[PATCH rtems-lwip v4 0/7] lwIP port for STM32F4 BSP
Sat Sep 10 03:00:33 UTC 2022
I'd like to see another ack. Chris? Andrei? Christian? Poke them on discord
please.
On Fri, Sep 9, 2022, 9:05 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> This addresses all my issues with the patch, looks good!
> Kinsey
> On 9/9/2022 18:13, Duc Doan wrote:
> > This patch set aims to port RTEMS lwIP for STM32F4 BSP. It also contains
> > generic drivers for STM32 chips in general. It is tested with a TCP echo
> > server application on STM32F407 Discovery Board.
> > Prerequisite: this patch set requires my STM32F4 patches to be applied
> > because it uses STM32 HAL.
> > v2:
> > - Changes the arch and BSP check to use rtems.arch and rtems.bsp
> > - Updates #4714: replace os.walk by ant_glob
> > - Group STM32F4 BSP-specific files together
> > v3:
> > - Make BSP check exact
> > - Add ORIGIN.stm32 and COPYING.stm32
> > - Imported files under stm32/ are now generated by STM32CubeIDE under
> > RTOS mode
> > - Remove unused lwip.c
> > v4:
> > - Fix improper code addition
> > - Fix aarch64 BSP list in lwip.py
> > - Remove unused lwip.h
> > Duc Doan (7):
> >    lwip.py: Change arch and bsp check method
> >    lwip.py: Use ant_glob instead of os.walk()
> >    Add STM32 Ethernet source
> >    rtemslwip: Add STM32F4 lwipopts.h and netstart.c
> >    RTEMS port of lwIP for STM32 and STM32F4 BSP
> >    lwip.py: Add STM32 lwIP port to build
> >    stm32: Convert to Unix line endings
> >   COPYING.stm32                    |  28 +
> >   ORIGIN.stm32                     |   2 +
> >   lwip.py                          |  69 ++-
> >   rtemslwip/stm32f4/lwipopts.h     | 147 +++++
> >   rtemslwip/stm32f4/netstart.c     |  73 +++
> >   rtemslwip/stm32f4/stm32f4_lwip.c |  39 ++
> >   rtemslwip/stm32f4/stm32f4_lwip.h |  34 ++
> >   stm32/driver/dp83848.c           | 664 +++++++++++++++++++++
> >   stm32/driver/dp83848.h           | 436 ++++++++++++++
> >   stm32/ethernetif.c               | 986 +++++++++++++++++++++++++++++++
> >   stm32/ethernetif.h               |  54 ++
> >   11 files changed, 2508 insertions(+), 24 deletions(-)
> >   create mode 100644 COPYING.stm32
> >   create mode 100644 ORIGIN.stm32
> >   create mode 100644 rtemslwip/stm32f4/lwipopts.h
> >   create mode 100644 rtemslwip/stm32f4/netstart.c
> >   create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.c
> >   create mode 100644 rtemslwip/stm32f4/stm32f4_lwip.h
> >   create mode 100644 stm32/driver/dp83848.c
> >   create mode 100644 stm32/driver/dp83848.h
> >   create mode 100644 stm32/ethernetif.c
> >   create mode 100644 stm32/ethernetif.h
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220909/b5310741/attachment-0001.htm>
