[RSB 5 PATCH 3/6] sb/setbuilder: Correctly create build set tar files
chrisj at rtems.org
chrisj at rtems.org
Sun Sep 18 01:51:24 UTC 2022
- Make a single tarfile for all buildsets built
- Use the staging tree as the tarfile source
- Use python's tarfile module
- Create a config.file object without loading a .cfg file
Updates #4716
source-builder/sb/config.py | 5 +--
source-builder/sb/setbuilder.py | 58 ++++++++++++++++++++-------------
2 files changed, 39 insertions(+), 24 deletions(-)
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index 9250896..24590eb 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -258,7 +258,7 @@ class file:
re.compile('%select'),
re.compile('%disable') ]
- def __init__(self, name, opts, macros = None):
+ def __init__(self, name, opts, macros = None, load = True):
log.trace('config: %s: initialising' % (name))
self.opts = opts
self.init_name = name
@@ -267,7 +267,8 @@ class file:
self.sf = re.compile(r'%\([^\)]+\)')
self.set_macros(macros)
self._reset(name)
- self.load(name)
+ if load:
+ self.load(name)
def __str__(self):
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index 55bd86f..36fca46 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -30,11 +30,14 @@ import glob
import operator
import os
import sys
+import tarfile
import textwrap
try:
import build
import check
+ import config
import error
import log
import mailer
@@ -259,21 +262,31 @@ class buildset:
self.root_copy(_build.config.expand('%{buildroot}'),
_build.config.expand('%{_tmproot}'))
- def bset_tar(self, _build):
- tardir = _build.config.expand('%{_tardir}')
- if (self.opts.get_arg('--bset-tar-file') or self.opts.canadian_cross()) \
- and not _build.macros.get('%{_disable_packaging}'):
+ def bset_tar(self, stagingroot):
+ if self.opts.get_arg('--bset-tar-file') or self.opts.canadian_cross():
+ # Use a config to expand the macros because it supports all
+ # expansions, ie %{_cwd}
+ cfg = config.file(self.bset, self.opts, self.macros, load=False)
+ prefix = cfg.expand('%{_prefix}')
+ tardir = cfg.expand('%{_tardir}')
path.mkdir(tardir)
- tar = path.join(tardir,
- _build.config.expand('%s.tar.bz2' % \
- (_build.main_package().name())))
- log.notice('tarball: %s' % (os.path.relpath(path.host(tar))))
+ tarname = path.join(tardir,
+ path.basename('%s.tar.bz2' % (self.bset)))
+ log.notice('tarfile: %s' % (os.path.relpath(path.host(tarname))))
if not self.opts.dry_run():
- tmproot = _build.config.expand('%{_tmproot}')
- cmd = _build.config.expand('"cd ' + tmproot + \
- ' && %{__tar} -cf - . | %{__bzip2} > ' + \
- tar + '"')
- _build.run(cmd, shell_opts = '-c', cwd = tmproot)
+ tar = None
+ try:
+ tar = tarfile.open(tarname, 'w:bz2')
+ for filedir in sorted(path.listdir(stagingroot)):
+ src = path.join(stagingroot, filedir)
+ dst = path.join(prefix, filedir)
+ log.trace('tar: %s -> %s' % (src, dst))
+ tar.add(src, dst)
+ except OSError as oe:
+ raise error.general('tarfile: %s: %s' % (self.bset, oe))
+ finally:
+ if tar is not None:
+ tar.close()
def parse(self, bset):
@@ -500,8 +513,6 @@ class buildset:
copy.copy(self.macros),
format = 'xml',
mail = mail)
- if s == len(configs) - 1 and not have_errors:
- self.bset_tar(b)
else:
deps += b.config.includes()
builds += [b]
@@ -540,7 +551,7 @@ class buildset:
log.trace('_bset: %2d: %s: builds: %s' % \
(nesting_count, self.install_mode(),
', '.join([b.name() for b in builds])))
- if deps is None and not self.opts.no_install() and not have_errors:
+ if deps is None and not have_errors:
for b in builds:
log.trace('_bset: : %s: %r' % (self.install_mode(),
b.installable()))
@@ -550,7 +561,6 @@ class buildset:
if self.staging():
prefix = b.config.expand('%{stagingroot}')
self.install(self.install_mode(), b.name(), buildroot, prefix)
# Sizes ...
@@ -604,16 +614,20 @@ class buildset:
del b
- # If builds have been staged install into the finaly prefix.
+ # If builds have been staged install into the final prefix.
- if have_staging and not self.opts.no_install() and not have_errors:
+ if have_staging and not have_errors:
stagingroot = macro_expand(self.macros, '%{stagingroot}')
have_stagingroot = path.exists(stagingroot)
- log.trace('_bset: %2d: install staging, present: %s' % \
- (nesting_count, have_stagingroot))
+ do_install = not self.opts.no_install()
+ if do_install:
+ log.trace('_bset: %2d: install staging, present: %s' % \
+ (nesting_count, have_stagingroot))
if have_stagingroot:
prefix = macro_expand(self.macros, '%{_prefix}')
- self.install(self.install_mode(), self.bset, stagingroot, prefix)
+ if do_install:
+ self.install(self.install_mode(), self.bset, stagingroot, prefix)
+ self.bset_tar(stagingroot)
staging_size = path.get_size(stagingroot)
if not self.opts.no_clean() or self.opts.always_clean():
log.notice('clean staging: %s' % (self.bset))
2.37.1
