[RSB 5 PATCH 2/6] sb/config: Correctly handle multiple config paths
chrisj at rtems.org
chrisj at rtems.org
Sun Sep 18 01:51:23 UTC 2022
- Add rtems/config to the config directories searched to better
support deployment
- Correctly expand the configdir and path searchs
Updates #4716
source-builder/defaults.mc | 2 +-
source-builder/sb/config.py | 52 ++++++++++++++++++-------------------
2 files changed, 26 insertions(+), 28 deletions(-)
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index 8ed7003..4658277 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -98,7 +98,7 @@ _host_cc: none, none, 'gcc'
_host_cxx: none, none, 'g++'
_arch: none, none, '%{_host_arch}'
_topdir: dir, required, '%{_cwd}'
-_configdir: dir, optional, '%{_topdir}/config:%{_sbdir}/config:%{_sbtop}/bare/config'
+_configdir: dir, optional, '%{_topdir}/config:%{_sbdir}/config:%{_sbtop}/bare/config:%{_sbtop}/rtems/config'
_tardir: dir, optional, '%{_topdir}/tar'
_sourcedir: dir, optional, '%{_topdir}/sources'
_patchdir: dir, optional, '%{_topdir}/patches:%{_sbdir}/patches'
diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
index df2aa31..9250896 100644
--- a/source-builder/sb/config.py
+++ b/source-builder/sb/config.py
@@ -785,7 +785,16 @@ class file:
mn = '%{nil}'
if mn:
if mn.lower() in self.macros:
- s = s.replace(m, self.macros[mn.lower()])
+ em = self.macros[mn.lower()]
+ if self.macros.get_type(mn) == 'dir' and ':' in em:
+ ss = []
+ for sp in s.split():
+ if m in sp:
+ sp = ':'.join([sp.replace(mn, ps) for ps in em.split(':')])
+ ss += [sp]
+ s = ' '.join(ss)
+ else:
+ s = s.replace(m, self.macros[mn.lower()])
expanded = True
elif show_warning:
self._error("macro '%s' not found" % (mn))
@@ -1345,6 +1354,14 @@ class file:
right = right[:-1]
return end
+ def search_path(confignames):
+ for configname in confignames.split(':'):
+ if not configname.endswith('.cfg'):
+ configname = '%s.cfg' % (configname)
+ if path.exists(configname):
+ return configname
+ return None
if self.load_depth == 0:
self._packages[self.package] = package(self.package,
self.define('%{_arch}'),
@@ -1358,7 +1375,7 @@ class file:
# Locate the config file. Expand any macros then add the
- # extension. Check if the file exists, therefore directly
+ # extension. Check if the file exists then it is directly
# referenced. If not see if the file contains ':' or the path
# separator. If it does split the path else use the standard config dir
# path in the defaults.
@@ -1366,32 +1383,13 @@ class file:
exname = self.expand(name)
- # Macro could add an extension.
- if exname.endswith('.cfg'):
- configname = exname
- else:
- configname = '%s.cfg' % (exname)
- name = '%s.cfg' % (name)
- if ':' in configname:
- cfgname = path.basename(configname)
- else:
- cfgname = common_end(configname, name)
+ configname = search_path(exname)
+ if configname is None:
+ configname = search_path(self.expand(path.join('%{_configdir}', exname)))
+ raise error.general('no config file found: %s' % (','.join(exname.split(':'))))
- if not path.exists(configname):
- configdirs = path.dirname(configname).split(':')
- else:
- configdirs = self.define('_configdir').split(':')
- for cp in configdirs:
- configname = path.join(path.abspath(cp), cfgname)
- if path.exists(configname):
- break
- configname = None
- if configname is None:
- raise error.general('no config file found: %s' % (cfgname))
+ name = path.basename(configname)
try:
log.trace('config: %s: _open: %s' % (self.name, path.host(configname)))
2.37.1
