[PATCH 3/3] devel/gcc: Check and build GNU sed if not available on build host
chrisj at rtems.org
chrisj at rtems.org
Wed Sep 14 07:02:38 UTC 2022
Closes #2300
bare/config/devel/gnu-default-tools.bset | 6 ++++++
rtems/config/tools/rtems-default-tools.bset | 5 +++++
source-builder/config/gcc-common-1.cfg | 4 ++++
3 files changed, 15 insertions(+)
diff --git a/bare/config/devel/gnu-default-tools.bset b/bare/config/devel/gnu-default-tools.bset
index dab8c5e..f038352 100644
--- a/bare/config/devel/gnu-default-tools.bset
+++ b/bare/config/devel/gnu-default-tools.bset
@@ -6,6 +6,12 @@
%define gcc_version_message RTEMS bare %{rtems_version}, RSB %{_sbgit_id}, Newlib %{newlib_version}
+# GCC requires a GNU sed so build an internal version if one is not
+# available
+%include textproc/gsed-internal
# Build gdb first to raise the Python install error as early as
# possible. GDB needs expat so it needs to be built before gdb.
diff --git a/rtems/config/tools/rtems-default-tools.bset b/rtems/config/tools/rtems-default-tools.bset
index 7d273cf..8ec6721 100644
--- a/rtems/config/tools/rtems-default-tools.bset
+++ b/rtems/config/tools/rtems-default-tools.bset
@@ -2,6 +2,11 @@
# Default tools build
+# available
+%include textproc/gsed-internal.bset
diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
index 87ccef1..933202a 100644
--- a/source-builder/config/gcc-common-1.cfg
+++ b/source-builder/config/gcc-common-1.cfg
@@ -165,6 +165,10 @@ URL: http://gcc.gnu.org/
%build
build_top=$(pwd)
+ %if %{defined _internal_gsed_path}
+ export PATH=%{_internal_gsed_path}/bin:$PATH
+ %endif
%{build_directory}
mkdir -p ${build_dir}
2.37.1
