_BUF + (TCP_MSS - 1))/TCP_MSS -----*/
-#define TCP_SND_QUEUELEN 9
-/*----- Value in opt.h for TCP_SNDLOWAT: LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) -*/
-#define TCP_SNDLOWAT 1071
-/*----- Value in opt.h for TCP_SNDQUEUELOWAT: LWIP_MAX(TCP_SND_QUEUELEN)/2, 5) -*/
-#define TCP_SNDQUEUELOWAT 5
-/*----- Value in opt.h for TCP_WND_UPDATE_THRESHOLD: LWIP_MIN(TCP_WND/4, TCP_MSS*4) -----*/
-#define TCP_WND_UPDATE_THRESHOLD 536
-/*----- Value in opt.h for LWIP_NETIF_LINK_CALLBACK: 0 -----*/
-//#define LWIP_NETIF_LINK_CALLBACK 0
-/*----- Value in opt.h for LWIP_NETCONN: 1 -----*/
-#define LWIP_NETCONN 1
-/*----- Value in opt.h for LWIP_SOCKET: 1 -----*/
-#define LWIP_SOCKET 1
-/*----- Value in opt.h for RECV_BUFSIZE_DEFAULT: INT_MAX -----*/
-//#define RECV_BUFSIZE_DEFAULT 2000000000
-/*----- Value in opt.h for LWIP_STATS: 1 -----*/
-#define LWIP_STATS 0
-/*----- Value in opt.h for CHECKSUM_GEN_IP: 1 -----*/
-#define CHECKSUM_GEN_IP 0
-/*----- Value in opt.h for CHECKSUM_GEN_UDP: 1 -----*/
-#define CHECKSUM_GEN_UDP 0
-/*----- Value in opt.h for CHECKSUM_GEN_TCP: 1 -----*/
-#define CHECKSUM_GEN_TCP 0
-/*----- Value in opt.h for CHECKSUM_GEN_ICMP: 1 -----*/
-#define CHECKSUM_GEN_ICMP 0
-/*----- Value in opt.h for CHECKSUM_GEN_ICMP6: 1 -----*/
-#define CHECKSUM_GEN_ICMP6 0
-/*----- Value in opt.h for CHECKSUM_CHECK_IP: 1 -----*/
-#define CHECKSUM_CHECK_IP 0
-/*----- Value in opt.h for CHECKSUM_CHECK_UDP: 1 -----*/
-#define CHECKSUM_CHECK_UDP 0
-/*----- Value in opt.h for CHECKSUM_CHECK_TCP: 1 -----*/
-#define CHECKSUM_CHECK_TCP 0
-/*----- Value in opt.h for CHECKSUM_CHECK_ICMP: 1 -----*/
-#define CHECKSUM_CHECK_ICMP 0
-/*----- Value in opt.h for CHECKSUM_CHECK_ICMP6: 1 -----*/
-#define CHECKSUM_CHECK_ICMP6 0
-/*----- Default Value for ETHARP_DEBUG: LWIP_DBG_OFF ---*/
-/* USER CODE BEGIN 1 */
-//#define LWIP_DEBUG 1
-#define LWIP_ARP 1
-#define LWIP_NETIF_API 1
-#define NO_SYS_NO_TIMERS 0
-#define IP_REASSEMBLY                   0
-#define IP_FRAG                         0
-#define LWIP_IPV4                       1
-#define LWIP_IPV6                       1
-#define LWIP_TCPIP_CORE_LOCKING         1
-#define TCPIP_THREAD_STACKSIZE 1024
-#define TCPIP_THREAD_PRIO 24
-#define TCPIP_MBOX_SIZE 6
-#define SLIPIF_THREAD_STACKSIZE 1024
-#define SLIPIF_THREAD_PRIO 3
-#define DEFAULT_THREAD_STACKSIZE 1024
-#define DEFAULT_THREAD_PRIO 3
-#define DEFAULT_UDP_RECVMBOX_SIZE 6
-#define DEFAULT_TCP_RECVMBOX_SIZE 6
-#define DEFAULT_ACCEPTMBOX_SIZE 6
-#define LWIP_DHCP                       1
-#define DHCP_DOES_ARP_CHECK             1
-#define LWIP_DNS                        1
-#define LWIP_AUTOIP                     1
-#define LWIP_DHCP_AUTOIP_COOP           ((LWIP_DHCP) && (LWIP_AUTOIP))
-#define LWIP_TIMEVAL_PRIVATE 0
-#define LWIP_COMPAT_SOCKETS 1
-#define LWIP_RAW 0
-#define SO_REUSE 1
-/* USER CODE END 1 */
-#ifdef __cplusplus
-#endif
-#endif /*__LWIPOPTS__H__ */
+/* USER CODE BEGIN Header */
+  * File Name          : Target/lwipopts.h
+  * Description        : This file overrides LwIP stack default configuration
+  *                      done in opt.h file.
+  * @attention
+  * Copyright (c) 2022 STMicroelectronics.
+  * All rights reserved.
+  * This software is licensed under terms that can be found in the LICENSE file
+  * in the root directory of this software component.
+  * If no LICENSE file comes with this software, it is provided AS-IS.
+/* USER CODE END Header */
+/* Define to prevent recursive inclusion --------------------------------------*/
+#ifndef __LWIPOPTS__H__
+#define __LWIPOPTS__H__
+/* Current version of LwIP supported by CubeMx: 2.1.2 -*/
+/* Within 'USER CODE' section, code will be kept by default at each generation */
+/* USER CODE BEGIN 0 */
+#include <stm32f4xx_hal.h>
+/* USER CODE END 0 */
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* STM32CubeMX Specific Parameters (not defined in opt.h) ---------------------*/
+/* Parameters set in STM32CubeMX LwIP Configuration GUI -*/
+/*----- WITH_RTOS disabled (Since FREERTOS is not set) -----*/
+#define WITH_RTOS 1
+/*----- CHECKSUM_BY_HARDWARE disabled -----*/
+#define CHECKSUM_BY_HARDWARE 0
+/* LwIP Stack Parameters (modified compared to initialization value in opt.h) -*/
+/*----- Default value in ETH configuration GUI in CubeMx: 1524 -----*/
+#define ETH_RX_BUFFER_SIZE 1536
+/*----- Value in opt.h for NO_SYS: 0 -----*/
+#define NO_SYS 0
+/*----- Value in opt.h for SYS_LIGHTWEIGHT_PROT: 1 -----*/
+#define SYS_LIGHTWEIGHT_PROT 1
+/*----- Value in opt.h for MEM_ALIGNMENT: 1 -----*/
+#define MEM_ALIGNMENT 4
+/*----- Default Value for H7 devices: 0x30044000 -----*/
+//#define LWIP_RAM_HEAP_POINTER 0x20017f58
+/*----- Value supported for H7 devices: 1 -----*/
+#define LWIP_SUPPORT_CUSTOM_PBUF 1
+/*----- Value in opt.h for LWIP_ETHERNET: LWIP_ARP || PPPOE_SUPPORT -*/
+#define LWIP_ETHERNET 1
+/*----- Value in opt.h for LWIP_DNS_SECURE: (LWIP_DNS_SECURE_RAND_XID | LWIP_DNS_SECURE_NO_MULTIPLE_OUTSTANDING | LWIP_DNS_SECURE_RAND_SRC_PORT) -*/
+#define LWIP_DNS_SECURE 7
+/*----- Value in opt.h for TCP_SND_QUEUELEN: (4*TCP_SND_BUF + (TCP_MSS - 1))/TCP_MSS -----*/
+#define TCP_SND_QUEUELEN 9
+/*----- Value in opt.h for TCP_SNDLOWAT: LWIP_MIN(LWIP_MAX(((TCP_SND_BUF)/2), (2 * TCP_MSS) + 1), (TCP_SND_BUF) - 1) -*/
+#define TCP_SNDLOWAT 1071
+/*----- Value in opt.h for TCP_SNDQUEUELOWAT: LWIP_MAX(TCP_SND_QUEUELEN)/2, 5) -*/
+#define TCP_SNDQUEUELOWAT 5
+/*----- Value in opt.h for TCP_WND_UPDATE_THRESHOLD: LWIP_MIN(TCP_WND/4, TCP_MSS*4) -----*/
+#define TCP_WND_UPDATE_THRESHOLD 536
+/*----- Value in opt.h for LWIP_NETIF_LINK_CALLBACK: 0 -----*/
+//#define LWIP_NETIF_LINK_CALLBACK 0
+/*----- Value in opt.h for LWIP_NETCONN: 1 -----*/
+#define LWIP_NETCONN 1
+/*----- Value in opt.h for LWIP_SOCKET: 1 -----*/
+#define LWIP_SOCKET 1
+/*----- Value in opt.h for RECV_BUFSIZE_DEFAULT: INT_MAX -----*/
+//#define RECV_BUFSIZE_DEFAULT 2000000000
+/*----- Value in opt.h for LWIP_STATS: 1 -----*/
+#define LWIP_STATS 0
+/*----- Value in opt.h for CHECKSUM_GEN_IP: 1 -----*/
+#define CHECKSUM_GEN_IP 0
+/*----- Value in opt.h for CHECKSUM_GEN_UDP: 1 -----*/
+#define CHECKSUM_GEN_UDP 0
+/*----- Value in opt.h for CHECKSUM_GEN_TCP: 1 -----*/
+#define CHECKSUM_GEN_TCP 0
+/*----- Value in opt.h for CHECKSUM_GEN_ICMP: 1 -----*/
+#define CHECKSUM_GEN_ICMP 0
+/*----- Value in opt.h for CHECKSUM_GEN_ICMP6: 1 -----*/
+#define CHECKSUM_GEN_ICMP6 0
+/*----- Value in opt.h for CHECKSUM_CHECK_IP: 1 -----*/
+#define CHECKSUM_CHECK_IP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_UDP: 1 -----*/
+#define CHECKSUM_CHECK_UDP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_TCP: 1 -----*/
+#define CHECKSUM_CHECK_TCP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_ICMP: 1 -----*/
+#define CHECKSUM_CHECK_ICMP 0
+/*----- Value in opt.h for CHECKSUM_CHECK_ICMP6: 1 -----*/
+#define CHECKSUM_CHECK_ICMP6 0
+/*----- Default Value for ETHARP_DEBUG: LWIP_DBG_OFF ---*/
+/* USER CODE BEGIN 1 */
+//#define LWIP_DEBUG 1
+#define LWIP_ARP 1
+#define LWIP_NETIF_API 1
+#define NO_SYS_NO_TIMERS 0
+#define IP_REASSEMBLY                   0
+#define IP_FRAG                         0
+#define LWIP_IPV4                       1
+#define LWIP_IPV6                       1
+#define LWIP_TCPIP_CORE_LOCKING         1
+#define TCPIP_THREAD_STACKSIZE 1024
+#define TCPIP_THREAD_PRIO 24
+#define TCPIP_MBOX_SIZE 6
+#define SLIPIF_THREAD_STACKSIZE 1024
+#define SLIPIF_THREAD_PRIO 3
+#define DEFAULT_THREAD_STACKSIZE 1024
+#define DEFAULT_THREAD_PRIO 3
+#define DEFAULT_UDP_RECVMBOX_SIZE 6
+#define DEFAULT_TCP_RECVMBOX_SIZE 6
+#define DEFAULT_ACCEPTMBOX_SIZE 6
+#define LWIP_DHCP                       1
+#define DHCP_DOES_ARP_CHECK             1
+#define LWIP_DNS                        1
+#define LWIP_AUTOIP                     1
+#define LWIP_DHCP_AUTOIP_COOP           ((LWIP_DHCP) && (LWIP_AUTOIP))
+#define LWIP_TIMEVAL_PRIVATE 0
+#define LWIP_COMPAT_SOCKETS 1
+#define LWIP_RAW 0
+#define SO_REUSE 1
+/* USER CODE END 1 */
+#ifdef __cplusplus
+#endif
+#endif /*__LWIPOPTS__H__ */
diff --git a/stm32/driver/dp83848.c b/stm32/driver/dp83848.c
index 2c5d59b..b1d3150 100644
--- a/stm32/driver/dp83848.c
+++ b/stm32/driver/dp83848.c
@@ -1,664 +1,664 @@
-  * @file    dp83848.c
-  * @author  MCD Application Team
-  * @brief   This file provides a set of functions needed to manage the DP83848
-  *          PHY devices.
-  * @attention
-  * <h2><center>© Copyright (c) 2021 STMicroelectronics.
-  * All rights reserved.</center></h2>
-  * This software component is licensed by ST under BSD 3-Clause license,
-  * the "License"; You may not use this file except in compliance with the
-  * License. You may obtain a copy of the License at:
-  *                        opensource.org/licenses/BSD-3-Clause
-/* Includes ------------------------------------------------------------------*/
-#include "dp83848.h"
-/** @addtogroup BSP
-/** @addtogroup Component
-/** @defgroup DP83848 DP83848
-/* Private typedef -----------------------------------------------------------*/
-/* Private define ------------------------------------------------------------*/
-/** @defgroup DP83848_Private_Defines DP83848 Private Defines
-#define DP83848_SW_RESET_TO    ((uint32_t)500U)
-#define DP83848_INIT_TO        ((uint32_t)2000U)
-#define DP83848_MAX_DEV_ADDR   ((uint32_t)31U)
-/* Private macro -------------------------------------------------------------*/
-/* Private variables ---------------------------------------------------------*/
-/* Private function prototypes -----------------------------------------------*/
-/* Private functions ---------------------------------------------------------*/
-/** @defgroup DP83848_Private_Functions DP83848 Private Functions
-  * @brief  Register IO functions to component object
-  * @param  pObj: device object  of DP83848_Object_t.
-  * @param  ioctx: holds device IO functions.
-  * @retval DP83848_STATUS_OK  if OK
-  *         DP83848_STATUS_ERROR if missing mandatory function
-int32_t  DP83848_RegisterBusIO(dp83848_Object_t *pObj, dp83848_IOCtx_t *ioctx)
-  if(!pObj || !ioctx->ReadReg || !ioctx->WriteReg || !ioctx->GetTick)
-    return DP83848_STATUS_ERROR;
-  pObj->IO.Init = ioctx->Init;
-  pObj->IO.DeInit = ioctx->DeInit;
-  pObj->IO.ReadReg = ioctx->ReadReg;
-  pObj->IO.WriteReg = ioctx->WriteReg;
-  pObj->IO.GetTick = ioctx->GetTick;
-  return DP83848_STATUS_OK;
-  * @brief  Initialize the DP83848 and configure the needed hardware resources
-  * @param  pObj: device object DP83848_Object_t.
-  *         DP83848_STATUS_ADDRESS_ERROR if cannot find device address
-  *         DP83848_STATUS_READ_ERROR if connot read register
-  *         DP83848_STATUS_WRITE_ERROR if connot write to register
-  *         DP83848_STATUS_RESET_TIMEOUT if cannot perform a software reset
- int32_t DP83848_Init(dp83848_Object_t *pObj)
-   uint32_t tickstart = 0, regvalue = 0, addr = 0;
-   int32_t status = DP83848_STATUS_OK;
-   if(pObj->Is_Initialized == 0)
-     if(pObj->IO.Init != 0)
-       /* GPIO and Clocks initialization */
-       pObj->IO.Init();
-     /* for later check */
-     pObj->DevAddr = DP83848_MAX_DEV_ADDR + 1;
-     /* Get the device address from special mode register */
-     for(addr = 0; addr <= DP83848_MAX_DEV_ADDR; addr ++)
-       if(pObj->IO.ReadReg(addr, DP83848_SMR, &regvalue) < 0)
-         status = DP83848_STATUS_READ_ERROR;
-         /* Can't read from this device address
-            continue with next address */
-         continue;
-       if((regvalue & DP83848_SMR_PHY_ADDR) == addr)
-         pObj->DevAddr = addr;
-         status = DP83848_STATUS_OK;
-         break;
-     if(pObj->DevAddr > DP83848_MAX_DEV_ADDR)
-       status = DP83848_STATUS_ADDRESS_ERROR;
-     /* if device address is matched */
-     if(status == DP83848_STATUS_OK)
-       /* set a software reset  */
-       if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_BCR, DP83848_BCR_SOFT_RESET) >= 0)
-         /* get software reset status */
-         if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &regvalue) >= 0)
-           tickstart = pObj->IO.GetTick();
-           /* wait until software reset is done or timeout occured  */
-           while(regvalue & DP83848_BCR_SOFT_RESET)
-             if((pObj->IO.GetTick() - tickstart) <= DP83848_SW_RESET_TO)
-               if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &regvalue) < 0)
-                 break;
-             else
-               status = DP83848_STATUS_RESET_TIMEOUT;
-               break;
-         else
-       else
-         status = DP83848_STATUS_WRITE_ERROR;
-     /* Wait for 2s to perform initialization */
-     while((pObj->IO.GetTick() - tickstart) <= DP83848_INIT_TO)
-     pObj->Is_Initialized = 1;
-   return status;
-  * @brief  De-Initialize the dp83848 and it's hardware resources
-  * @retval None
-int32_t DP83848_DeInit(dp83848_Object_t *pObj)
-  if(pObj->Is_Initialized)
-    if(pObj->IO.DeInit != 0)
-      if(pObj->IO.DeInit() < 0)
-    pObj->Is_Initialized = 0;
-  * @brief  Disable the DP83848 power down mode.
-int32_t DP83848_DisablePowerDownMode(dp83848_Object_t *pObj)
-  uint32_t readval = 0;
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &readval) >= 0)
-    readval &= ~DP83848_BCR_POWER_DOWN;
-    /* Apply configuration */
-    if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_BCR, readval) < 0)
-  else
-  return status;
-  * @brief  Enable the DP83848 power down mode.
-int32_t DP83848_EnablePowerDownMode(dp83848_Object_t *pObj)
-    readval |= DP83848_BCR_POWER_DOWN;
-  else
-  return status;
-  * @brief  Start the auto negotiation process.
-int32_t DP83848_StartAutoNego(dp83848_Object_t *pObj)
-    readval |= DP83848_BCR_AUTONEGO_EN;
-  else
-  return status;
-  * @brief  Get the link state of DP83848 device.
-  * @param  pObj: Pointer to device object.
-  * @param  pLinkState: Pointer to link state
-  * @retval DP83848_STATUS_LINK_DOWN  if link is down
-  *         DP83848_STATUS_AUTONEGO_NOTDONE if Auto nego not completed
-  *         DP83848_STATUS_100MBITS_FULLDUPLEX if 100Mb/s FD
-  *         DP83848_STATUS_100MBITS_HALFDUPLEX if 100Mb/s HD
-  *         DP83848_STATUS_10MBITS_FULLDUPLEX  if 10Mb/s FD
-  *         DP83848_STATUS_10MBITS_HALFDUPLEX  if 10Mb/s HD
-int32_t DP83848_GetLinkState(dp83848_Object_t *pObj)
-  /* Read Status register  */
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BSR, &readval) < 0)
-    return DP83848_STATUS_READ_ERROR;
-  /* Read Status register again */
-  if((readval & DP83848_BSR_LINK_STATUS) == 0)
-    /* Return Link Down status */
-    return DP83848_STATUS_LINK_DOWN;
-  /* Check Auto negotiaition */
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &readval) < 0)
-  if((readval & DP83848_BCR_AUTONEGO_EN) != DP83848_BCR_AUTONEGO_EN)
-    if(((readval & DP83848_BCR_SPEED_SELECT) == DP83848_BCR_SPEED_SELECT) && ((readval & DP83848_BCR_DUPLEX_MODE) == DP83848_BCR_DUPLEX_MODE))
-      return DP83848_STATUS_100MBITS_FULLDUPLEX;
-    else if ((readval & DP83848_BCR_SPEED_SELECT) == DP83848_BCR_SPEED_SELECT)
-      return DP83848_STATUS_100MBITS_HALFDUPLEX;
-    else if ((readval & DP83848_BCR_DUPLEX_MODE) == DP83848_BCR_DUPLEX_MODE)
-      return DP83848_STATUS_10MBITS_FULLDUPLEX;
-    else
-      return DP83848_STATUS_10MBITS_HALFDUPLEX;
-  else /* Auto Nego enabled */
-    if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_PHYSCSR, &readval) < 0)
-    /* Check if auto nego not done */
-    if((readval & DP83848_PHYSCSR_AUTONEGO_DONE) == 0)
-      return DP83848_STATUS_AUTONEGO_NOTDONE;
-    if((readval & DP83848_PHYSCSR_HCDSPEEDMASK) == DP83848_PHYSCSR_100BTX_FD)
-    else if ((readval & DP83848_PHYSCSR_HCDSPEEDMASK) == DP83848_PHYSCSR_100BTX_HD)
-    else if ((readval & DP83848_PHYSCSR_HCDSPEEDMASK) == DP83848_PHYSCSR_10BT_FD)
-    else
-  * @brief  Set the link state of DP83848 device.
-  * @param  pLinkState: link state can be one of the following
-  *         DP83848_STATUS_ERROR  if parameter error
-int32_t DP83848_SetLinkState(dp83848_Object_t *pObj, uint32_t LinkState)
-  uint32_t bcrvalue = 0;
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &bcrvalue) >= 0)
-    /* Disable link config (Auto nego, speed and duplex) */
-    bcrvalue &= ~(DP83848_BCR_AUTONEGO_EN | DP83848_BCR_SPEED_SELECT | DP83848_BCR_DUPLEX_MODE);
-    if(LinkState == DP83848_STATUS_100MBITS_FULLDUPLEX)
-      bcrvalue |= (DP83848_BCR_SPEED_SELECT | DP83848_BCR_DUPLEX_MODE);
-    else if (LinkState == DP83848_STATUS_100MBITS_HALFDUPLEX)
-      bcrvalue |= DP83848_BCR_SPEED_SELECT;
-    else if (LinkState == DP83848_STATUS_10MBITS_FULLDUPLEX)
-      bcrvalue |= DP83848_BCR_DUPLEX_MODE;
-    else
-      /* Wrong link status parameter */
-      status = DP83848_STATUS_ERROR;
-  else
-    if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_BCR, bcrvalue) < 0)
-  return status;
-  * @brief  Enable loopback mode.
-int32_t DP83848_EnableLoopbackMode(dp83848_Object_t *pObj)
-    readval |= DP83848_BCR_LOOPBACK;
-  else
-  return status;
-  * @brief  Disable loopback mode.
-int32_t DP83848_DisableLoopbackMode(dp83848_Object_t *pObj)
-    readval &= ~DP83848_BCR_LOOPBACK;
-  else
-  return status;
-  * @brief  Enable IT source.
-  * @param  Interrupt: IT source to be enabled
-  *         should be a value or a combination of the following:
-  *         DP83848_WOL_IT
-  *         DP83848_ENERGYON_IT
-  *         DP83848_AUTONEGO_COMPLETE_IT
-  *         DP83848_REMOTE_FAULT_IT
-  *         DP83848_LINK_DOWN_IT
-  *         DP83848_AUTONEGO_LP_ACK_IT
-  *         DP83848_PARALLEL_DETECTION_FAULT_IT
-  *         DP83848_AUTONEGO_PAGE_RECEIVED_IT
-int32_t DP83848_EnableIT(dp83848_Object_t *pObj, uint32_t Interrupt)
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_IMR, &readval) >= 0)
-    readval |= Interrupt;
-    if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_IMR, readval) < 0)
-  else
-  return status;
-  * @brief  Disable IT source.
-  * @param  Interrupt: IT source to be disabled
-  *         DP83848_WOL_IT
-int32_t DP83848_DisableIT(dp83848_Object_t *pObj, uint32_t Interrupt)
-    readval &= ~Interrupt;
-  else
-  return status;
-  * @brief  Clear IT flag.
-  * @param  Interrupt: IT flag to be cleared
-  *         DP83848_WOL_IT
-int32_t  DP83848_ClearIT(dp83848_Object_t *pObj, uint32_t Interrupt)
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_ISFR, &readval) < 0)
-  return status;
-  * @brief  Get IT Flag status.
-  * @param  Interrupt: IT Flag to be checked,
-  *         DP83848_WOL_IT
-  * @retval 1 IT flag is SET
-  *         0 IT flag is RESET
-int32_t DP83848_GetITStatus(dp83848_Object_t *pObj, uint32_t Interrupt)
-  int32_t status = 0;
-  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_ISFR, &readval) >= 0)
-    status = ((readval & Interrupt) == Interrupt);
-  else
-  return status;
+  * @file    dp83848.c
+  * @author  MCD Application Team
+  * @brief   This file provides a set of functions needed to manage the DP83848
+  *          PHY devices.
+  * @attention
+  * <h2><center>© Copyright (c) 2021 STMicroelectronics.
+  * All rights reserved.</center></h2>
+  * This software component is licensed by ST under BSD 3-Clause license,
+  * the "License"; You may not use this file except in compliance with the
+  * License. You may obtain a copy of the License at:
+  *                        opensource.org/licenses/BSD-3-Clause
+/* Includes ------------------------------------------------------------------*/
+#include "dp83848.h"
+/** @addtogroup BSP
+/** @addtogroup Component
+/** @defgroup DP83848 DP83848
+/* Private typedef -----------------------------------------------------------*/
+/* Private define ------------------------------------------------------------*/
+/** @defgroup DP83848_Private_Defines DP83848 Private Defines
+#define DP83848_SW_RESET_TO    ((uint32_t)500U)
+#define DP83848_INIT_TO        ((uint32_t)2000U)
+#define DP83848_MAX_DEV_ADDR   ((uint32_t)31U)
+/* Private macro -------------------------------------------------------------*/
+/* Private variables ---------------------------------------------------------*/
+/* Private function prototypes -----------------------------------------------*/
+/* Private functions ---------------------------------------------------------*/
+/** @defgroup DP83848_Private_Functions DP83848 Private Functions
+  * @brief  Register IO functions to component object
+  * @param  pObj: device object  of DP83848_Object_t.
+  * @param  ioctx: holds device IO functions.
+  * @retval DP83848_STATUS_OK  if OK
+  *         DP83848_STATUS_ERROR if missing mandatory function
+int32_t  DP83848_RegisterBusIO(dp83848_Object_t *pObj, dp83848_IOCtx_t *ioctx)
+  if(!pObj || !ioctx->ReadReg || !ioctx->WriteReg || !ioctx->GetTick)
+    return DP83848_STATUS_ERROR;
+  pObj->IO.Init = ioctx->Init;
+  pObj->IO.DeInit = ioctx->DeInit;
+  pObj->IO.ReadReg = ioctx->ReadReg;
+  pObj->IO.WriteReg = ioctx->WriteReg;
+  pObj->IO.GetTick = ioctx->GetTick;
+  return DP83848_STATUS_OK;
+  * @brief  Initialize the DP83848 and configure the needed hardware resources
+  * @param  pObj: device object DP83848_Object_t.
+  *         DP83848_STATUS_ADDRESS_ERROR if cannot find device address
+  *         DP83848_STATUS_READ_ERROR if connot read register
+  *         DP83848_STATUS_WRITE_ERROR if connot write to register
+  *         DP83848_STATUS_RESET_TIMEOUT if cannot perform a software reset
+ int32_t DP83848_Init(dp83848_Object_t *pObj)
+   uint32_t tickstart = 0, regvalue = 0, addr = 0;
+   int32_t status = DP83848_STATUS_OK;
+   if(pObj->Is_Initialized == 0)
+     if(pObj->IO.Init != 0)
+       /* GPIO and Clocks initialization */
+       pObj->IO.Init();
+     /* for later check */
+     pObj->DevAddr = DP83848_MAX_DEV_ADDR + 1;
+     /* Get the device address from special mode register */
+     for(addr = 0; addr <= DP83848_MAX_DEV_ADDR; addr ++)
+       if(pObj->IO.ReadReg(addr, DP83848_SMR, &regvalue) < 0)
+         status = DP83848_STATUS_READ_ERROR;
+         /* Can't read from this device address
+            continue with next address */
+         continue;
+       if((regvalue & DP83848_SMR_PHY_ADDR) == addr)
+         pObj->DevAddr = addr;
+         status = DP83848_STATUS_OK;
+         break;
+     if(pObj->DevAddr > DP83848_MAX_DEV_ADDR)
+       status = DP83848_STATUS_ADDRESS_ERROR;
+     /* if device address is matched */
+     if(status == DP83848_STATUS_OK)
+       /* set a software reset  */
+       if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_BCR, DP83848_BCR_SOFT_RESET) >= 0)
+         /* get software reset status */
+         if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &regvalue) >= 0)
+           tickstart = pObj->IO.GetTick();
+           /* wait until software reset is done or timeout occured  */
+           while(regvalue & DP83848_BCR_SOFT_RESET)
+             if((pObj->IO.GetTick() - tickstart) <= DP83848_SW_RESET_TO)
+               if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &regvalue) < 0)
+                 break;
+             else
+               status = DP83848_STATUS_RESET_TIMEOUT;
+               break;
+         else
+       else
+         status = DP83848_STATUS_WRITE_ERROR;
+     /* Wait for 2s to perform initialization */
+     while((pObj->IO.GetTick() - tickstart) <= DP83848_INIT_TO)
+     pObj->Is_Initialized = 1;
+   return status;
+  * @brief  De-Initialize the dp83848 and it's hardware resources
+  * @retval None
+int32_t DP83848_DeInit(dp83848_Object_t *pObj)
+  if(pObj->Is_Initialized)
+    if(pObj->IO.DeInit != 0)
+      if(pObj->IO.DeInit() < 0)
+    pObj->Is_Initialized = 0;
+  * @brief  Disable the DP83848 power down mode.
+int32_t DP83848_DisablePowerDownMode(dp83848_Object_t *pObj)
+  uint32_t readval = 0;
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &readval) >= 0)
+    readval &= ~DP83848_BCR_POWER_DOWN;
+    /* Apply configuration */
+    if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_BCR, readval) < 0)
+  else
+  return status;
+  * @brief  Enable the DP83848 power down mode.
+int32_t DP83848_EnablePowerDownMode(dp83848_Object_t *pObj)
+    readval |= DP83848_BCR_POWER_DOWN;
+  else
+  return status;
+  * @brief  Start the auto negotiation process.
+int32_t DP83848_StartAutoNego(dp83848_Object_t *pObj)
+    readval |= DP83848_BCR_AUTONEGO_EN;
+  else
+  return status;
+  * @brief  Get the link state of DP83848 device.
+  * @param  pObj: Pointer to device object.
+  * @param  pLinkState: Pointer to link state
+  * @retval DP83848_STATUS_LINK_DOWN  if link is down
+  *         DP83848_STATUS_AUTONEGO_NOTDONE if Auto nego not completed
+  *         DP83848_STATUS_100MBITS_FULLDUPLEX if 100Mb/s FD
+  *         DP83848_STATUS_100MBITS_HALFDUPLEX if 100Mb/s HD
+  *         DP83848_STATUS_10MBITS_FULLDUPLEX  if 10Mb/s FD
+  *         DP83848_STATUS_10MBITS_HALFDUPLEX  if 10Mb/s HD
+int32_t DP83848_GetLinkState(dp83848_Object_t *pObj)
+  /* Read Status register  */
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BSR, &readval) < 0)
+    return DP83848_STATUS_READ_ERROR;
+  /* Read Status register again */
+  if((readval & DP83848_BSR_LINK_STATUS) == 0)
+    /* Return Link Down status */
+    return DP83848_STATUS_LINK_DOWN;
+  /* Check Auto negotiaition */
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &readval) < 0)
+  if((readval & DP83848_BCR_AUTONEGO_EN) != DP83848_BCR_AUTONEGO_EN)
+    if(((readval & DP83848_BCR_SPEED_SELECT) == DP83848_BCR_SPEED_SELECT) && ((readval & DP83848_BCR_DUPLEX_MODE) == DP83848_BCR_DUPLEX_MODE))
+      return DP83848_STATUS_100MBITS_FULLDUPLEX;
+    else if ((readval & DP83848_BCR_SPEED_SELECT) == DP83848_BCR_SPEED_SELECT)
+      return DP83848_STATUS_100MBITS_HALFDUPLEX;
+    else if ((readval & DP83848_BCR_DUPLEX_MODE) == DP83848_BCR_DUPLEX_MODE)
+      return DP83848_STATUS_10MBITS_FULLDUPLEX;
+    else
+      return DP83848_STATUS_10MBITS_HALFDUPLEX;
+  else /* Auto Nego enabled */
+    if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_PHYSCSR, &readval) < 0)
+    /* Check if auto nego not done */
+    if((readval & DP83848_PHYSCSR_AUTONEGO_DONE) == 0)
+      return DP83848_STATUS_AUTONEGO_NOTDONE;
+    if((readval & DP83848_PHYSCSR_HCDSPEEDMASK) == DP83848_PHYSCSR_100BTX_FD)
+    else if ((readval & DP83848_PHYSCSR_HCDSPEEDMASK) == DP83848_PHYSCSR_100BTX_HD)
+    else if ((readval & DP83848_PHYSCSR_HCDSPEEDMASK) == DP83848_PHYSCSR_10BT_FD)
+    else
+  * @brief  Set the link state of DP83848 device.
+  * @param  pLinkState: link state can be one of the following
+  *         DP83848_STATUS_ERROR  if parameter error
+int32_t DP83848_SetLinkState(dp83848_Object_t *pObj, uint32_t LinkState)
+  uint32_t bcrvalue = 0;
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_BCR, &bcrvalue) >= 0)
+    /* Disable link config (Auto nego, speed and duplex) */
+    bcrvalue &= ~(DP83848_BCR_AUTONEGO_EN | DP83848_BCR_SPEED_SELECT | DP83848_BCR_DUPLEX_MODE);
+    if(LinkState == DP83848_STATUS_100MBITS_FULLDUPLEX)
+      bcrvalue |= (DP83848_BCR_SPEED_SELECT | DP83848_BCR_DUPLEX_MODE);
+    else if (LinkState == DP83848_STATUS_100MBITS_HALFDUPLEX)
+      bcrvalue |= DP83848_BCR_SPEED_SELECT;
+    else if (LinkState == DP83848_STATUS_10MBITS_FULLDUPLEX)
+      bcrvalue |= DP83848_BCR_DUPLEX_MODE;
+    else
+      /* Wrong link status parameter */
+      status = DP83848_STATUS_ERROR;
+  else
+    if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_BCR, bcrvalue) < 0)
+  return status;
+  * @brief  Enable loopback mode.
+int32_t DP83848_EnableLoopbackMode(dp83848_Object_t *pObj)
+    readval |= DP83848_BCR_LOOPBACK;
+  else
+  return status;
+  * @brief  Disable loopback mode.
+int32_t DP83848_DisableLoopbackMode(dp83848_Object_t *pObj)
+    readval &= ~DP83848_BCR_LOOPBACK;
+  else
+  return status;
+  * @brief  Enable IT source.
+  * @param  Interrupt: IT source to be enabled
+  *         should be a value or a combination of the following:
+  *         DP83848_WOL_IT
+  *         DP83848_ENERGYON_IT
+  *         DP83848_AUTONEGO_COMPLETE_IT
+  *         DP83848_REMOTE_FAULT_IT
+  *         DP83848_LINK_DOWN_IT
+  *         DP83848_AUTONEGO_LP_ACK_IT
+  *         DP83848_PARALLEL_DETECTION_FAULT_IT
+  *         DP83848_AUTONEGO_PAGE_RECEIVED_IT
+int32_t DP83848_EnableIT(dp83848_Object_t *pObj, uint32_t Interrupt)
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_IMR, &readval) >= 0)
+    readval |= Interrupt;
+    if(pObj->IO.WriteReg(pObj->DevAddr, DP83848_IMR, readval) < 0)
+  else
+  return status;
+  * @brief  Disable IT source.
+  * @param  Interrupt: IT source to be disabled
+  *         DP83848_WOL_IT
+int32_t DP83848_DisableIT(dp83848_Object_t *pObj, uint32_t Interrupt)
+    readval &= ~Interrupt;
+  else
+  return status;
+  * @brief  Clear IT flag.
+  * @param  Interrupt: IT flag to be cleared
+  *         DP83848_WOL_IT
+int32_t  DP83848_ClearIT(dp83848_Object_t *pObj, uint32_t Interrupt)
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_ISFR, &readval) < 0)
+  return status;
+  * @brief  Get IT Flag status.
+  * @param  Interrupt: IT Flag to be checked,
+  *         DP83848_WOL_IT
+  * @retval 1 IT flag is SET
+  *         0 IT flag is RESET
+int32_t DP83848_GetITStatus(dp83848_Object_t *pObj, uint32_t Interrupt)
+  int32_t status = 0;
+  if(pObj->IO.ReadReg(pObj->DevAddr, DP83848_ISFR, &readval) >= 0)
+    status = ((readval & Interrupt) == Interrupt);
+  else
+  return status;
diff --git a/stm32/driver/dp83848.h b/stm32/driver/dp83848.h
index d49496d..dd921f6 100644
--- a/stm32/driver/dp83848.h
+++ b/stm32/driver/dp83848.h
@@ -1,436 +1,436 @@
-  * @file    dp83848.h
-  * @brief   This file contains all the functions prototypes for the
-  *          dp83848.c PHY driver.
-  * @attention
-/* Define to prevent recursive inclusion -------------------------------------*/
-#ifndef DP83848_H
-#define DP83848_H
-#ifdef __cplusplus
- extern "C" {
-#endif
-#include <stdint.h>
-/* Exported constants --------------------------------------------------------*/
-/** @defgroup DP83848_Exported_Constants DP83848 Exported Constants
-/** @defgroup DP83848_Registers_Mapping DP83848 Registers Mapping
-#define DP83848_BCR      ((uint16_t)0x0000U)
-#define DP83848_BSR      ((uint16_t)0x0001U)
-#define DP83848_PHYI1R   ((uint16_t)0x0002U)
-#define DP83848_PHYI2R   ((uint16_t)0x0003U)
-#define DP83848_ANAR     ((uint16_t)0x0004U)
-#define DP83848_ANLPAR   ((uint16_t)0x0005U)
-#define DP83848_ANER     ((uint16_t)0x0006U)
-#define DP83848_ANNPTR   ((uint16_t)0x0007U)
-#define DP83848_SMR      ((uint16_t)0x0019U)
-#define DP83848_ISFR     ((uint16_t)0x0012U)
-#define DP83848_IMR      ((uint16_t)0x0011U)
-#define DP83848_PHYSCSR  ((uint16_t)0x0010U)
-/** @defgroup DP83848_BCR_Bit_Definition DP83848 BCR Bit Definition
-#define DP83848_BCR_SOFT_RESET         ((uint16_t)0x8000U)
-#define DP83848_BCR_LOOPBACK           ((uint16_t)0x4000U)
-#define DP83848_BCR_SPEED_SELECT       ((uint16_t)0x2000U)
-#define DP83848_BCR_AUTONEGO_EN        ((uint16_t)0x1000U)
-#define DP83848_BCR_POWER_DOWN         ((uint16_t)0x0800U)
-#define DP83848_BCR_ISOLATE            ((uint16_t)0x0400U)
-#define DP83848_BCR_RESTART_AUTONEGO   ((uint16_t)0x0200U)
-#define DP83848_BCR_DUPLEX_MODE        ((uint16_t)0x0100U)
-/** @defgroup DP83848_BSR_Bit_Definition DP83848 BSR Bit Definition
-#define DP83848_BSR_100BASE_T4       ((uint16_t)0x8000U)
-#define DP83848_BSR_100BASE_TX_FD    ((uint16_t)0x4000U)
-#define DP83848_BSR_100BASE_TX_HD    ((uint16_t)0x2000U)
-#define DP83848_BSR_10BASE_T_FD      ((uint16_t)0x1000U)
-#define DP83848_BSR_10BASE_T_HD      ((uint16_t)0x0800U)
-#define DP83848_BSR_MF_PREAMBLE      ((uint16_t)0x0040U)
-#define DP83848_BSR_AUTONEGO_CPLT    ((uint16_t)0x0020U)
-#define DP83848_BSR_REMOTE_FAULT     ((uint16_t)0x0010U)
-#define DP83848_BSR_AUTONEGO_ABILITY ((uint16_t)0x0008U)
-#define DP83848_BSR_LINK_STATUS      ((uint16_t)0x0004U)
-#define DP83848_BSR_JABBER_DETECT    ((uint16_t)0x0002U)
-#define DP83848_BSR_EXTENDED_CAP     ((uint16_t)0x0001U)
-/** @defgroup DP83848_PHYI1R_Bit_Definition DP83848 PHYI1R Bit Definition
-#define DP83848_PHYI1R_OUI_3_18           ((uint16_t)0xFFFFU)
-/** @defgroup DP83848_PHYI2R_Bit_Definition DP83848 PHYI2R Bit Definition
-#define DP83848_PHYI2R_OUI_19_24          ((uint16_t)0xFC00U)
-#define DP83848_PHYI2R_MODEL_NBR          ((uint16_t)0x03F0U)
-#define DP83848_PHYI2R_REVISION_NBR       ((uint16_t)0x000FU)
-/** @defgroup DP83848_ANAR_Bit_Definition DP83848 ANAR Bit Definition
-#define DP83848_ANAR_NEXT_PAGE               ((uint16_t)0x8000U)
-#define DP83848_ANAR_REMOTE_FAULT            ((uint16_t)0x2000U)
-#define DP83848_ANAR_PAUSE_OPERATION         ((uint16_t)0x0C00U)
-#define DP83848_ANAR_PO_NOPAUSE              ((uint16_t)0x0000U)
-#define DP83848_ANAR_PO_SYMMETRIC_PAUSE      ((uint16_t)0x0400U)
-#define DP83848_ANAR_PO_ASYMMETRIC_PAUSE     ((uint16_t)0x0800U)
-#define DP83848_ANAR_PO_ADVERTISE_SUPPORT    ((uint16_t)0x0C00U)
-#define DP83848_ANAR_100BASE_TX_FD           ((uint16_t)0x0100U)
-#define DP83848_ANAR_100BASE_TX              ((uint16_t)0x0080U)
-#define DP83848_ANAR_10BASE_T_FD             ((uint16_t)0x0040U)
-#define DP83848_ANAR_10BASE_T                ((uint16_t)0x0020U)
-#define DP83848_ANAR_SELECTOR_FIELD          ((uint16_t)0x000FU)
-/** @defgroup DP83848_ANLPAR_Bit_Definition DP83848 ANLPAR Bit Definition
-#define DP83848_ANLPAR_NEXT_PAGE            ((uint16_t)0x8000U)
-#define DP83848_ANLPAR_REMOTE_FAULT         ((uint16_t)0x2000U)
-#define DP83848_ANLPAR_PAUSE_OPERATION      ((uint16_t)0x0C00U)
-#define DP83848_ANLPAR_PO_NOPAUSE           ((uint16_t)0x0000U)
-#define DP83848_ANLPAR_PO_SYMMETRIC_PAUSE   ((uint16_t)0x0400U)
-#define DP83848_ANLPAR_PO_ASYMMETRIC_PAUSE  ((uint16_t)0x0800U)
-#define DP83848_ANLPAR_PO_ADVERTISE_SUPPORT ((uint16_t)0x0C00U)
-#define DP83848_ANLPAR_100BASE_TX_FD        ((uint16_t)0x0100U)
-#define DP83848_ANLPAR_100BASE_TX           ((uint16_t)0x0080U)
-#define DP83848_ANLPAR_10BASE_T_FD          ((uint16_t)0x0040U)
-#define DP83848_ANLPAR_10BASE_T             ((uint16_t)0x0020U)
-#define DP83848_ANLPAR_SELECTOR_FIELD       ((uint16_t)0x000FU)
-/** @defgroup DP83848_ANER_Bit_Definition DP83848 ANER Bit Definition
-#define DP83848_ANER_RX_NP_LOCATION_ABLE    ((uint16_t)0x0040U)
-#define DP83848_ANER_RX_NP_STORAGE_LOCATION ((uint16_t)0x0020U)
-#define DP83848_ANER_PARALLEL_DETECT_FAULT  ((uint16_t)0x0010U)
-#define DP83848_ANER_LP_NP_ABLE             ((uint16_t)0x0008U)
-#define DP83848_ANER_NP_ABLE                ((uint16_t)0x0004U)
-#define DP83848_ANER_PAGE_RECEIVED          ((uint16_t)0x0002U)
-#define DP83848_ANER_LP_AUTONEG_ABLE        ((uint16_t)0x0001U)
-/** @defgroup DP83848_ANNPTR_Bit_Definition DP83848 ANNPTR Bit Definition
-#define DP83848_ANNPTR_NEXT_PAGE         ((uint16_t)0x8000U)
-#define DP83848_ANNPTR_MESSAGE_PAGE      ((uint16_t)0x2000U)
-#define DP83848_ANNPTR_ACK2              ((uint16_t)0x1000U)
-#define DP83848_ANNPTR_TOGGLE            ((uint16_t)0x0800U)
-#define DP83848_ANNPTR_MESSAGE_CODE      ((uint16_t)0x07FFU)
-/** @defgroup DP83848_ANNPRR_Bit_Definition DP83848 ANNPRR Bit Definition
-#define DP83848_ANNPRR_NEXT_PAGE         ((uint16_t)0x8000U)
-#define DP83848_ANNPRR_ACK               ((uint16_t)0x4000U)
-#define DP83848_ANNPRR_MESSAGE_PAGE      ((uint16_t)0x2000U)
-#define DP83848_ANNPRR_ACK2              ((uint16_t)0x1000U)
-#define DP83848_ANNPRR_TOGGLE            ((uint16_t)0x0800U)
-#define DP83848_ANNPRR_MESSAGE_CODE      ((uint16_t)0x07FFU)
-/** @defgroup DP83848_MMDACR_Bit_Definition DP83848 MMDACR Bit Definition
-#define DP83848_MMDACR_MMD_FUNCTION       ((uint16_t)0xC000U)
-#define DP83848_MMDACR_MMD_FUNCTION_ADDR  ((uint16_t)0x0000U)
-#define DP83848_MMDACR_MMD_FUNCTION_DATA  ((uint16_t)0x4000U)
-#define DP83848_MMDACR_MMD_DEV_ADDR       ((uint16_t)0x001FU)
-/** @defgroup DP83848_ENCTR_Bit_Definition DP83848 ENCTR Bit Definition
-#define DP83848_ENCTR_TX_ENABLE             ((uint16_t)0x8000U)
-#define DP83848_ENCTR_TX_TIMER              ((uint16_t)0x6000U)
-#define DP83848_ENCTR_TX_TIMER_1S           ((uint16_t)0x0000U)
-#define DP83848_ENCTR_TX_TIMER_768MS        ((uint16_t)0x2000U)
-#define DP83848_ENCTR_TX_TIMER_512MS        ((uint16_t)0x4000U)
-#define DP83848_ENCTR_TX_TIMER_265MS        ((uint16_t)0x6000U)
-#define DP83848_ENCTR_RX_ENABLE             ((uint16_t)0x1000U)
-#define DP83848_ENCTR_RX_MAX_INTERVAL       ((uint16_t)0x0C00U)
-#define DP83848_ENCTR_RX_MAX_INTERVAL_64MS  ((uint16_t)0x0000U)
-#define DP83848_ENCTR_RX_MAX_INTERVAL_256MS ((uint16_t)0x0400U)
-#define DP83848_ENCTR_RX_MAX_INTERVAL_512MS ((uint16_t)0x0800U)
-#define DP83848_ENCTR_RX_MAX_INTERVAL_1S    ((uint16_t)0x0C00U)
-#define DP83848_ENCTR_EX_CROSS_OVER         ((uint16_t)0x0002U)
-#define DP83848_ENCTR_EX_MANUAL_CROSS_OVER  ((uint16_t)0x0001U)
-/** @defgroup DP83848_MCSR_Bit_Definition DP83848 MCSR Bit Definition
-#define DP83848_MCSR_EDPWRDOWN        ((uint16_t)0x2000U)
-#define DP83848_MCSR_FARLOOPBACK      ((uint16_t)0x0200U)
-#define DP83848_MCSR_ALTINT           ((uint16_t)0x0040U)
-#define DP83848_MCSR_ENERGYON         ((uint16_t)0x0002U)
-/** @defgroup DP83848_SMR_Bit_Definition DP83848 SMR Bit Definition
-#define DP83848_SMR_MODE       ((uint16_t)0x00E0U)
-#define DP83848_SMR_PHY_ADDR   ((uint16_t)0x001FU)
-/** @defgroup DP83848_TPDCR_Bit_Definition DP83848 TPDCR Bit Definition
-#define DP83848_TPDCR_DELAY_IN                 ((uint16_t)0x8000U)
-#define DP83848_TPDCR_LINE_BREAK_COUNTER       ((uint16_t)0x7000U)
-#define DP83848_TPDCR_PATTERN_HIGH             ((uint16_t)0x0FC0U)
-#define DP83848_TPDCR_PATTERN_LOW              ((uint16_t)0x003FU)
-/** @defgroup DP83848_TCSR_Bit_Definition DP83848 TCSR Bit Definition
-#define DP83848_TCSR_TDR_ENABLE           ((uint16_t)0x8000U)
-#define DP83848_TCSR_TDR_AD_FILTER_ENABLE ((uint16_t)0x4000U)
-#define DP83848_TCSR_TDR_CH_CABLE_TYPE    ((uint16_t)0x0600U)
-#define DP83848_TCSR_TDR_CH_CABLE_DEFAULT ((uint16_t)0x0000U)
-#define DP83848_TCSR_TDR_CH_CABLE_SHORTED ((uint16_t)0x0200U)
-#define DP83848_TCSR_TDR_CH_CABLE_OPEN    ((uint16_t)0x0400U)
-#define DP83848_TCSR_TDR_CH_CABLE_MATCH   ((uint16_t)0x0600U)
-#define DP83848_TCSR_TDR_CH_STATUS        ((uint16_t)0x0100U)
-#define DP83848_TCSR_TDR_CH_LENGTH        ((uint16_t)0x00FFU)
-/** @defgroup DP83848_SCSIR_Bit_Definition DP83848 SCSIR Bit Definition
-#define DP83848_SCSIR_AUTO_MDIX_ENABLE    ((uint16_t)0x8000U)
-#define DP83848_SCSIR_CHANNEL_SELECT      ((uint16_t)0x2000U)
-#define DP83848_SCSIR_SQE_DISABLE         ((uint16_t)0x0800U)
-#define DP83848_SCSIR_XPOLALITY           ((uint16_t)0x0010U)
-/** @defgroup DP83848_CLR_Bit_Definition DP83848 CLR Bit Definition
-#define DP83848_CLR_CABLE_LENGTH       ((uint16_t)0xF000U)
-/** @defgroup DP83848_IMR_ISFR_Bit_Definition DP83848 IMR ISFR Bit Definition
-#define DP83848_INT_8       ((uint16_t)0x0100U)
-#define DP83848_INT_7       ((uint16_t)0x0080U)
-#define DP83848_INT_6       ((uint16_t)0x0040U)
-#define DP83848_INT_5       ((uint16_t)0x0020U)
-#define DP83848_INT_4       ((uint16_t)0x0010U)
-#define DP83848_INT_3       ((uint16_t)0x0008U)
-#define DP83848_INT_2       ((uint16_t)0x0004U)
-#define DP83848_INT_1       ((uint16_t)0x0002U)
-/** @defgroup DP83848_PHYSCSR_Bit_Definition DP83848 PHYSCSR Bit Definition
-#define DP83848_PHYSCSR_AUTONEGO_DONE   ((uint16_t)0x100U)
-#define DP83848_PHYSCSR_HCDSPEEDMASK    ((uint16_t)0x006U)
-#define DP83848_PHYSCSR_10BT_HD         ((uint16_t)0x002U)
-#define DP83848_PHYSCSR_10BT_FD         ((uint16_t)0x006U)
-#define DP83848_PHYSCSR_100BTX_HD       ((uint16_t)0x000U)
-#define DP83848_PHYSCSR_100BTX_FD       ((uint16_t)0x004U)
-/** @defgroup DP83848_Status DP83848 Status
-#define  DP83848_STATUS_READ_ERROR            ((int32_t)-5)
-#define  DP83848_STATUS_WRITE_ERROR           ((int32_t)-4)
-#define  DP83848_STATUS_ADDRESS_ERROR         ((int32_t)-3)
-#define  DP83848_STATUS_RESET_TIMEOUT         ((int32_t)-2)
-#define  DP83848_STATUS_ERROR                 ((int32_t)-1)
-#define  DP83848_STATUS_OK                    ((int32_t) 0)
-#define  DP83848_STATUS_LINK_DOWN             ((int32_t) 1)
-#define  DP83848_STATUS_100MBITS_FULLDUPLEX   ((int32_t) 2)
-#define  DP83848_STATUS_100MBITS_HALFDUPLEX   ((int32_t) 3)
-#define  DP83848_STATUS_10MBITS_FULLDUPLEX    ((int32_t) 4)
-#define  DP83848_STATUS_10MBITS_HALFDUPLEX    ((int32_t) 5)
-#define  DP83848_STATUS_AUTONEGO_NOTDONE      ((int32_t) 6)
-/** @defgroup DP83848_IT_Flags DP83848 IT Flags
-#define  DP83848_WOL_IT                        DP83848_INT_8
-#define  DP83848_ENERGYON_IT                   DP83848_INT_7
-#define  DP83848_AUTONEGO_COMPLETE_IT          DP83848_INT_6
-#define  DP83848_REMOTE_FAULT_IT               DP83848_INT_5
-#define  DP83848_LINK_DOWN_IT                  DP83848_INT_4
-#define  DP83848_AUTONEGO_LP_ACK_IT            DP83848_INT_3
-#define  DP83848_PARALLEL_DETECTION_FAULT_IT   DP83848_INT_2
-#define  DP83848_AUTONEGO_PAGE_RECEIVED_IT     DP83848_INT_1
-/* Exported types ------------------------------------------------------------*/
-/** @defgroup DP83848_Exported_Types DP83848 Exported Types
-typedef int32_t  (*dp83848_Init_Func) (void);
-typedef int32_t  (*dp83848_DeInit_Func) (void);
-typedef int32_t  (*dp83848_ReadReg_Func)   (uint32_t, uint32_t, uint32_t *);
-typedef int32_t  (*dp83848_WriteReg_Func)  (uint32_t, uint32_t, uint32_t);
-typedef int32_t  (*dp83848_GetTick_Func)  (void);
-typedef struct
-  dp83848_Init_Func      Init;
-  dp83848_DeInit_Func    DeInit;
-  dp83848_WriteReg_Func  WriteReg;
-  dp83848_ReadReg_Func   ReadReg;
-  dp83848_GetTick_Func   GetTick;
-} dp83848_IOCtx_t;
-typedef struct
-  uint32_t            DevAddr;
-  uint32_t            Is_Initialized;
-  dp83848_IOCtx_t     IO;
-  void               *pData;
-}dp83848_Object_t;
-/* Exported macro ------------------------------------------------------------*/
-/* Exported functions --------------------------------------------------------*/
-/** @defgroup DP83848_Exported_Functions DP83848 Exported Functions
-int32_t DP83848_RegisterBusIO(dp83848_Object_t *pObj, dp83848_IOCtx_t *ioctx);
-int32_t DP83848_Init(dp83848_Object_t *pObj);
-int32_t DP83848_DeInit(dp83848_Object_t *pObj);
-int32_t DP83848_DisablePowerDownMode(dp83848_Object_t *pObj);
-int32_t DP83848_EnablePowerDownMode(dp83848_Object_t *pObj);
-int32_t DP83848_StartAutoNego(dp83848_Object_t *pObj);
-int32_t DP83848_GetLinkState(dp83848_Object_t *pObj);
-int32_t DP83848_SetLinkState(dp83848_Object_t *pObj, uint32_t LinkState);
-int32_t DP83848_EnableLoopbackMode(dp83848_Object_t *pObj);
-int32_t DP83848_DisableLoopbackMode(dp83848_Object_t *pObj);
-int32_t DP83848_EnableIT(dp83848_Object_t *pObj, uint32_t Interrupt);
-int32_t DP83848_DisableIT(dp83848_Object_t *pObj, uint32_t Interrupt);
-int32_t DP83848_ClearIT(dp83848_Object_t *pObj, uint32_t Interrupt);
-int32_t DP83848_GetITStatus(dp83848_Object_t *pObj, uint32_t Interrupt);
-#ifdef __cplusplus
-#endif
-#endif /* DP83848_H */
+  * @file    dp83848.h
+  * @brief   This file contains all the functions prototypes for the
+  *          dp83848.c PHY driver.
+  * @attention
+/* Define to prevent recursive inclusion -------------------------------------*/
+#ifndef DP83848_H
+#define DP83848_H
+#ifdef __cplusplus
+ extern "C" {
+#endif
+#include <stdint.h>
+/* Exported constants --------------------------------------------------------*/
+/** @defgroup DP83848_Exported_Constants DP83848 Exported Constants
+/** @defgroup DP83848_Registers_Mapping DP83848 Registers Mapping
+#define DP83848_BCR      ((uint16_t)0x0000U)
+#define DP83848_BSR      ((uint16_t)0x0001U)
+#define DP83848_PHYI1R   ((uint16_t)0x0002U)
+#define DP83848_PHYI2R   ((uint16_t)0x0003U)
+#define DP83848_ANAR     ((uint16_t)0x0004U)
+#define DP83848_ANLPAR   ((uint16_t)0x0005U)
+#define DP83848_ANER     ((uint16_t)0x0006U)
+#define DP83848_ANNPTR   ((uint16_t)0x0007U)
+#define DP83848_SMR      ((uint16_t)0x0019U)
+#define DP83848_ISFR     ((uint16_t)0x0012U)
+#define DP83848_IMR      ((uint16_t)0x0011U)
+#define DP83848_PHYSCSR  ((uint16_t)0x0010U)
+/** @defgroup DP83848_BCR_Bit_Definition DP83848 BCR Bit Definition
+#define DP83848_BCR_SOFT_RESET         ((uint16_t)0x8000U)
+#define DP83848_BCR_LOOPBACK           ((uint16_t)0x4000U)
+#define DP83848_BCR_SPEED_SELECT       ((uint16_t)0x2000U)
+#define DP83848_BCR_AUTONEGO_EN        ((uint16_t)0x1000U)
+#define DP83848_BCR_POWER_DOWN         ((uint16_t)0x0800U)
+#define DP83848_BCR_ISOLATE            ((uint16_t)0x0400U)
+#define DP83848_BCR_RESTART_AUTONEGO   ((uint16_t)0x0200U)
+#define DP83848_BCR_DUPLEX_MODE        ((uint16_t)0x0100U)
+/** @defgroup DP83848_BSR_Bit_Definition DP83848 BSR Bit Definition
+#define DP83848_BSR_100BASE_T4       ((uint16_t)0x8000U)
+#define DP83848_BSR_100BASE_TX_FD    ((uint16_t)0x4000U)
+#define DP83848_BSR_100BASE_TX_HD    ((uint16_t)0x2000U)
+#define DP83848_BSR_10BASE_T_FD      ((uint16_t)0x1000U)
+#define DP83848_BSR_10BASE_T_HD      ((uint16_t)0x0800U)
+#define DP83848_BSR_MF_PREAMBLE      ((uint16_t)0x0040U)
+#define DP83848_BSR_AUTONEGO_CPLT    ((uint16_t)0x0020U)
+#define DP83848_BSR_REMOTE_FAULT     ((uint16_t)0x0010U)
+#define DP83848_BSR_AUTONEGO_ABILITY ((uint16_t)0x0008U)
+#define DP83848_BSR_LINK_STATUS      ((uint16_t)0x0004U)
+#define DP83848_BSR_JABBER_DETECT    ((uint16_t)0x0002U)
+#define DP83848_BSR_EXTENDED_CAP     ((uint16_t)0x0001U)
+/** @defgroup DP83848_PHYI1R_Bit_Definition DP83848 PHYI1R Bit Definition
+#define DP83848_PHYI1R_OUI_3_18           ((uint16_t)0xFFFFU)
+/** @defgroup DP83848_PHYI2R_Bit_Definition DP83848 PHYI2R Bit Definition
+#define DP83848_PHYI2R_OUI_19_24          ((uint16_t)0xFC00U)
+#define DP83848_PHYI2R_MODEL_NBR          ((uint16_t)0x03F0U)
+#define DP83848_PHYI2R_REVISION_NBR       ((uint16_t)0x000FU)
+/** @defgroup DP83848_ANAR_Bit_Definition DP83848 ANAR Bit Definition
+#define DP83848_ANAR_NEXT_PAGE               ((uint16_t)0x8000U)
+#define DP83848_ANAR_REMOTE_FAULT            ((uint16_t)0x2000U)
+#define DP83848_ANAR_PAUSE_OPERATION         ((uint16_t)0x0C00U)
+#define DP83848_ANAR_PO_NOPAUSE              ((uint16_t)0x0000U)
+#define DP83848_ANAR_PO_SYMMETRIC_PAUSE      ((uint16_t)0x0400U)
+#define DP83848_ANAR_PO_ASYMMETRIC_PAUSE     ((uint16_t)0x0800U)
+#define DP83848_ANAR_PO_ADVERTISE_SUPPORT    ((uint16_t)0x0C00U)
+#define DP83848_ANAR_100BASE_TX_FD           ((uint16_t)0x0100U)
+#define DP83848_ANAR_100BASE_TX              ((uint16_t)0x0080U)
+#define DP83848_ANAR_10BASE_T_FD             ((uint16_t)0x0040U)
+#define DP83848_ANAR_10BASE_T                ((uint16_t)0x0020U)
+#define DP83848_ANAR_SELECTOR_FIELD          ((uint16_t)0x000FU)
+/** @defgroup DP83848_ANLPAR_Bit_Definition DP83848 ANLPAR Bit Definition
+#define DP83848_ANLPAR_NEXT_PAGE            ((uint16_t)0x8000U)
+#define DP83848_ANLPAR_REMOTE_FAULT         ((uint16_t)0x2000U)
+#define DP83848_ANLPAR_PAUSE_OPERATION      ((uint16_t)0x0C00U)
+#define DP83848_ANLPAR_PO_NOPAUSE           ((uint16_t)0x0000U)
+#define DP83848_ANLPAR_PO_SYMMETRIC_PAUSE   ((uint16_t)0x0400U)
+#define DP83848_ANLPAR_PO_ASYMMETRIC_PAUSE  ((uint16_t)0x0800U)
+#define DP83848_ANLPAR_PO_ADVERTISE_SUPPORT ((uint16_t)0x0C00U)
+#define DP83848_ANLPAR_100BASE_TX_FD        ((uint16_t)0x0100U)
+#define DP83848_ANLPAR_100BASE_TX           ((uint16_t)0x0080U)
+#define DP83848_ANLPAR_10BASE_T_FD          ((uint16_t)0x0040U)
+#define DP83848_ANLPAR_10BASE_T             ((uint16_t)0x0020U)
+#define DP83848_ANLPAR_SELECTOR_FIELD       ((uint16_t)0x000FU)
+/** @defgroup DP83848_ANER_Bit_Definition DP83848 ANER Bit Definition
+#define DP83848_ANER_RX_NP_LOCATION_ABLE    ((uint16_t)0x0040U)
+#define DP83848_ANER_RX_NP_STORAGE_LOCATION ((uint16_t)0x0020U)
+#define DP83848_ANER_PARALLEL_DETECT_FAULT  ((uint16_t)0x0010U)
+#define DP83848_ANER_LP_NP_ABLE             ((uint16_t)0x0008U)
+#define DP83848_ANER_NP_ABLE                ((uint16_t)0x0004U)
+#define DP83848_ANER_PAGE_RECEIVED          ((uint16_t)0x0002U)
+#define DP83848_ANER_LP_AUTONEG_ABLE        ((uint16_t)0x0001U)
+/** @defgroup DP83848_ANNPTR_Bit_Definition DP83848 ANNPTR Bit Definition
+#define DP83848_ANNPTR_NEXT_PAGE         ((uint16_t)0x8000U)
+#define DP83848_ANNPTR_MESSAGE_PAGE      ((uint16_t)0x2000U)
+#define DP83848_ANNPTR_ACK2              ((uint16_t)0x1000U)
+#define DP83848_ANNPTR_TOGGLE            ((uint16_t)0x0800U)
+#define DP83848_ANNPTR_MESSAGE_CODE      ((uint16_t)0x07FFU)
+/** @defgroup DP83848_ANNPRR_Bit_Definition DP83848 ANNPRR Bit Definition
+#define DP83848_ANNPRR_NEXT_PAGE         ((uint16_t)0x8000U)
+#define DP83848_ANNPRR_ACK               ((uint16_t)0x4000U)
+#define DP83848_ANNPRR_MESSAGE_PAGE      ((uint16_t)0x2000U)
+#define DP83848_ANNPRR_ACK2              ((uint16_t)0x1000U)
+#define DP83848_ANNPRR_TOGGLE            ((uint16_t)0x0800U)
+#define DP83848_ANNPRR_MESSAGE_CODE      ((uint16_t)0x07FFU)
+/** @defgroup DP83848_MMDACR_Bit_Definition DP83848 MMDACR Bit Definition
+#define DP83848_MMDACR_MMD_FUNCTION       ((uint16_t)0xC000U)
+#define DP83848_MMDACR_MMD_FUNCTION_ADDR  ((uint16_t)0x0000U)
+#define DP83848_MMDACR_MMD_FUNCTION_DATA  ((uint16_t)0x4000U)
+#define DP83848_MMDACR_MMD_DEV_ADDR       ((uint16_t)0x001FU)
+/** @defgroup DP83848_ENCTR_Bit_Definition DP83848 ENCTR Bit Definition
+#define DP83848_ENCTR_TX_ENABLE             ((uint16_t)0x8000U)
+#define DP83848_ENCTR_TX_TIMER              ((uint16_t)0x6000U)
+#define DP83848_ENCTR_TX_TIMER_1S           ((uint16_t)0x0000U)
+#define DP83848_ENCTR_TX_TIMER_768MS        ((uint16_t)0x2000U)
+#define DP83848_ENCTR_TX_TIMER_512MS        ((uint16_t)0x4000U)
+#define DP83848_ENCTR_TX_TIMER_265MS        ((uint16_t)0x6000U)
+#define DP83848_ENCTR_RX_ENABLE             ((uint16_t)0x1000U)
+#define DP83848_ENCTR_RX_MAX_INTERVAL       ((uint16_t)0x0C00U)
+#define DP83848_ENCTR_RX_MAX_INTERVAL_64MS  ((uint16_t)0x0000U)
+#define DP83848_ENCTR_RX_MAX_INTERVAL_256MS ((uint16_t)0x0400U)
+#define DP83848_ENCTR_RX_MAX_INTERVAL_512MS ((uint16_t)0x0800U)
+#define DP83848_ENCTR_RX_MAX_INTERVAL_1S    ((uint16_t)0x0C00U)
+#define DP83848_ENCTR_EX_CROSS_OVER         ((uint16_t)0x0002U)
+#define DP83848_ENCTR_EX_MANUAL_CROSS_OVER  ((uint16_t)0x0001U)
+/** @defgroup DP83848_MCSR_Bit_Definition DP83848 MCSR Bit Definition
+#define DP83848_MCSR_EDPWRDOWN        ((uint16_t)0x2000U)
+#define DP83848_MCSR_FARLOOPBACK      ((uint16_t)0x0200U)
+#define DP83848_MCSR_ALTINT           ((uint16_t)0x0040U)
+#define DP83848_MCSR_ENERGYON         ((uint16_t)0x0002U)
+/** @defgroup DP83848_SMR_Bit_Definition DP83848 SMR Bit Definition
+#define DP83848_SMR_MODE       ((uint16_t)0x00E0U)
+#define DP83848_SMR_PHY_ADDR   ((uint16_t)0x001FU)
+/** @defgroup DP83848_TPDCR_Bit_Definition DP83848 TPDCR Bit Definition
+#define DP83848_TPDCR_DELAY_IN                 ((uint16_t)0x8000U)
+#define DP83848_TPDCR_LINE_BREAK_COUNTER       ((uint16_t)0x7000U)
+#define DP83848_TPDCR_PATTERN_HIGH             ((uint16_t)0x0FC0U)
+#define DP83848_TPDCR_PATTERN_LOW              ((uint16_t)0x003FU)
+/** @defgroup DP83848_TCSR_Bit_Definition DP83848 TCSR Bit Definition
+#define DP83848_TCSR_TDR_ENABLE           ((uint16_t)0x8000U)
+#define DP83848_TCSR_TDR_AD_FILTER_ENABLE ((uint16_t)0x4000U)
+#define DP83848_TCSR_TDR_CH_CABLE_TYPE    ((uint16_t)0x0600U)
+#define DP83848_TCSR_TDR_CH_CABLE_DEFAULT ((uint16_t)0x0000U)
+#define DP83848_TCSR_TDR_CH_CABLE_SHORTED ((uint16_t)0x0200U)
+#define DP83848_TCSR_TDR_CH_CABLE_OPEN    ((uint16_t)0x0400U)
+#define DP83848_TCSR_TDR_CH_CABLE_MATCH   ((uint16_t)0x0600U)
+#define DP83848_TCSR_TDR_CH_STATUS        ((uint16_t)0x0100U)
+#define DP83848_TCSR_TDR_CH_LENGTH        ((uint16_t)0x00FFU)
+/** @defgroup DP83848_SCSIR_Bit_Definition DP83848 SCSIR Bit Definition
+#define DP83848_SCSIR_AUTO_MDIX_ENABLE    ((uint16_t)0x8000U)
+#define DP83848_SCSIR_CHANNEL_SELECT      ((uint16_t)0x2000U)
+#define DP83848_SCSIR_SQE_DISABLE         ((uint16_t)0x0800U)
+#define DP83848_SCSIR_XPOLALITY           ((uint16_t)0x0010U)
+/** @defgroup DP83848_CLR_Bit_Definition DP83848 CLR Bit Definition
+#define DP83848_CLR_CABLE_LENGTH       ((uint16_t)0xF000U)
+/** @defgroup DP83848_IMR_ISFR_Bit_Definition DP83848 IMR ISFR Bit Definition
+#define DP83848_INT_8       ((uint16_t)0x0100U)
+#define DP83848_INT_7       ((uint16_t)0x0080U)
+#define DP83848_INT_6       ((uint16_t)0x0040U)
+#define DP83848_INT_5       ((uint16_t)0x0020U)
+#define DP83848_INT_4       ((uint16_t)0x0010U)
+#define DP83848_INT_3       ((uint16_t)0x0008U)
+#define DP83848_INT_2       ((uint16_t)0x0004U)
+#define DP83848_INT_1       ((uint16_t)0x0002U)
+/** @defgroup DP83848_PHYSCSR_Bit_Definition DP83848 PHYSCSR Bit Definition
+#define DP83848_PHYSCSR_AUTONEGO_DONE   ((uint16_t)0x100U)
+#define DP83848_PHYSCSR_HCDSPEEDMASK    ((uint16_t)0x006U)
+#define DP83848_PHYSCSR_10BT_HD         ((uint16_t)0x002U)
+#define DP83848_PHYSCSR_10BT_FD         ((uint16_t)0x006U)
+#define DP83848_PHYSCSR_100BTX_HD       ((uint16_t)0x000U)
+#define DP83848_PHYSCSR_100BTX_FD       ((uint16_t)0x004U)
+/** @defgroup DP83848_Status DP83848 Status
+#define  DP83848_STATUS_READ_ERROR            ((int32_t)-5)
+#define  DP83848_STATUS_WRITE_ERROR           ((int32_t)-4)
+#define  DP83848_STATUS_ADDRESS_ERROR         ((int32_t)-3)
+#define  DP83848_STATUS_RESET_TIMEOUT         ((int32_t)-2)
+#define  DP83848_STATUS_ERROR                 ((int32_t)-1)
+#define  DP83848_STATUS_OK                    ((int32_t) 0)
+#define  DP83848_STATUS_LINK_DOWN             ((int32_t) 1)
+#define  DP83848_STATUS_100MBITS_FULLDUPLEX   ((int32_t) 2)
+#define  DP83848_STATUS_100MBITS_HALFDUPLEX   ((int32_t) 3)
+#define  DP83848_STATUS_10MBITS_FULLDUPLEX    ((int32_t) 4)
+#define  DP83848_STATUS_10MBITS_HALFDUPLEX    ((int32_t) 5)
+#define  DP83848_STATUS_AUTONEGO_NOTDONE      ((int32_t) 6)
+/** @defgroup DP83848_IT_Flags DP83848 IT Flags
+#define  DP83848_WOL_IT                        DP83848_INT_8
+#define  DP83848_ENERGYON_IT                   DP83848_INT_7
+#define  DP83848_AUTONEGO_COMPLETE_IT          DP83848_INT_6
+#define  DP83848_REMOTE_FAULT_IT               DP83848_INT_5
+#define  DP83848_LINK_DOWN_IT                  DP83848_INT_4
+#define  DP83848_AUTONEGO_LP_ACK_IT            DP83848_INT_3
+#define  DP83848_PARALLEL_DETECTION_FAULT_IT   DP83848_INT_2
+#define  DP83848_AUTONEGO_PAGE_RECEIVED_IT     DP83848_INT_1
+/* Exported types ------------------------------------------------------------*/
+/** @defgroup DP83848_Exported_Types DP83848 Exported Types
+typedef int32_t  (*dp83848_Init_Func) (void);
+typedef int32_t  (*dp83848_DeInit_Func) (void);
+typedef int32_t  (*dp83848_ReadReg_Func)   (uint32_t, uint32_t, uint32_t *);
+typedef int32_t  (*dp83848_WriteReg_Func)  (uint32_t, uint32_t, uint32_t);
+typedef int32_t  (*dp83848_GetTick_Func)  (void);
+typedef struct
+  dp83848_Init_Func      Init;
+  dp83848_DeInit_Func    DeInit;
+  dp83848_WriteReg_Func  WriteReg;
+  dp83848_ReadReg_Func   ReadReg;
+  dp83848_GetTick_Func   GetTick;
+} dp83848_IOCtx_t;
+typedef struct
+  uint32_t            DevAddr;
+  uint32_t            Is_Initialized;
+  dp83848_IOCtx_t     IO;
+  void               *pData;
+}dp83848_Object_t;
+/* Exported macro ------------------------------------------------------------*/
+/* Exported functions --------------------------------------------------------*/
+/** @defgroup DP83848_Exported_Functions DP83848 Exported Functions
+int32_t DP83848_RegisterBusIO(dp83848_Object_t *pObj, dp83848_IOCtx_t *ioctx);
+int32_t DP83848_Init(dp83848_Object_t *pObj);
+int32_t DP83848_DeInit(dp83848_Object_t *pObj);
+int32_t DP83848_DisablePowerDownMode(dp83848_Object_t *pObj);
+int32_t DP83848_EnablePowerDownMode(dp83848_Object_t *pObj);
+int32_t DP83848_StartAutoNego(dp83848_Object_t *pObj);
+int32_t DP83848_GetLinkState(dp83848_Object_t *pObj);
+int32_t DP83848_SetLinkState(dp83848_Object_t *pObj, uint32_t LinkState);
+int32_t DP83848_EnableLoopbackMode(dp83848_Object_t *pObj);
+int32_t DP83848_DisableLoopbackMode(dp83848_Object_t *pObj);
+int32_t DP83848_EnableIT(dp83848_Object_t *pObj, uint32_t Interrupt);
+int32_t DP83848_DisableIT(dp83848_Object_t *pObj, uint32_t Interrupt);
+int32_t DP83848_ClearIT(dp83848_Object_t *pObj, uint32_t Interrupt);
+int32_t DP83848_GetITStatus(dp83848_Object_t *pObj, uint32_t Interrupt);
+#ifdef __cplusplus
+#endif
+#endif /* DP83848_H */
diff --git a/stm32/ethernetif.c b/stm32/ethernetif.c
index ac023a0..c32ad45 100644
--- a/stm32/ethernetif.c
+++ b/stm32/ethernetif.c
@@ -1,986 +1,986 @@
-  * File Name          : ethernetif.c
-  * Description        : This file provides code for the configuration
-  *                      of the ethernetif.c MiddleWare.
-  * @attention
-#ifndef __rtems__
-#include "main.h"
-#else
-#include <bsp.h>
-#include <bsp/irq.h>
-#endif /* __rtems__ */
-#include "lwip/opt.h"
-#include "lwip/timeouts.h"
-#include "netif/ethernet.h"
-#include "netif/etharp.h"
-#include "lwip/ethip6.h"
-#include "ethernetif.h"
-#include <string.h>
-#ifndef __rtems__
-#include "cmsis_os.h"
-#include "lwip/tcpip.h"
-/* The time to block waiting for input. */
-#ifndef __rtems__
-#define TIME_WAITING_FOR_INPUT ( portMAX_DELAY )
-#else
-#define TIME_WAITING_FOR_INPUT ( RTEMS_NO_TIMEOUT )
-/* USER CODE BEGIN OS_THREAD_STACK_SIZE_WITH_RTOS */
-/* Stack size of the interface thread */
-#define INTERFACE_THREAD_STACK_SIZE ( 350 )
-/* USER CODE END OS_THREAD_STACK_SIZE_WITH_RTOS */
-/* Network interface name */
-#define IFNAME0 's'
-#define IFNAME1 't'
-/* ETH Setting  */
-#define ETH_DMA_TRANSMIT_TIMEOUT               ( 20U )
-#define ETH_TX_BUFFER_MAX             ((ETH_TX_DESC_CNT) * 2U)
-/* ETH_RX_BUFFER_SIZE parameter is defined in lwipopts.h */
- at Note: This interface is implemented to operate in zero-copy mode only:
-        - Rx buffers are allocated statically and passed directly to the LwIP stack
-          they will return back to ETH DMA after been processed by the stack.
-        - Tx Buffers will be allocated from LwIP stack memory heap,
-          then passed to ETH HAL driver.
- at Notes:
-  1.a. ETH DMA Rx descriptors must be contiguous, the default count is 4,
-       to customize it please redefine ETH_RX_DESC_CNT in ETH GUI (Rx Descriptor Length)
-       so that updated value will be generated in stm32xxxx_hal_conf.h
-  1.b. ETH DMA Tx descriptors must be contiguous, the default count is 4,
-       to customize it please redefine ETH_TX_DESC_CNT in ETH GUI (Tx Descriptor Length)
-  2.a. Rx Buffers number must be between ETH_RX_DESC_CNT and 2*ETH_RX_DESC_CNT
-  2.b. Rx Buffers must have the same size: ETH_RX_BUFFER_SIZE, this value must
-       passed to ETH DMA in the init field (heth.Init.RxBuffLen)
-  2.c  The RX Ruffers addresses and sizes must be properly defined to be aligned
-       to L1-CACHE line size (32 bytes).
-/* Data Type Definitions */
-typedef enum
-  RX_ALLOC_OK       = 0x00,
-  RX_ALLOC_ERROR    = 0x01
-} RxAllocStatusTypeDef;
-typedef struct
-  struct pbuf_custom pbuf_custom;
-  uint8_t buff[(ETH_RX_BUFFER_SIZE + 31) & ~31] __ALIGNED(32);
-} RxBuff_t;
-/* Memory Pool Declaration */
-#define ETH_RX_BUFFER_CNT             12U
-LWIP_MEMPOOL_DECLARE(RX_POOL, ETH_RX_BUFFER_CNT, sizeof(RxBuff_t), "Zero-copy RX PBUF pool");
-/* Variable Definitions */
-static uint8_t RxAllocStatus;
-__IO uint32_t TxPkt = 0;
-__IO uint32_t RxPkt = 0;
-ETH_DMADescTypeDef  DMARxDscrTab[ETH_RX_DESC_CNT]; /* Ethernet Rx DMA Descriptors */
-ETH_DMADescTypeDef  DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet Tx DMA Descriptors */
-/* USER CODE BEGIN 2 */
-/* USER CODE END 2 */
-#ifndef __rtems__
-osSemaphoreId RxPktSemaphore = NULL;   /* Semaphore to signal incoming packets */
-osSemaphoreId TxPktSemaphore = NULL;   /* Semaphore to signal transmit packet complete */
-#else
-rtems_id RxPktSemaphore;   /* Semaphore to signal incoming packets */
-rtems_id TxPktSemaphore;   /* Semaphore to signal transmit packet complete */
-/* Global Ethernet handle */
-ETH_HandleTypeDef heth;
-ETH_TxPacketConfig TxConfig;
-#ifdef __rtems__
-static uint8_t *MACAddr;
-int32_t ETH_PHY_IO_Init(void);
-int32_t ETH_PHY_IO_DeInit (void);
-int32_t ETH_PHY_IO_ReadReg(uint32_t DevAddr, uint32_t RegAddr, uint32_t *pRegVal);
-int32_t ETH_PHY_IO_WriteReg(uint32_t DevAddr, uint32_t RegAddr, uint32_t RegVal);
-int32_t ETH_PHY_IO_GetTick(void);
-dp83848_Object_t DP83848;
-dp83848_IOCtx_t  DP83848_IOCtx = {ETH_PHY_IO_Init,
-                                  ETH_PHY_IO_DeInit,
-                                  ETH_PHY_IO_WriteReg,
-                                  ETH_PHY_IO_ReadReg,
-                                  ETH_PHY_IO_GetTick};
-/* USER CODE BEGIN 3 */
-/* USER CODE END 3 */
-void pbuf_free_custom(struct pbuf *p);
-  * @brief  Ethernet Rx Transfer completed callback
-  * @param  handlerEth: ETH handler
-  * @retval None
-void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *handlerEth)
-#ifndef __rtems__
-  osSemaphoreRelease(RxPktSemaphore);
-#else
-  rtems_semaphore_release(RxPktSemaphore);
-  * @brief  Ethernet Tx Transfer completed callback
-  * @retval None
-void HAL_ETH_TxCpltCallback(ETH_HandleTypeDef *handlerEth)
-#ifndef __rtems__
-  osSemaphoreRelease(TxPktSemaphore);
-#else
-  rtems_semaphore_release(TxPktSemaphore);
-  * @brief  Ethernet DMA transfer error callback
-  * @retval None
-void HAL_ETH_ErrorCallback(ETH_HandleTypeDef *handlerEth)
-  if((HAL_ETH_GetDMAError(handlerEth) & ETH_DMASR_RBUS) == ETH_DMASR_RBUS)
-#ifndef __rtems__
-#else
-/* USER CODE BEGIN 4 */
-#ifdef __rtems__
-void set_mac_addr(uint8_t *mac_addr)
-  MACAddr = mac_addr;
-/* USER CODE END 4 */
-                       LL Driver Interface ( LwIP stack --> ETH)
- * @brief In this function, the hardware should be initialized.
- * Called from ethernetif_init().
- * @param netif the already initialized lwip network interface structure
- *        for this ethernetif
-static void low_level_init(struct netif *netif)
-  HAL_StatusTypeDef hal_eth_init_status = HAL_OK;
-/* USER CODE BEGIN OS_THREAD_ATTR_CMSIS_RTOS_V2 */
-#ifndef __rtems__
-  osThreadAttr_t attributes;
-/* USER CODE END OS_THREAD_ATTR_CMSIS_RTOS_V2 */
-  uint32_t duplex, speed = 0;
-  int32_t PHYLinkState = 0;
-  ETH_MACConfigTypeDef MACConf = {0};
-  /* Start ETH HAL Init */
-#ifndef __rtems__
-   uint8_t MACAddr[6] ;
-  heth.Instance = ETH;
-#ifndef __rtems__
-  MACAddr[0] = 0x02;
-  MACAddr[1] = 0x00;
-  MACAddr[2] = 0x00;
-  MACAddr[3] = 0x00;
-  MACAddr[4] = 0x00;
-  MACAddr[5] = 0x01;
-  heth.Init.MACAddr = &MACAddr[0];
-#else
-  heth.Init.MACAddr = MACAddr;
-  heth.Init.MediaInterface = HAL_ETH_RMII_MODE;
-  heth.Init.TxDesc = DMATxDscrTab;
-  heth.Init.RxDesc = DMARxDscrTab;
-  heth.Init.RxBuffLen = 1536;
-  /* USER CODE BEGIN MACADDRESS */
-  /* USER CODE END MACADDRESS */
-  hal_eth_init_status = HAL_ETH_Init(&heth);
-  memset(&TxConfig, 0 , sizeof(ETH_TxPacketConfig));
-  TxConfig.Attributes = ETH_TX_PACKETS_FEATURES_CSUM | ETH_TX_PACKETS_FEATURES_CRCPAD;
-  TxConfig.ChecksumCtrl = ETH_CHECKSUM_IPHDR_PAYLOAD_INSERT_PHDR_CALC;
-  TxConfig.CRCPadCtrl = ETH_CRC_PAD_INSERT;
-  /* End ETH HAL Init */
-  /* Initialize the RX POOL */
-  LWIP_MEMPOOL_INIT(RX_POOL);
-#if LWIP_ARP || LWIP_ETHERNET
-  /* set MAC hardware address length */
-  netif->hwaddr_len = ETH_HWADDR_LEN;
-  /* set MAC hardware address */
-  netif->hwaddr[0] =  heth.Init.MACAddr[0];
-  netif->hwaddr[1] =  heth.Init.MACAddr[1];
-  netif->hwaddr[2] =  heth.Init.MACAddr[2];
-  netif->hwaddr[3] =  heth.Init.MACAddr[3];
-  netif->hwaddr[4] =  heth.Init.MACAddr[4];
-  netif->hwaddr[5] =  heth.Init.MACAddr[5];
-  /* maximum transfer unit */
-  netif->mtu = ETH_MAX_PAYLOAD;
-  /* Accept broadcast address and ARP traffic */
-  /* don't set NETIF_FLAG_ETHARP if this device is not an ethernet one */
-  #if LWIP_ARP
-    netif->flags |= NETIF_FLAG_BROADCAST | NETIF_FLAG_ETHARP;
-  #else
-    netif->flags |= NETIF_FLAG_BROADCAST;
-  #endif /* LWIP_ARP */
-  /* create a binary semaphore used for informing ethernetif of frame reception */
-#ifndef __rtems__
-  RxPktSemaphore = osSemaphoreNew(1, 1, NULL);
-#else
-  rtems_semaphore_create(
-    rtems_build_name('R', 'x', 'p', 'k'),
-    1,
-    RTEMS_SIMPLE_BINARY_SEMAPHORE,
-    0,
-    &RxPktSemaphore
-  /* create a binary semaphore used for informing ethernetif of frame transmission */
-#ifndef __rtems__
-  TxPktSemaphore = osSemaphoreNew(1, 1, NULL);
-#else
-    rtems_build_name('T', 'x', 'p', 'k'),
-    1,
-    0,
-    &TxPktSemaphore
-  /* create the task that handles the ETH_MAC */
-/* USER CODE BEGIN OS_THREAD_NEW_CMSIS_RTOS_V2 */
-#ifndef __rtems__
-  memset(&attributes, 0x0, sizeof(osThreadAttr_t));
-  attributes.name = "EthIf";
-  attributes.stack_size = INTERFACE_THREAD_STACK_SIZE;
-  attributes.priority = osPriorityRealtime;
-  osThreadNew(ethernetif_input, netif, &attributes);
-#else
-  sys_thread_new(
-    "ethernetif_input_thread",
-    ethernetif_input,
-    netif,
-    RTEMS_MINIMUM_STACK_SIZE,
-    DEFAULT_THREAD_PRIO
-#endif /* __rtem__ */
-/* USER CODE END OS_THREAD_NEW_CMSIS_RTOS_V2 */
-/* USER CODE BEGIN PHY_PRE_CONFIG */
-/* USER CODE END PHY_PRE_CONFIG */
-  /* Set PHY IO functions */
-  DP83848_RegisterBusIO(&DP83848, &DP83848_IOCtx);
-  /* Initialize the DP83848 ETH PHY */
-  DP83848_Init(&DP83848);
-  if (hal_eth_init_status == HAL_OK)
-    PHYLinkState = DP83848_GetLinkState(&DP83848);
-    /* Get link state */
-    if(PHYLinkState <= DP83848_STATUS_LINK_DOWN)
-      netif_set_link_down(netif);
-      netif_set_down(netif);
-    else
-      switch (PHYLinkState)
-      case DP83848_STATUS_100MBITS_FULLDUPLEX:
-        duplex = ETH_FULLDUPLEX_MODE;
-        speed = ETH_SPEED_100M;
-        break;
-      case DP83848_STATUS_100MBITS_HALFDUPLEX:
-        duplex = ETH_HALFDUPLEX_MODE;
-        break;
-      case DP83848_STATUS_10MBITS_FULLDUPLEX:
-        speed = ETH_SPEED_10M;
-        break;
-      case DP83848_STATUS_10MBITS_HALFDUPLEX:
-        break;
-      default:
-        break;
-    /* Get MAC Config MAC */
-    HAL_ETH_GetMACConfig(&heth, &MACConf);
-    MACConf.DuplexMode = duplex;
-    MACConf.Speed = speed;
-    HAL_ETH_SetMACConfig(&heth, &MACConf);
-#ifdef __rtems__
-    rtems_interrupt_handler_install(
-            STM32F4_IRQ_ETH,
-            NULL,
-            RTEMS_INTERRUPT_UNIQUE,
-            HAL_ETH_IRQHandler,
-            &heth
-    HAL_ETH_Start_IT(&heth);
-    netif_set_up(netif);
-    netif_set_link_up(netif);
-/* USER CODE BEGIN PHY_POST_CONFIG */
-/* USER CODE END PHY_POST_CONFIG */
-  else
-    Error_Handler();
-#endif /* LWIP_ARP || LWIP_ETHERNET */
-/* USER CODE BEGIN LOW_LEVEL_INIT */
-/* USER CODE END LOW_LEVEL_INIT */
- * This function should do the actual transmission of the packet. The packet is
- * contained in the pbuf that is passed to the function. This pbuf
- * might be chained.
- * @param netif the lwip network interface structure for this ethernetif
- * @param p the MAC packet to send (e.g. IP packet including MAC addresses and type)
- * @return ERR_OK if the packet could be sent
- *         an err_t value if the packet couldn't be sent
- * @note Returning ERR_MEM here if a DMA queue of your MAC is full can lead to
- *       strange results. You might consider waiting for space in the DMA queue
- *       to become available since the stack doesn't retry to send a packet
- *       dropped because of memory failure (except for the TCP timers).
-static err_t low_level_output(struct netif *netif, struct pbuf *p)
-  uint32_t i = 0U;
-  struct pbuf *q = NULL;
-  err_t errval = ERR_OK;
-  ETH_BufferTypeDef Txbuffer[ETH_TX_DESC_CNT];
-  memset(Txbuffer, 0 , ETH_TX_DESC_CNT*sizeof(ETH_BufferTypeDef));
-  for(q = p; q != NULL; q = q->next)
-    if(i >= ETH_TX_DESC_CNT)
-      return ERR_IF;
-    Txbuffer[i].buffer = q->payload;
-    Txbuffer[i].len = q->len;
-    if(i>0)
-      Txbuffer[i-1].next = &Txbuffer[i];
-    if(q->next == NULL)
-      Txbuffer[i].next = NULL;
-    i++;
-  TxConfig.Length = p->tot_len;
-  TxConfig.TxBuffer = Txbuffer;
-  TxConfig.pData = p;
-  pbuf_ref(p);
-  HAL_ETH_Transmit_IT(&heth, &TxConfig);
-#ifndef __rtems__
-  while(osSemaphoreAcquire(TxPktSemaphore, TIME_WAITING_FOR_INPUT)!=osOK)
-#else
-  while (rtems_semaphore_obtain(TxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
-          TIME_WAITING_FOR_INPUT) != RTEMS_SUCCESSFUL)
-  HAL_ETH_ReleaseTxPacket(&heth);
-  return errval;
- * Should allocate a pbuf and transfer the bytes of the incoming
- * packet from the interface into the pbuf.
- * @return a pbuf filled with the received packet (including MAC header)
- *         NULL on memory error
-static struct pbuf * low_level_input(struct netif *netif)
-  struct pbuf *p = NULL;
-  if(RxAllocStatus == RX_ALLOC_OK)
-    HAL_ETH_ReadData(&heth, (void **)&p);
-  return p;
- * This function should be called when a packet is ready to be read
- * from the interface. It uses the function low_level_input() that
- * should handle the actual reception of bytes from the network
- * interface. Then the type of the received packet is determined and
- * the appropriate input function is called.
-void ethernetif_input(void* argument)
-  struct netif *netif = (struct netif *) argument;
-  for( ;; )
-#ifndef __rtems__
-    if (osSemaphoreAcquire(RxPktSemaphore, TIME_WAITING_FOR_INPUT) == osOK)
-#else
-    if (rtems_semaphore_obtain(RxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
-            TIME_WAITING_FOR_INPUT) == RTEMS_SUCCESSFUL)
-      do
-        p = low_level_input( netif );
-        if (p != NULL)
-          if (netif->input( p, netif) != ERR_OK )
-            pbuf_free(p);
-      } while(p!=NULL);
-#if !LWIP_ARP
- * This function has to be completed by user in case of ARP OFF.
- * @return ERR_OK if ...
-static err_t low_level_output_arp_off(struct netif *netif, struct pbuf *q, const ip4_addr_t *ipaddr)
-  err_t errval;
-  errval = ERR_OK;
-/* USER CODE BEGIN 5 */
-/* USER CODE END 5 */
-  return errval;
-#endif /* LWIP_ARP */
- * Should be called at the beginning of the program to set up the
- * network interface. It calls the function low_level_init() to do the
- * actual setup of the hardware.
- * This function should be passed as a parameter to netif_add().
- * @return ERR_OK if the loopif is initialized
- *         ERR_MEM if private data couldn't be allocated
- *         any other err_t on error
-err_t ethernetif_init(struct netif *netif)
-  LWIP_ASSERT("netif != NULL", (netif != NULL));
-#if LWIP_NETIF_HOSTNAME
-  /* Initialize interface hostname */
-  netif->hostname = "lwip";
-#endif /* LWIP_NETIF_HOSTNAME */
-   * Initialize the snmp variables and counters inside the struct netif.
-   * The last argument should be replaced with your link speed, in units
-   * of bits per second.
-  // MIB2_INIT_NETIF(netif, snmp_ifType_ethernet_csmacd, LINK_SPEED_OF_YOUR_NETIF_IN_BPS);
-  netif->name[0] = IFNAME0;
-  netif->name[1] = IFNAME1;
-  /* We directly use etharp_output() here to save a function call.
-   * You can instead declare your own function an call etharp_output()
-   * from it if you have to do some checks before sending (e.g. if link
-   * is available...) */
-#if LWIP_IPV4
-#if LWIP_ARP
-  netif->output = etharp_output;
-#else
-  /* The user should write its own code in low_level_output_arp_off function */
-  netif->output = low_level_output_arp_off;
-#endif /* LWIP_IPV4 */
-#if LWIP_IPV6
-  netif->output_ip6 = ethip6_output;
-#endif /* LWIP_IPV6 */
-  netif->linkoutput = low_level_output;
-  /* initialize the hardware */
-  low_level_init(netif);
-  return ERR_OK;
-  * @brief  Custom Rx pbuf free callback
-  * @param  pbuf: pbuf to be freed
-  * @retval None
-  struct pbuf_custom* custom_pbuf = (struct pbuf_custom*)p;
-  LWIP_MEMPOOL_FREE(RX_POOL, custom_pbuf);
-  /* If the Rx Buffer Pool was exhausted, signal the ethernetif_input task to
-   * call HAL_ETH_GetRxDataBuffer to rebuild the Rx descriptors. */
-  if (RxAllocStatus == RX_ALLOC_ERROR)
-    RxAllocStatus = RX_ALLOC_OK;
-#ifndef __rtems__
-#else
-/* USER CODE BEGIN 6 */
-#ifndef __rtems__
-* @brief  Returns the current time in milliseconds
-*         when LWIP_TIMERS == 1 and NO_SYS == 1
-* @param  None
-* @retval Current Time value
-u32_t sys_now(void)
-  return HAL_GetTick();
-/* USER CODE END 6 */
-void HAL_ETH_MspInit(ETH_HandleTypeDef* ethHandle)
-  GPIO_InitTypeDef GPIO_InitStruct = {0};
-  if(ethHandle->Instance==ETH)
-  /* USER CODE BEGIN ETH_MspInit 0 */
-  /* USER CODE END ETH_MspInit 0 */
-    /* Enable Peripheral clock */
-    __HAL_RCC_ETH_CLK_ENABLE();
-    __HAL_RCC_GPIOC_CLK_ENABLE();
-    __HAL_RCC_GPIOA_CLK_ENABLE();
-    __HAL_RCC_GPIOB_CLK_ENABLE();
-    /**ETH GPIO Configuration
-    PC1     ------> ETH_MDC
-    PA1     ------> ETH_REF_CLK
-    PA2     ------> ETH_MDIO
-    PA7     ------> ETH_CRS_DV
-    PC4     ------> ETH_RXD0
-    PC5     ------> ETH_RXD1
-    PB11     ------> ETH_TX_EN
-    PB12     ------> ETH_TXD0
-    PB13     ------> ETH_TXD1
-    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
-    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
-    GPIO_InitStruct.Pull = GPIO_NOPULL;
-    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
-    GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
-    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
-    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7;
-    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
-    GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13;
-    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
-    /* Peripheral interrupt init */
-#ifndef __rtems__
-    HAL_NVIC_SetPriority(ETH_IRQn, 5, 0);
-    HAL_NVIC_EnableIRQ(ETH_IRQn);
-  /* USER CODE BEGIN ETH_MspInit 1 */
-  /* USER CODE END ETH_MspInit 1 */
-void HAL_ETH_MspDeInit(ETH_HandleTypeDef* ethHandle)
-  /* USER CODE BEGIN ETH_MspDeInit 0 */
-  /* USER CODE END ETH_MspDeInit 0 */
-    /* Peripheral clock disable */
-    __HAL_RCC_ETH_CLK_DISABLE();
-    HAL_GPIO_DeInit(GPIOC, GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5);
-    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7);
-    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13);
-    /* Peripheral interrupt Deinit*/
-    HAL_NVIC_DisableIRQ(ETH_IRQn);
-  /* USER CODE BEGIN ETH_MspDeInit 1 */
-  /* USER CODE END ETH_MspDeInit 1 */
-                       PHI IO Functions
-  * @brief  Initializes the MDIO interface GPIO and clocks.
-  * @param  None
-  * @retval 0 if OK, -1 if ERROR
-  /* We assume that MDIO GPIO configuration is already done
-     in the ETH_MspInit() else it should be done here
-  /* Configure the MDIO Clock */
-  HAL_ETH_SetMDIOClockRange(&heth);
-  return 0;
-  * @brief  De-Initializes the MDIO interface .
-  * @param  None
-  return 0;
-  * @brief  Read a PHY register through the MDIO interface.
-  * @param  DevAddr: PHY port address
-  * @param  RegAddr: PHY register address
-  * @param  pRegVal: pointer to hold the register value
-  * @retval 0 if OK -1 if Error
-  if(HAL_ETH_ReadPHYRegister(&heth, DevAddr, RegAddr, pRegVal) != HAL_OK)
-    return -1;
-  return 0;
-  * @brief  Write a value to a PHY register through the MDIO interface.
-  * @param  RegVal: Value to be written
-  if(HAL_ETH_WritePHYRegister(&heth, DevAddr, RegAddr, RegVal) != HAL_OK)
-    return -1;
-  return 0;
-  * @brief  Get the time in millisecons used for internal PHY driver process.
-  * @retval Time value
-  * @brief  Check the ETH link state then update ETH driver and netif link accordingly.
-  * @param  argument: netif
-  * @retval None
-void ethernet_link_thread(void* argument)
-  uint32_t linkchanged = 0U, speed = 0U, duplex = 0U;
-/* USER CODE BEGIN ETH link init */
-/* USER CODE END ETH link init */
-  for(;;)
-  if(netif_is_link_up(netif) && (PHYLinkState <= DP83848_STATUS_LINK_DOWN))
-    HAL_ETH_Stop_IT(&heth);
-  else if(!netif_is_link_up(netif) && (PHYLinkState > DP83848_STATUS_LINK_DOWN))
-      linkchanged = 1;
-      break;
-      linkchanged = 1;
-      break;
-      linkchanged = 1;
-      break;
-      linkchanged = 1;
-      break;
-    default:
-      break;
-    if(linkchanged)
-      HAL_ETH_Start(&heth);
-/* USER CODE BEGIN ETH link Thread core code for User BSP */
-/* USER CODE END ETH link Thread core code for User BSP */
-#ifndef __rtems__
-    osDelay(100);
-#else
-    sys_arch_delay(100);
-void HAL_ETH_RxAllocateCallback(uint8_t **buff)
-/* USER CODE BEGIN HAL ETH RxAllocateCallback */
-  struct pbuf_custom *p = LWIP_MEMPOOL_ALLOC(RX_POOL);
-  if (p)
-    /* Get the buff from the struct pbuf address. */
-    *buff = (uint8_t *)p + offsetof(RxBuff_t, buff);
-    p->custom_free_function = pbuf_free_custom;
-    /* Initialize the struct pbuf.
-    * This must be performed whenever a buffer's allocated because it may be
-    * changed by lwIP or the app, e.g., pbuf_free decrements ref. */
-    pbuf_alloced_custom(PBUF_RAW, 0, PBUF_REF, p, *buff, ETH_RX_BUFFER_SIZE);
-  else
-    RxAllocStatus = RX_ALLOC_ERROR;
-    *buff = NULL;
-/* USER CODE END HAL ETH RxAllocateCallback */
-void HAL_ETH_RxLinkCallback(void **pStart, void **pEnd, uint8_t *buff, uint16_t Length)
-/* USER CODE BEGIN HAL ETH RxLinkCallback */
-  struct pbuf **ppStart = (struct pbuf **)pStart;
-  struct pbuf **ppEnd = (struct pbuf **)pEnd;
-  /* Get the struct pbuf from the buff address. */
-  p = (struct pbuf *)(buff - offsetof(RxBuff_t, buff));
-  p->next = NULL;
-  p->tot_len = 0;
-  p->len = Length;
-  /* Chain the buffer. */
-  if (!*ppStart)
-    /* The first buffer of the packet. */
-    *ppStart = p;
-  else
-    /* Chain the buffer to the end of the packet. */
-    (*ppEnd)->next = p;
-  *ppEnd  = p;
-  /* Update the total length of all the buffers of the chain. Each pbuf in the chain should have its tot_len
-   * set to its own length, plus the length of all the following pbufs in the chain. */
-  for (p = *ppStart; p != NULL; p = p->next)
-    p->tot_len += Length;
-/* USER CODE END HAL ETH RxLinkCallback */
-void HAL_ETH_TxFreeCallback(uint32_t * buff)
-/* USER CODE BEGIN HAL ETH TxFreeCallback */
-  pbuf_free((struct pbuf *)buff);
-/* USER CODE END HAL ETH TxFreeCallback */
-/* USER CODE BEGIN 8 */
-/* USER CODE END 8 */
+/* USER CODE BEGIN Header */
+  * File Name          : ethernetif.c
+  * Description        : This file provides code for the configuration
+  *                      of the ethernetif.c MiddleWare.
+  * @attention
+  * Copyright (c) 2022 STMicroelectronics.
+  * This software is licensed under terms that can be found in the LICENSE file
+  * in the root directory of this software component.
+  * If no LICENSE file comes with this software, it is provided AS-IS.
+/* USER CODE END Header */
+#ifndef __rtems__
+#include "main.h"
+#else
+#include <bsp.h>
+#include <bsp/irq.h>
+#endif /* __rtems__ */
+#include "lwip/opt.h"
+#include "lwip/timeouts.h"
+#include "netif/ethernet.h"
+#include "netif/etharp.h"
+#include "lwip/ethip6.h"
+#include "ethernetif.h"
+#include <string.h>
+#ifndef __rtems__
+#include "cmsis_os.h"
+#include "lwip/tcpip.h"
+/* Within 'USER CODE' section, code will be kept by default at each generation */
+/* USER CODE BEGIN 0 */
+/* USER CODE END 0 */
+/* The time to block waiting for input. */
+#ifndef __rtems__
+#define TIME_WAITING_FOR_INPUT ( portMAX_DELAY )
+#else
+#define TIME_WAITING_FOR_INPUT ( RTEMS_NO_TIMEOUT )
+/* USER CODE BEGIN OS_THREAD_STACK_SIZE_WITH_RTOS */
+/* Stack size of the interface thread */
+#define INTERFACE_THREAD_STACK_SIZE ( 350 )
+/* USER CODE END OS_THREAD_STACK_SIZE_WITH_RTOS */
+/* Network interface name */
+#define IFNAME0 's'
+#define IFNAME1 't'
+/* ETH Setting  */
+#define ETH_DMA_TRANSMIT_TIMEOUT               ( 20U )
+#define ETH_TX_BUFFER_MAX             ((ETH_TX_DESC_CNT) * 2U)
+/* ETH_RX_BUFFER_SIZE parameter is defined in lwipopts.h */
+/* USER CODE BEGIN 1 */
+/* USER CODE END 1 */
+ at Note: This interface is implemented to operate in zero-copy mode only:
+        - Rx buffers are allocated statically and passed directly to the LwIP stack
+          they will return back to ETH DMA after been processed by the stack.
+        - Tx Buffers will be allocated from LwIP stack memory heap,
+          then passed to ETH HAL driver.
+ at Notes:
+  1.a. ETH DMA Rx descriptors must be contiguous, the default count is 4,
+       to customize it please redefine ETH_RX_DESC_CNT in ETH GUI (Rx Descriptor Length)
+       so that updated value will be generated in stm32xxxx_hal_conf.h
+  1.b. ETH DMA Tx descriptors must be contiguous, the default count is 4,
+       to customize it please redefine ETH_TX_DESC_CNT in ETH GUI (Tx Descriptor Length)
+  2.a. Rx Buffers number must be between ETH_RX_DESC_CNT and 2*ETH_RX_DESC_CNT
+  2.b. Rx Buffers must have the same size: ETH_RX_BUFFER_SIZE, this value must
+       passed to ETH DMA in the init field (heth.Init.RxBuffLen)
+  2.c  The RX Ruffers addresses and sizes must be properly defined to be aligned
+       to L1-CACHE line size (32 bytes).
+/* Data Type Definitions */
+typedef enum
+  RX_ALLOC_OK       = 0x00,
+  RX_ALLOC_ERROR    = 0x01
+} RxAllocStatusTypeDef;
+typedef struct
+  struct pbuf_custom pbuf_custom;
+  uint8_t buff[(ETH_RX_BUFFER_SIZE + 31) & ~31] __ALIGNED(32);
+} RxBuff_t;
+/* Memory Pool Declaration */
+#define ETH_RX_BUFFER_CNT             12U
+LWIP_MEMPOOL_DECLARE(RX_POOL, ETH_RX_BUFFER_CNT, sizeof(RxBuff_t), "Zero-copy RX PBUF pool");
+/* Variable Definitions */
+static uint8_t RxAllocStatus;
+__IO uint32_t TxPkt = 0;
+__IO uint32_t RxPkt = 0;
+ETH_DMADescTypeDef  DMARxDscrTab[ETH_RX_DESC_CNT]; /* Ethernet Rx DMA Descriptors */
+ETH_DMADescTypeDef  DMATxDscrTab[ETH_TX_DESC_CNT]; /* Ethernet Tx DMA Descriptors */
+/* USER CODE BEGIN 2 */
+/* USER CODE END 2 */
+#ifndef __rtems__
+osSemaphoreId RxPktSemaphore = NULL;   /* Semaphore to signal incoming packets */
+osSemaphoreId TxPktSemaphore = NULL;   /* Semaphore to signal transmit packet complete */
+#else
+rtems_id RxPktSemaphore;   /* Semaphore to signal incoming packets */
+rtems_id TxPktSemaphore;   /* Semaphore to signal transmit packet complete */
+/* Global Ethernet handle */
+ETH_HandleTypeDef heth;
+ETH_TxPacketConfig TxConfig;
+#ifdef __rtems__
+static uint8_t *MACAddr;
+int32_t ETH_PHY_IO_Init(void);
+int32_t ETH_PHY_IO_DeInit (void);
+int32_t ETH_PHY_IO_ReadReg(uint32_t DevAddr, uint32_t RegAddr, uint32_t *pRegVal);
+int32_t ETH_PHY_IO_WriteReg(uint32_t DevAddr, uint32_t RegAddr, uint32_t RegVal);
+int32_t ETH_PHY_IO_GetTick(void);
+dp83848_Object_t DP83848;
+dp83848_IOCtx_t  DP83848_IOCtx = {ETH_PHY_IO_Init,
+                                  ETH_PHY_IO_DeInit,
+                                  ETH_PHY_IO_WriteReg,
+                                  ETH_PHY_IO_ReadReg,
+                                  ETH_PHY_IO_GetTick};
+/* USER CODE BEGIN 3 */
+/* USER CODE END 3 */
+void pbuf_free_custom(struct pbuf *p);
+  * @brief  Ethernet Rx Transfer completed callback
+  * @param  handlerEth: ETH handler
+  * @retval None
+void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *handlerEth)
+#ifndef __rtems__
+  osSemaphoreRelease(RxPktSemaphore);
+#else
+  rtems_semaphore_release(RxPktSemaphore);
+  * @brief  Ethernet Tx Transfer completed callback
+  * @retval None
+void HAL_ETH_TxCpltCallback(ETH_HandleTypeDef *handlerEth)
+#ifndef __rtems__
+  osSemaphoreRelease(TxPktSemaphore);
+#else
+  rtems_semaphore_release(TxPktSemaphore);
+  * @brief  Ethernet DMA transfer error callback
+  * @retval None
+void HAL_ETH_ErrorCallback(ETH_HandleTypeDef *handlerEth)
+  if((HAL_ETH_GetDMAError(handlerEth) & ETH_DMASR_RBUS) == ETH_DMASR_RBUS)
+#ifndef __rtems__
+#else
+/* USER CODE BEGIN 4 */
+#ifdef __rtems__
+void set_mac_addr(uint8_t *mac_addr)
+  MACAddr = mac_addr;
+/* USER CODE END 4 */
+                       LL Driver Interface ( LwIP stack --> ETH)
+ * @brief In this function, the hardware should be initialized.
+ * Called from ethernetif_init().
+ * @param netif the already initialized lwip network interface structure
+ *        for this ethernetif
+static void low_level_init(struct netif *netif)
+  HAL_StatusTypeDef hal_eth_init_status = HAL_OK;
+/* USER CODE BEGIN OS_THREAD_ATTR_CMSIS_RTOS_V2 */
+#ifndef __rtems__
+  osThreadAttr_t attributes;
+/* USER CODE END OS_THREAD_ATTR_CMSIS_RTOS_V2 */
+  uint32_t duplex, speed = 0;
+  int32_t PHYLinkState = 0;
+  ETH_MACConfigTypeDef MACConf = {0};
+  /* Start ETH HAL Init */
+#ifndef __rtems__
+   uint8_t MACAddr[6] ;
+  heth.Instance = ETH;
+#ifndef __rtems__
+  MACAddr[0] = 0x02;
+  MACAddr[1] = 0x00;
+  MACAddr[2] = 0x00;
+  MACAddr[3] = 0x00;
+  MACAddr[4] = 0x00;
+  MACAddr[5] = 0x01;
+  heth.Init.MACAddr = &MACAddr[0];
+#else
+  heth.Init.MACAddr = MACAddr;
+  heth.Init.MediaInterface = HAL_ETH_RMII_MODE;
+  heth.Init.TxDesc = DMATxDscrTab;
+  heth.Init.RxDesc = DMARxDscrTab;
+  heth.Init.RxBuffLen = 1536;
+  /* USER CODE BEGIN MACADDRESS */
+  /* USER CODE END MACADDRESS */
+  hal_eth_init_status = HAL_ETH_Init(&heth);
+  memset(&TxConfig, 0 , sizeof(ETH_TxPacketConfig));
+  TxConfig.Attributes = ETH_TX_PACKETS_FEATURES_CSUM | ETH_TX_PACKETS_FEATURES_CRCPAD;
+  TxConfig.ChecksumCtrl = ETH_CHECKSUM_IPHDR_PAYLOAD_INSERT_PHDR_CALC;
+  TxConfig.CRCPadCtrl = ETH_CRC_PAD_INSERT;
+  /* End ETH HAL Init */
+  /* Initialize the RX POOL */
+  LWIP_MEMPOOL_INIT(RX_POOL);
+#if LWIP_ARP || LWIP_ETHERNET
+  /* set MAC hardware address length */
+  netif->hwaddr_len = ETH_HWADDR_LEN;
+  /* set MAC hardware address */
+  netif->hwaddr[0] =  heth.Init.MACAddr[0];
+  netif->hwaddr[1] =  heth.Init.MACAddr[1];
+  netif->hwaddr[2] =  heth.Init.MACAddr[2];
+  netif->hwaddr[3] =  heth.Init.MACAddr[3];
+  netif->hwaddr[4] =  heth.Init.MACAddr[4];
+  netif->hwaddr[5] =  heth.Init.MACAddr[5];
+  /* maximum transfer unit */
+  netif->mtu = ETH_MAX_PAYLOAD;
+  /* Accept broadcast address and ARP traffic */
+  /* don't set NETIF_FLAG_ETHARP if this device is not an ethernet one */
+  #if LWIP_ARP
+    netif->flags |= NETIF_FLAG_BROADCAST | NETIF_FLAG_ETHARP;
+  #else
+    netif->flags |= NETIF_FLAG_BROADCAST;
+  #endif /* LWIP_ARP */
+  /* create a binary semaphore used for informing ethernetif of frame reception */
+#ifndef __rtems__
+  RxPktSemaphore = osSemaphoreNew(1, 1, NULL);
+#else
+  rtems_semaphore_create(
+    rtems_build_name('R', 'x', 'p', 'k'),
+    1,
+    RTEMS_SIMPLE_BINARY_SEMAPHORE,
+    0,
+    &RxPktSemaphore
+  /* create a binary semaphore used for informing ethernetif of frame transmission */
+#ifndef __rtems__
+  TxPktSemaphore = osSemaphoreNew(1, 1, NULL);
+#else
+    rtems_build_name('T', 'x', 'p', 'k'),
+    1,
+    0,
+    &TxPktSemaphore
+  /* create the task that handles the ETH_MAC */
+/* USER CODE BEGIN OS_THREAD_NEW_CMSIS_RTOS_V2 */
+#ifndef __rtems__
+  memset(&attributes, 0x0, sizeof(osThreadAttr_t));
+  attributes.name = "EthIf";
+  attributes.stack_size = INTERFACE_THREAD_STACK_SIZE;
+  attributes.priority = osPriorityRealtime;
+  osThreadNew(ethernetif_input, netif, &attributes);
+#else
+  sys_thread_new(
+    "ethernetif_input_thread",
+    ethernetif_input,
+    netif,
+    RTEMS_MINIMUM_STACK_SIZE,
+    DEFAULT_THREAD_PRIO
+#endif /* __rtem__ */
+/* USER CODE END OS_THREAD_NEW_CMSIS_RTOS_V2 */
+/* USER CODE BEGIN PHY_PRE_CONFIG */
+/* USER CODE END PHY_PRE_CONFIG */
+  /* Set PHY IO functions */
+  DP83848_RegisterBusIO(&DP83848, &DP83848_IOCtx);
+  /* Initialize the DP83848 ETH PHY */
+  DP83848_Init(&DP83848);
+  if (hal_eth_init_status == HAL_OK)
+    PHYLinkState = DP83848_GetLinkState(&DP83848);
+    /* Get link state */
+    if(PHYLinkState <= DP83848_STATUS_LINK_DOWN)
+      netif_set_link_down(netif);
+      netif_set_down(netif);
+    else
+      switch (PHYLinkState)
+      case DP83848_STATUS_100MBITS_FULLDUPLEX:
+        duplex = ETH_FULLDUPLEX_MODE;
+        speed = ETH_SPEED_100M;
+        break;
+      case DP83848_STATUS_100MBITS_HALFDUPLEX:
+        duplex = ETH_HALFDUPLEX_MODE;
+        break;
+      case DP83848_STATUS_10MBITS_FULLDUPLEX:
+        speed = ETH_SPEED_10M;
+        break;
+      case DP83848_STATUS_10MBITS_HALFDUPLEX:
+        break;
+      default:
+        break;
+    /* Get MAC Config MAC */
+    HAL_ETH_GetMACConfig(&heth, &MACConf);
+    MACConf.DuplexMode = duplex;
+    MACConf.Speed = speed;
+    HAL_ETH_SetMACConfig(&heth, &MACConf);
+#ifdef __rtems__
+    rtems_interrupt_handler_install(
+            STM32F4_IRQ_ETH,
+            NULL,
+            RTEMS_INTERRUPT_UNIQUE,
+            HAL_ETH_IRQHandler,
+            &heth
+    HAL_ETH_Start_IT(&heth);
+    netif_set_up(netif);
+    netif_set_link_up(netif);
+/* USER CODE BEGIN PHY_POST_CONFIG */
+/* USER CODE END PHY_POST_CONFIG */
+  else
+    Error_Handler();
+#endif /* LWIP_ARP || LWIP_ETHERNET */
+/* USER CODE BEGIN LOW_LEVEL_INIT */
+/* USER CODE END LOW_LEVEL_INIT */
+ * This function should do the actual transmission of the packet. The packet is
+ * contained in the pbuf that is passed to the function. This pbuf
+ * might be chained.
+ * @param netif the lwip network interface structure for this ethernetif
+ * @param p the MAC packet to send (e.g. IP packet including MAC addresses and type)
+ * @return ERR_OK if the packet could be sent
+ *         an err_t value if the packet couldn't be sent
+ * @note Returning ERR_MEM here if a DMA queue of your MAC is full can lead to
+ *       strange results. You might consider waiting for space in the DMA queue
+ *       to become available since the stack doesn't retry to send a packet
+ *       dropped because of memory failure (except for the TCP timers).
+static err_t low_level_output(struct netif *netif, struct pbuf *p)
+  uint32_t i = 0U;
+  struct pbuf *q = NULL;
+  err_t errval = ERR_OK;
+  ETH_BufferTypeDef Txbuffer[ETH_TX_DESC_CNT];
+  memset(Txbuffer, 0 , ETH_TX_DESC_CNT*sizeof(ETH_BufferTypeDef));
+  for(q = p; q != NULL; q = q->next)
+    if(i >= ETH_TX_DESC_CNT)
+      return ERR_IF;
+    Txbuffer[i].buffer = q->payload;
+    Txbuffer[i].len = q->len;
+    if(i>0)
+      Txbuffer[i-1].next = &Txbuffer[i];
+    if(q->next == NULL)
+      Txbuffer[i].next = NULL;
+    i++;
+  TxConfig.Length = p->tot_len;
+  TxConfig.TxBuffer = Txbuffer;
+  TxConfig.pData = p;
+  pbuf_ref(p);
+  HAL_ETH_Transmit_IT(&heth, &TxConfig);
+#ifndef __rtems__
+  while(osSemaphoreAcquire(TxPktSemaphore, TIME_WAITING_FOR_INPUT)!=osOK)
+#else
+  while (rtems_semaphore_obtain(TxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
+          TIME_WAITING_FOR_INPUT) != RTEMS_SUCCESSFUL)
+  HAL_ETH_ReleaseTxPacket(&heth);
+  return errval;
+ * Should allocate a pbuf and transfer the bytes of the incoming
+ * packet from the interface into the pbuf.
+ * @return a pbuf filled with the received packet (including MAC header)
+ *         NULL on memory error
+static struct pbuf * low_level_input(struct netif *netif)
+  struct pbuf *p = NULL;
+  if(RxAllocStatus == RX_ALLOC_OK)
+    HAL_ETH_ReadData(&heth, (void **)&p);
+  return p;
+ * This function should be called when a packet is ready to be read
+ * from the interface. It uses the function low_level_input() that
+ * should handle the actual reception of bytes from the network
+ * interface. Then the type of the received packet is determined and
+ * the appropriate input function is called.
+void ethernetif_input(void* argument)
+  struct netif *netif = (struct netif *) argument;
+  for( ;; )
+#ifndef __rtems__
+    if (osSemaphoreAcquire(RxPktSemaphore, TIME_WAITING_FOR_INPUT) == osOK)
+#else
+    if (rtems_semaphore_obtain(RxPktSemaphore, RTEMS_DEFAULT_OPTIONS,
+            TIME_WAITING_FOR_INPUT) == RTEMS_SUCCESSFUL)
+      do
+        p = low_level_input( netif );
+        if (p != NULL)
+          if (netif->input( p, netif) != ERR_OK )
+            pbuf_free(p);
+      } while(p!=NULL);
+#if !LWIP_ARP
+ * This function has to be completed by user in case of ARP OFF.
+ * @return ERR_OK if ...
+static err_t low_level_output_arp_off(struct netif *netif, struct pbuf *q, const ip4_addr_t *ipaddr)
+  err_t errval;
+  errval = ERR_OK;
+/* USER CODE BEGIN 5 */
+/* USER CODE END 5 */
+  return errval;
+#endif /* LWIP_ARP */
+ * Should be called at the beginning of the program to set up the
+ * network interface. It calls the function low_level_init() to do the
+ * actual setup of the hardware.
+ * This function should be passed as a parameter to netif_add().
+ * @return ERR_OK if the loopif is initialized
+ *         ERR_MEM if private data couldn't be allocated
+ *         any other err_t on error
+err_t ethernetif_init(struct netif *netif)
+  LWIP_ASSERT("netif != NULL", (netif != NULL));
+#if LWIP_NETIF_HOSTNAME
+  /* Initialize interface hostname */
+  netif->hostname = "lwip";
+#endif /* LWIP_NETIF_HOSTNAME */
+   * Initialize the snmp variables and counters inside the struct netif.
+   * The last argument should be replaced with your link speed, in units
+   * of bits per second.
+  // MIB2_INIT_NETIF(netif, snmp_ifType_ethernet_csmacd, LINK_SPEED_OF_YOUR_NETIF_IN_BPS);
+  netif->name[0] = IFNAME0;
+  netif->name[1] = IFNAME1;
+  /* We directly use etharp_output() here to save a function call.
+   * You can instead declare your own function an call etharp_output()
+   * from it if you have to do some checks before sending (e.g. if link
+   * is available...) */
+#if LWIP_IPV4
+#if LWIP_ARP
+  netif->output = etharp_output;
+#else
+  /* The user should write its own code in low_level_output_arp_off function */
+  netif->output = low_level_output_arp_off;
+#endif /* LWIP_IPV4 */
+#if LWIP_IPV6
+  netif->output_ip6 = ethip6_output;
+#endif /* LWIP_IPV6 */
+  netif->linkoutput = low_level_output;
+  /* initialize the hardware */
+  low_level_init(netif);
+  return ERR_OK;
+  * @brief  Custom Rx pbuf free callback
+  * @param  pbuf: pbuf to be freed
+  * @retval None
+  struct pbuf_custom* custom_pbuf = (struct pbuf_custom*)p;
+  LWIP_MEMPOOL_FREE(RX_POOL, custom_pbuf);
+  /* If the Rx Buffer Pool was exhausted, signal the ethernetif_input task to
+   * call HAL_ETH_GetRxDataBuffer to rebuild the Rx descriptors. */
+  if (RxAllocStatus == RX_ALLOC_ERROR)
+    RxAllocStatus = RX_ALLOC_OK;
+#ifndef __rtems__
+#else
+/* USER CODE BEGIN 6 */
+#ifndef __rtems__
+* @brief  Returns the current time in milliseconds
+*         when LWIP_TIMERS == 1 and NO_SYS == 1
+* @param  None
+* @retval Current Time value
+u32_t sys_now(void)
+  return HAL_GetTick();
+/* USER CODE END 6 */
+void HAL_ETH_MspInit(ETH_HandleTypeDef* ethHandle)
+  GPIO_InitTypeDef GPIO_InitStruct = {0};
+  if(ethHandle->Instance==ETH)
+  /* USER CODE BEGIN ETH_MspInit 0 */
+  /* USER CODE END ETH_MspInit 0 */
+    /* Enable Peripheral clock */
+    __HAL_RCC_ETH_CLK_ENABLE();
+    __HAL_RCC_GPIOC_CLK_ENABLE();
+    __HAL_RCC_GPIOA_CLK_ENABLE();
+    __HAL_RCC_GPIOB_CLK_ENABLE();
+    /**ETH GPIO Configuration
+    PC1     ------> ETH_MDC
+    PA1     ------> ETH_REF_CLK
+    PA2     ------> ETH_MDIO
+    PA7     ------> ETH_CRS_DV
+    PC4     ------> ETH_RXD0
+    PC5     ------> ETH_RXD1
+    PB11     ------> ETH_TX_EN
+    PB12     ------> ETH_TXD0
+    PB13     ------> ETH_TXD1
+    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5;
+    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
+    GPIO_InitStruct.Pull = GPIO_NOPULL;
+    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
+    GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
+    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
+    GPIO_InitStruct.Pin = GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7;
+    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
+    GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13;
+    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
+    /* Peripheral interrupt init */
+#ifndef __rtems__
+    HAL_NVIC_SetPriority(ETH_IRQn, 5, 0);
+    HAL_NVIC_EnableIRQ(ETH_IRQn);
+  /* USER CODE BEGIN ETH_MspInit 1 */
+  /* USER CODE END ETH_MspInit 1 */
+void HAL_ETH_MspDeInit(ETH_HandleTypeDef* ethHandle)
+  /* USER CODE BEGIN ETH_MspDeInit 0 */
+  /* USER CODE END ETH_MspDeInit 0 */
+    /* Peripheral clock disable */
+    __HAL_RCC_ETH_CLK_DISABLE();
+    HAL_GPIO_DeInit(GPIOC, GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_5);
+    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_7);
+    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_11|GPIO_PIN_12|GPIO_PIN_13);
+    /* Peripheral interrupt Deinit*/
+    HAL_NVIC_DisableIRQ(ETH_IRQn);
+  /* USER CODE BEGIN ETH_MspDeInit 1 */
+  /* USER CODE END ETH_MspDeInit 1 */
+                       PHI IO Functions
+  * @brief  Initializes the MDIO interface GPIO and clocks.
+  * @param  None
+  * @retval 0 if OK, -1 if ERROR
+  /* We assume that MDIO GPIO configuration is already done
+     in the ETH_MspInit() else it should be done here
+  /* Configure the MDIO Clock */
+  HAL_ETH_SetMDIOClockRange(&heth);
+  return 0;
+  * @brief  De-Initializes the MDIO interface .
+  * @param  None
+  return 0;
+  * @brief  Read a PHY register through the MDIO interface.
+  * @param  DevAddr: PHY port address
+  * @param  RegAddr: PHY register address
+  * @param  pRegVal: pointer to hold the register value
+  * @retval 0 if OK -1 if Error
+  if(HAL_ETH_ReadPHYRegister(&heth, DevAddr, RegAddr, pRegVal) != HAL_OK)
+    return -1;
+  return 0;
+  * @brief  Write a value to a PHY register through the MDIO interface.
+  * @param  RegVal: Value to be written
+  if(HAL_ETH_WritePHYRegister(&heth, DevAddr, RegAddr, RegVal) != HAL_OK)
+    return -1;
+  return 0;
+  * @brief  Get the time in millisecons used for internal PHY driver process.
+  * @retval Time value
+  * @brief  Check the ETH link state then update ETH driver and netif link accordingly.
+  * @param  argument: netif
+  * @retval None
+void ethernet_link_thread(void* argument)
+  uint32_t linkchanged = 0U, speed = 0U, duplex = 0U;
+/* USER CODE BEGIN ETH link init */
+/* USER CODE END ETH link init */
+  for(;;)
+  if(netif_is_link_up(netif) && (PHYLinkState <= DP83848_STATUS_LINK_DOWN))
+    HAL_ETH_Stop_IT(&heth);
+  else if(!netif_is_link_up(netif) && (PHYLinkState > DP83848_STATUS_LINK_DOWN))
+      linkchanged = 1;
+      break;
+      linkchanged = 1;
+      break;
+      linkchanged = 1;
+      break;
+      linkchanged = 1;
+      break;
+    default:
+      break;
+    if(linkchanged)
+      HAL_ETH_Start(&heth);
+/* USER CODE BEGIN ETH link Thread core code for User BSP */
+/* USER CODE END ETH link Thread core code for User BSP */
+#ifndef __rtems__
+    osDelay(100);
+#else
+    sys_arch_delay(100);
+void HAL_ETH_RxAllocateCallback(uint8_t **buff)
+/* USER CODE BEGIN HAL ETH RxAllocateCallback */
+  struct pbuf_custom *p = LWIP_MEMPOOL_ALLOC(RX_POOL);
+  if (p)
+    /* Get the buff from the struct pbuf address. */
+    *buff = (uint8_t *)p + offsetof(RxBuff_t, buff);
+    p->custom_free_function = pbuf_free_custom;
+    /* Initialize the struct pbuf.
+    * This must be performed whenever a buffer's allocated because it may be
+    * changed by lwIP or the app, e.g., pbuf_free decrements ref. */
+    pbuf_alloced_custom(PBUF_RAW, 0, PBUF_REF, p, *buff, ETH_RX_BUFFER_SIZE);
+  else
+    RxAllocStatus = RX_ALLOC_ERROR;
+    *buff = NULL;
+/* USER CODE END HAL ETH RxAllocateCallback */
+void HAL_ETH_RxLinkCallback(void **pStart, void **pEnd, uint8_t *buff, uint16_t Length)
+/* USER CODE BEGIN HAL ETH RxLinkCallback */
+  struct pbuf **ppStart = (struct pbuf **)pStart;
+  struct pbuf **ppEnd = (struct pbuf **)pEnd;
+  /* Get the struct pbuf from the buff address. */
+  p = (struct pbuf *)(buff - offsetof(RxBuff_t, buff));
+  p->next = NULL;
+  p->tot_len = 0;
+  p->len = Length;
+  /* Chain the buffer. */
+  if (!*ppStart)
+    /* The first buffer of the packet. */
+    *ppStart = p;
+  else
+    /* Chain the buffer to the end of the packet. */
+    (*ppEnd)->next = p;
+  *ppEnd  = p;
+  /* Update the total length of all the buffers of the chain. Each pbuf in the chain should have its tot_len
+   * set to its own length, plus the length of all the following pbufs in the chain. */
+  for (p = *ppStart; p != NULL; p = p->next)
+    p->tot_len += Length;
+/* USER CODE END HAL ETH RxLinkCallback */
+void HAL_ETH_TxFreeCallback(uint32_t * buff)
+/* USER CODE BEGIN HAL ETH TxFreeCallback */
+  pbuf_free((struct pbuf *)buff);
+/* USER CODE END HAL ETH TxFreeCallback */
+/* USER CODE BEGIN 8 */
+/* USER CODE END 8 */
diff --git a/stm32/ethernetif.h b/stm32/ethernetif.h
index a7b2a55..9905835 100644
--- a/stm32/ethernetif.h
+++ b/stm32/ethernetif.h
@@ -1,54 +1,54 @@
-/* USER CODE BEGIN Header */
-  * File Name          : ethernetif.h
-  * Description        : This file provides initialization code for LWIP
-  *                      middleWare.
-  * @attention
-  * Copyright (c) 2022 STMicroelectronics.
-  * All rights reserved.
-  * This software is licensed under terms that can be found in the LICENSE file
-  * in the root directory of this software component.
-  * If no LICENSE file comes with this software, it is provided AS-IS.
-/* USER CODE END Header */
-#ifndef __ETHERNETIF_H__
-#define __ETHERNETIF_H__
-#include "lwip/err.h"
-#include "lwip/netif.h"
-#ifndef __rtems__
-/* Within 'USER CODE' section, code will be kept by default at each generation */
-/* USER CODE BEGIN 0 */
-#ifdef __rtems__
-void set_mac_addr(uint8_t *mac_addr);
-/* USER CODE END 0 */
-/* Exported functions ------------------------------------------------------- */
-err_t ethernetif_init(struct netif *netif);
-void ethernetif_input(void* argument);
-void ethernet_link_thread(void* argument );
-void Error_Handler(void);
-u32_t sys_jiffies(void);
-#ifndef __rtems__
-u32_t sys_now(void);
-/* USER CODE BEGIN 1 */
-/* USER CODE END 1 */
-#endif
+  * File Name          : ethernetif.h
+  * Description        : This file provides initialization code for LWIP
+  *                      middleWare.
+  * @attention
+  * All rights reserved.
+#ifndef __ETHERNETIF_H__
+#define __ETHERNETIF_H__
+#include "lwip/err.h"
+#include "lwip/netif.h"
+#ifndef __rtems__
+#ifdef __rtems__
+void set_mac_addr(uint8_t *mac_addr);
+/* Exported functions ------------------------------------------------------- */
+err_t ethernetif_init(struct netif *netif);
+void ethernetif_input(void* argument);
+void ethernet_link_thread(void* argument );
+void Error_Handler(void);
+u32_t sys_jiffies(void);
+#ifndef __rtems__
+u32_t sys_now(void);
+#endif
2.37.2
