[PATCH rtems-lwip v4 0/7] lwIP port for STM32F4 BSP
Kinsey Moore kinsey.moore at oarcorp.com
Sat Sep 10 02:04:47 UTC 2022
This addresses all my issues with the patch, looks good!
Kinsey
On 9/9/2022 18:13, Duc Doan wrote:
> This patch set aims to port RTEMS lwIP for STM32F4 BSP. It also contains
> generic drivers for STM32 chips in general. It is tested with a TCP echo
> server application on STM32F407 Discovery Board.
> Prerequisite: this patch set requires my STM32F4 patches to be applied
> because it uses STM32 HAL.
> v2:
> - Changes the arch and BSP check to use rtems.arch and rtems.bsp
> - Updates #4714: replace os.walk by ant_glob
> - Group STM32F4 BSP-specific files together
> v3:
> - Make BSP check exact
> - Add ORIGIN.stm32 and COPYING.stm32
> - Imported files under stm32/ are now generated by STM32CubeIDE under
> RTOS mode
> - Remove unused lwip.c
> v4:
> - Fix improper code addition
> - Fix aarch64 BSP list in lwip.py
> - Remove unused lwip.h
> Duc Doan (7):
>    lwip.py: Change arch and bsp check method
>    lwip.py: Use ant_glob instead of os.walk()
>    Add STM32 Ethernet source
>    rtemslwip: Add STM32F4 lwipopts.h and netstart.c
>    RTEMS port of lwIP for STM32 and STM32F4 BSP
>    lwip.py: Add STM32 lwIP port to build
>    stm32: Convert to Unix line endings
>   COPYING.stm32                    |  28 +
>   ORIGIN.stm32                     |   2 +
>   lwip.py                          |  69 ++-
>   rtemslwip/stm32f4/lwipopts.h     | 147 +++++
>   rtemslwip/stm32f4/netstart.c     |  73 +++
>   rtemslwip/stm32f4/stm32f4_lwip.c |  39 ++
>   rtemslwip/stm32f4/stm32f4_lwip.h |  34 ++
>   stm32/driver/dp83848.c           | 664 +++++++++++++++++++++
>   stm32/driver/dp83848.h           | 436 ++++++++++++++
>   stm32/ethernetif.c               | 986 +++++++++++++++++++++++++++++++
>   stm32/ethernetif.h               |  54 ++
>   11 files changed, 2508 insertions(+), 24 deletions(-)
>   create mode 100644 COPYING.stm32
>   create mode 100644 ORIGIN.stm32
>   create mode 100644 rtemslwip/stm32f4/lwipopts.h
>   create mode 100644 rtemslwip/stm32f4/netstart.c
>   create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.c
>   create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.h
>   create mode 100644 stm32/driver/dp83848.c
>   create mode 100644 stm32/driver/dp83848.h
>   create mode 100644 stm32/ethernetif.c
>   create mode 100644 stm32/ethernetif.h
