[PATCH 3/3] devel/gcc: Check and build GNU sed if not available on build host
Wed Sep 14 13:31:40 UTC 2022
OK. Hopefully this fixes the MIPS issues.
On Wed, Sep 14, 2022 at 2:02 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> Closes #2300
>  bare/config/devel/gnu-default-tools.bset    | 6 ++++++
>  rtems/config/tools/rtems-default-tools.bset | 5 +++++
>  source-builder/config/gcc-common-1.cfg      | 4 ++++
>  3 files changed, 15 insertions(+)
> diff --git a/bare/config/devel/gnu-default-tools.bset
> b/bare/config/devel/gnu-default-tools.bset
> index dab8c5e..f038352 100644
> --- a/bare/config/devel/gnu-default-tools.bset
> +++ b/bare/config/devel/gnu-default-tools.bset
> @@ -6,6 +6,12 @@
>  %define gcc_version_message RTEMS bare %{rtems_version}, RSB
> %{_sbgit_id}, Newlib %{newlib_version}
> +# GCC requires a GNU sed so build an internal version if one is not
> +# available
> +%include textproc/gsed-internal
>  # Build gdb first to raise the Python install error as early as
>  # possible. GDB needs expat so it needs to be built before gdb.
> diff --git a/rtems/config/tools/rtems-default-tools.bset
> b/rtems/config/tools/rtems-default-tools.bset
> index 7d273cf..8ec6721 100644
> --- a/rtems/config/tools/rtems-default-tools.bset
> +++ b/rtems/config/tools/rtems-default-tools.bset
> @@ -2,6 +2,11 @@
>  # Default tools build
> +# available
> +%include textproc/gsed-internal.bset
> diff --git a/source-builder/config/gcc-common-1.cfg
> b/source-builder/config/gcc-common-1.cfg
> index 87ccef1..933202a 100644
> --- a/source-builder/config/gcc-common-1.cfg
> +++ b/source-builder/config/gcc-common-1.cfg
> @@ -165,6 +165,10 @@ URL:          http://gcc.gnu.org/
>  %build
>    build_top=$(pwd)
> +  %if %{defined _internal_gsed_path}
> +    export PATH=%{_internal_gsed_path}/bin:$PATH
> +  %endif
>    %{build_directory}
>    mkdir -p ${build_dir}
> 2.37.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220914/fdfcdb3a/attachment.htm>
