[PATCH v2 1/4] bsps/riscv: Add device tree blob
Padmarao Begari
padmarao.begari at microchip.com
Mon Sep 19 13:00:24 UTC 2022
Add the basic Microchip PolarFire SoC device tree source and blob
The mpfs-dtb.h is generated by the bin2hex
https://github.com/padmaraob/bin2hex
1.Compile and build the bin2hex.c
$ gcc -o bin2hex bin2hex.c
2.Generate the mpfs.dtb from the mpfs.dts
$ dtc -O dtb -o mpfs.dtb mpfs.dts
3.Generate the mpfs-dtb.h Header file from the mpfs.dtb.
$ ./bin2hex mpfs.dtb
bsps/riscv/riscv/dts/mpfs.dts | 365 ++++++++++++++
bsps/riscv/riscv/include/bsp/mpfs-dtb.h | 602 ++++++++++++++++++++++++
2 files changed, 967 insertions(+)
create mode 100644 bsps/riscv/riscv/dts/mpfs.dts
create mode 100644 bsps/riscv/riscv/include/bsp/mpfs-dtb.h
diff --git a/bsps/riscv/riscv/dts/mpfs.dts b/bsps/riscv/riscv/dts/mpfs.dts
new file mode 100644
index 0000000000..7b19701b02
--- /dev/null
+++ b/bsps/riscv/riscv/dts/mpfs.dts
@@ -0,0 +1,365 @@
+ * Copyright (C) Padmarao Begari <padmarao.begari at microchip.com>
+ * Copyright (C) 2022 Microchip Technology Inc.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+/dts-v1/;
+ #address-cells = <2>;
+ #size-cells = <2>;
+ model = "Microchip PolarFire-SoC Icicle Kit";
+ compatible = "microchip,mpfs-icicle-kit", "microchip,mpfs";
+ aliases {
+ serial1 = &uart1;
+ ethernet0 = &emac1;
+ chosen {
+ stdout-path = "serial1";
+ cpucomplex: cpus {
+ #address-cells = <1>;
+ #size-cells = <0>;
+ timebase-frequency = <1000000>;
+ cpu0: cpu at 0 {
+ clock-frequency = <0>;
+ compatible = "sifive,e51", "sifive,rocket0", "riscv";
+ device_type = "cpu";
+ i-cache-block-size = <64>;
+ i-cache-sets = <128>;
+ i-cache-size = <16384>;
+ reg = <0>;
+ riscv,isa = "rv64imac";
+ status = "disabled";
+ cpu0intc: interrupt-controller {
+ #interrupt-cells = <1>;
+ compatible = "riscv,cpu-intc";
+ interrupt-controller;
+ cpu1: cpu at 1 {
+ compatible = "sifive,u54-mc", "sifive,rocket0", "riscv";
+ d-cache-block-size = <64>;
+ d-cache-sets = <64>;
+ d-cache-size = <32768>;
+ d-tlb-sets = <1>;
+ d-tlb-size = <32>;
+ i-cache-sets = <64>;
+ i-cache-size = <32768>;
+ i-tlb-sets = <1>;
+ i-tlb-size = <32>;
+ mmu-type = "riscv,sv39";
+ reg = <1>;
+ riscv,isa = "rv64imafdc";
+ tlb-split;
+ status = "okay";
+ cpu1intc: interrupt-controller {
+ cpu2: cpu at 2 {
+ d-tlb-sets = <1>;
+ i-tlb-sets = <1>;
+ reg = <2>;
+ tlb-split;
+ status = "okay";
+ cpu2intc: interrupt-controller {
+ cpu3: cpu at 3 {
+ d-tlb-sets = <1>;
+ i-tlb-sets = <1>;
+ reg = <3>;
+ tlb-split;
+ status = "okay";
+ cpu3intc: interrupt-controller {
+ cpu4: cpu at 4 {
+ d-tlb-sets = <1>;
+ i-tlb-sets = <1>;
+ reg = <4>;
+ tlb-split;
+ status = "okay";
+ cpu4intc: interrupt-controller {
+ refclk: refclk {
+ compatible = "fixed-clock";
+ #clock-cells = <0>;
+ clock-frequency = <600000000>;
+ clock-output-names = "msspllclk";
+ ddr: memory at 1000000000 {
+ device_type = "memory";
+ reg = <0x00000010 0x00000000 0x00000000 0x10000000>;
+ soc: soc {
+ compatible = "microchip,mpfs-soc", "simple-bus";
+ ranges;
+ clint0: clint at 2000000 {
+ compatible = "riscv,clint0";
+ interrupts-extended = <&cpu0intc 3 &cpu0intc 7
+ &cpu1intc 3 &cpu1intc 7
+ &cpu2intc 3 &cpu2intc 7
+ &cpu3intc 3 &cpu3intc 7
+ &cpu4intc 3 &cpu4intc 7>;
+ reg = <0x0 0x2000000 0x0 0x10000>;
+ reg-names = "control";
+ clock-frequency = <1000000>;
+ cachecontroller: cache-controller at 2010000 {
+ compatible = "sifive,fu540-c000-ccache", "cache";
+ cache-block-size = <64>;
+ cache-level = <2>;
+ cache-sets = <1024>;
+ cache-size = <2097152>;
+ cache-unified;
+ interrupt-parent = <&plic>;
+ interrupts = <1 2 3>;
+ reg = <0x0 0x2010000 0x0 0x1000>;
+ plic: interrupt-controller at c000000 {
+ compatible = "riscv,plic0";
+ reg = <0x0 0xc000000 0x0 0x4000000>;
+ riscv,max-priority = <7>;
+ riscv,ndev = <186>;
+ &cpu0intc 11
+ &cpu1intc 11 &cpu1intc 9
+ &cpu2intc 11 &cpu2intc 9
+ &cpu3intc 11 &cpu3intc 9
+ &cpu4intc 11 &cpu4intc 9>;
+ clkcfg: clkcfg at 20002000 {
+ compatible = "microchip,mpfs-clkcfg";
+ reg = <0x0 0x20002000 0x0 0x1000>;
+ reg-names = "mss_sysreg";
+ clocks = <&refclk>;
+ #clock-cells = <1>;
+ clock-output-names = "cpu", "axi", "ahb", "envm",
+ "mac0", "mac1", "mmc", "timer",
+ "mmuart0", "mmuart1", "mmuart2",
+ "mmuart3", "mmuart4", "spi0", "spi1",
+ "i2c0", "i2c1", "can0", "can1", "usb",
+ "reserved", "rtc", "qspi", "gpio0",
+ "gpio1", "gpio2", "ddrc", "fic0",
+ "fic1", "fic2", "fic3", "athena",
+ "cfm";
+ /* Common node entry for eMMC/SD */
+ mmc: mmc at 20008000 {
+ compatible = "microchip,mpfs-sd4hc","cdns,sd4hc";
+ reg = <0x0 0x20008000 0x0 0x1000>;
+ clocks = <&clkcfg 6>;
+ interrupts = <88 89>;
+ max-frequency = <200000000>;
+ bus-width = <4>;
+ disable-wp;
+ cap-mmc-highspeed;
+ cap-sd-highspeed;
+ card-detect-delay = <200>;
+ mmc-ddr-1_8v;
+ mmc-hs200-1_8v;
+ sd-uhs-sdr12;
+ sd-uhs-sdr25;
+ sd-uhs-sdr50;
+ sd-uhs-sdr104;
+ uart1: serial at 20100000 {
+ compatible = "ns16550a";
+ reg = <0x0 0x20100000 0x0 0x400>;
+ reg-io-width = <4>;
+ reg-shift = <2>;
+ interrupts = <91>;
+ clock-frequency = <150000000>;
+ clocks = <&clkcfg 9>;
+ status = "okay";
+ spi0: spi at 20108000 {
+ compatible = "microchip,mpfs-spi";
+ reg = <0x0 0x20108000 0x0 0x1000>;
+ clocks = <&clkcfg 13>;
+ interrupts = <54>;
+ i2c1: i2c at 2010b000 {
+ compatible = "microchip,mpfs-i2c";
+ reg = <0x0 0x2010b000 0x0 0x1000>;
+ interrupts = <61>;
+ clocks = <&clkcfg 16>;
+ clock-frequency = <100000>;
+ status = "okay";
+ pac193x at 10 {
+ compatible = "microchip,pac1934";
+ reg = <0x10>;
+ samp-rate = <64>;
+ ch1: channel0 {
+ uohms-shunt-res = <10000>;
+ rail-name = "VDD";
+ channel_enabled;
+ ch2: channel1 {
+ rail-name = "VDDA25";
+ channel_enabled;
+ ch3: channel2 {
+ rail-name = "VDD25";
+ channel_enabled;
+ ch4: channel3 {
+ rail-name = "VDDA";
+ channel_enabled;
+ emac1: ethernet at 20112000 {
+ compatible = "microchip,mpfs-macb","cdns,gem";
+ reg = <0x0 0x20112000 0x0 0x2000>;
+ interrupts = <70 71 72 73>;
+ local-mac-address = [00 04 A3 00 00 02];
+ phy-mode = "sgmii";
+ clocks = <&clkcfg 5>, <&clkcfg 1>;
+ clock-names = "pclk", "hclk";
+ status = "okay";
+ phy-handle = <&phy1>;
+ phy1: ethernet-phy at 9 {
+ reg = <9>;
+ gpio: gpio at 20122000 {
+ compatible = "microchip,mpfs-gpio";
+ interrupts = <13 14 15 16 17 18 19 20 21 22 23 24 25 26
+ 27 28 29 30 31 32 33 34 35 36 37 38 39
+ 40 41 42 43 44>;
+ gpio-controller;
+ clocks = <&clkcfg 25>;
+ reg = <0x00 0x20122000 0x0 0x1000>;
+ #gpio-cells = <2>;
diff --git a/bsps/riscv/riscv/include/bsp/mpfs-dtb.h b/bsps/riscv/riscv/include/bsp/mpfs-dtb.h
index 0000000000..a3f8140336
--- /dev/null
+++ b/bsps/riscv/riscv/include/bsp/mpfs-dtb.h
@@ -0,0 +1,602 @@
+ * Declarations for C structure representing binary file mpfs.dtb
+ * WARNING: Automatically generated -- do not edit!
+ * are met:
+#ifndef __system_dtb_h
+#define __system_dtb_h
+#include <rtems/score/basedefs.h>
+#include <sys/types.h>
+const unsigned char system_dtb[] RTEMS_ALIGNED(8) = {
+ 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x1a, 0x1f, 0x00, 0x00, 0x00, 0x38,
+ 0x00, 0x00, 0x16, 0xe8, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x37,
+ 0x00, 0x00, 0x16, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x1b,
+ 0x4d, 0x69, 0x63, 0x72, 0x6f, 0x63, 0x68, 0x69, 0x70, 0x20, 0x50, 0x6f,
+ 0x6c, 0x61, 0x72, 0x46, 0x69, 0x72, 0x65, 0x2d, 0x53, 0x6f, 0x43, 0x20,
+ 0x49, 0x63, 0x69, 0x63, 0x6c, 0x65, 0x20, 0x4b, 0x69, 0x74, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x00, 0x21,
+ 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x63, 0x68, 0x69, 0x70, 0x2c, 0x6d, 0x70,
+ 0x66, 0x73, 0x2d, 0x69, 0x63, 0x69, 0x63, 0x6c, 0x65, 0x2d, 0x6b, 0x69,
+ 0x74, 0x00, 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x63, 0x68, 0x69, 0x70, 0x2c,
+ 0x6d, 0x70, 0x66, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+ 0x61, 0x6c, 0x69, 0x61, 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x2c, 0x2f, 0x73, 0x6f, 0x63,
+ 0x2f, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x32, 0x30, 0x31, 0x30,
+ 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x34, 0x2f, 0x73, 0x6f, 0x63,
+ 0x2f, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x32, 0x30,
+ 0x31, 0x31, 0x32, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x6f, 0x73, 0x65, 0x6e, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x3e,
+ 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x31, 0x00, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x73, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x4a, 0x00, 0x0f, 0x42, 0x40,
+ 0x00, 0x00, 0x00, 0x01, 0x63, 0x70, 0x75, 0x40, 0x30, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5d,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20,
+ 0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x65,
+ 0x35, 0x31, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x72, 0x6f,
+ 0x63, 0x6b, 0x65, 0x74, 0x30, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x6d,
+ 0x63, 0x70, 0x75, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x79, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8c, 0x00, 0x00, 0x00, 0x80,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x99,
+ 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0xaa, 0x72, 0x76, 0x36, 0x34,
+ 0x69, 0x6d, 0x61, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0xb4, 0x64, 0x69, 0x73, 0x61,
+ 0x62, 0x6c, 0x65, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+ 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f,
+ 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xbb,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0f,
+ 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x63, 0x70,
+ 0x75, 0x2d, 0x69, 0x6e, 0x74, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xcc, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x63, 0x70, 0x75, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x5d, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x21,
+ 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x75, 0x35, 0x34, 0x2d, 0x6d,
+ 0x63, 0x00, 0x73, 0x69, 0x66, 0x69, 0x76, 0x65, 0x2c, 0x72, 0x6f, 0x63,
+ 0x6b, 0x65, 0x74, 0x30, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe9,
+ 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0xfc, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x09, 0x00, 0x00, 0x80, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x16,
+ 0x00, 0x00, 0x01, 0x21, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x6d, 0x63, 0x70, 0x75, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x79,
+ 0x00, 0x00, 0x00, 0x8c, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x99, 0x00, 0x00, 0x80, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x2c,
+ 0x00, 0x00, 0x01, 0x37, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x01, 0x42, 0x72, 0x69, 0x73, 0x63,
+ 0x76, 0x2c, 0x73, 0x76, 0x33, 0x39, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0xaa,
+ 0x72, 0x76, 0x36, 0x34, 0x69, 0x6d, 0x61, 0x66, 0x64, 0x63, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x4b,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0xb4,
+ 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x02,
+ 0x63, 0x70, 0x75, 0x40, 0x32, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x03,
+ 0x63, 0x70, 0x75, 0x40, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x04,
+ 0x63, 0x70, 0x75, 0x40, 0x34, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x72, 0x65, 0x66, 0x63, 0x6c, 0x6b, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x21,
+ 0x66, 0x69, 0x78, 0x65, 0x64, 0x2d, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x55,
+ 0x00, 0x00, 0x00, 0x5d, 0x23, 0xc3, 0x46, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x01, 0x62, 0x6d, 0x73, 0x73, 0x70,
+ 0x6c, 0x6c, 0x63, 0x6c, 0x6b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x07,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x65, 0x6d, 0x6f,
+ 0x72, 0x79, 0x40, 0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30,
+ 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07,
+ 0x00, 0x00, 0x00, 0x6d, 0x6d, 0x65, 0x6d, 0x6f, 0x72, 0x79, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0xa6,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x73, 0x6f, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x21,
+ 0x66, 0x73, 0x2d, 0x73, 0x6f, 0x63, 0x00, 0x73, 0x69, 0x6d, 0x70, 0x6c,
+ 0x65, 0x2d, 0x62, 0x75, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x75, 0x00, 0x00, 0x00, 0x01,
+ 0x63, 0x6c, 0x69, 0x6e, 0x74, 0x40, 0x32, 0x30, 0x30, 0x30, 0x30, 0x30,
+ 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0d,
+ 0x00, 0x00, 0x00, 0x21, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x63, 0x6c,
+ 0x69, 0x6e, 0x74, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x50, 0x00, 0x00, 0x01, 0x7c, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x07,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x07,
+ 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0x90, 0x63, 0x6f, 0x6e, 0x74,
+ 0x72, 0x6f, 0x6c, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x5d, 0x00, 0x0f, 0x42, 0x40, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d, 0x63, 0x6f,
+ 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x32, 0x30, 0x31,
+ 0x00, 0x00, 0x00, 0x1f, 0x00, 0x00, 0x00, 0x21, 0x73, 0x69, 0x66, 0x69,
+ 0x76, 0x65, 0x2c, 0x66, 0x75, 0x35, 0x34, 0x30, 0x2d, 0x63, 0x30, 0x30,
+ 0x30, 0x2d, 0x63, 0x63, 0x61, 0x63, 0x68, 0x65, 0x00, 0x63, 0x61, 0x63,
+ 0x68, 0x65, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0x9a, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x8e,
+ 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x9b, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xa6, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xb4, 0x00, 0x00, 0x00, 0x06,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x01, 0xc5,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x02, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x40, 0x63, 0x30, 0x30,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xbb, 0x00, 0x00, 0x00, 0x01,
+ 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x70, 0x6c, 0x69, 0x63, 0x30, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x01, 0xd0, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xe3, 0x00, 0x00, 0x00, 0xba,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xcc,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x48, 0x00, 0x00, 0x01, 0x7c,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x09,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1,
+ 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x63, 0x6c, 0x6b, 0x63, 0x66, 0x67, 0x40, 0x32, 0x30, 0x30, 0x30, 0x32,
+ 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x16,
+ 0x00, 0x00, 0x00, 0x21, 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x63, 0x68, 0x69,
+ 0x70, 0x2c, 0x6d, 0x70, 0x66, 0x73, 0x2d, 0x63, 0x6c, 0x6b, 0x63, 0x66,
+ 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x20, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x01, 0x90, 0x6d, 0x73, 0x73, 0x5f,
+ 0x73, 0x79, 0x73, 0x72, 0x65, 0x67, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xee, 0x00, 0x00, 0x00, 0x07,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0xb7,
+ 0x00, 0x00, 0x01, 0x62, 0x63, 0x70, 0x75, 0x00, 0x61, 0x78, 0x69, 0x00,
+ 0x61, 0x68, 0x62, 0x00, 0x65, 0x6e, 0x76, 0x6d, 0x00, 0x6d, 0x61, 0x63,
+ 0x30, 0x00, 0x6d, 0x61, 0x63, 0x31, 0x00, 0x6d, 0x6d, 0x63, 0x00, 0x74,
+ 0x69, 0x6d, 0x65, 0x72, 0x00, 0x6d, 0x6d, 0x75, 0x61, 0x72, 0x74, 0x30,
+ 0x00, 0x6d, 0x6d, 0x75, 0x61, 0x72, 0x74, 0x31, 0x00, 0x6d, 0x6d, 0x75,
+ 0x61, 0x72, 0x74, 0x32, 0x00, 0x6d, 0x6d, 0x75, 0x61, 0x72, 0x74, 0x33,
+ 0x00, 0x6d, 0x6d, 0x75, 0x61, 0x72, 0x74, 0x34, 0x00, 0x73, 0x70, 0x69,
+ 0x30, 0x00, 0x73, 0x70, 0x69, 0x31, 0x00, 0x69, 0x32, 0x63, 0x30, 0x00,
+ 0x69, 0x32, 0x63, 0x31, 0x00, 0x63, 0x61, 0x6e, 0x30, 0x00, 0x63, 0x61,
+ 0x6e, 0x31, 0x00, 0x75, 0x73, 0x62, 0x00, 0x72, 0x65, 0x73, 0x65, 0x72,
+ 0x76, 0x65, 0x64, 0x00, 0x72, 0x74, 0x63, 0x00, 0x71, 0x73, 0x70, 0x69,
+ 0x00, 0x67, 0x70, 0x69, 0x6f, 0x30, 0x00, 0x67, 0x70, 0x69, 0x6f, 0x31,
+ 0x00, 0x67, 0x70, 0x69, 0x6f, 0x32, 0x00, 0x64, 0x64, 0x72, 0x63, 0x00,
+ 0x66, 0x69, 0x63, 0x30, 0x00, 0x66, 0x69, 0x63, 0x31, 0x00, 0x66, 0x69,
+ 0x63, 0x32, 0x00, 0x66, 0x69, 0x63, 0x33, 0x00, 0x61, 0x74, 0x68, 0x65,
+ 0x6e, 0x61, 0x00, 0x63, 0x66, 0x6d, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xe1, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x6d, 0x63, 0x40,
+ 0x32, 0x30, 0x30, 0x30, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21,
+ 0x66, 0x73, 0x2d, 0x73, 0x64, 0x34, 0x68, 0x63, 0x00, 0x63, 0x64, 0x6e,
+ 0x73, 0x2c, 0x73, 0x64, 0x34, 0x68, 0x63, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x00,
+ 0x20, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0xee,
+ 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0xc5,
+ 0x00, 0x00, 0x00, 0x58, 0x00, 0x00, 0x00, 0x59, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xf5, 0x0b, 0xeb, 0xc2, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x02, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x02, 0x0d, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x02, 0x18, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x02, 0x2a, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x02, 0x3b, 0x00, 0x00, 0x00, 0xc8, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x4d, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x5a, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x69, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x76, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x83, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x90, 0x00, 0x00, 0x00, 0x03,
+ 0x62, 0x6c, 0x65, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x40, 0x32,
+ 0x30, 0x31, 0x30, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x21, 0x6e, 0x73, 0x31, 0x36,
+ 0x35, 0x35, 0x30, 0x61, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x20, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x02, 0x9e,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x02, 0xab, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x01, 0xc5,
+ 0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x5d, 0x08, 0xf0, 0xd1, 0x80, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x01, 0xee, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0xb4, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x73, 0x70, 0x69, 0x40,
+ 0x32, 0x30, 0x31, 0x30, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x21,
+ 0x66, 0x73, 0x2d, 0x73, 0x70, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x20, 0x10, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00,
+ 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0xb4,
+ 0x64, 0x69, 0x73, 0x61, 0x62, 0x6c, 0x65, 0x64, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x69, 0x32, 0x63, 0x40,
+ 0x32, 0x30, 0x31, 0x30, 0x62, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x21, 0x6d, 0x69, 0x63, 0x72,
+ 0x6f, 0x63, 0x68, 0x69, 0x70, 0x2c, 0x6d, 0x70, 0x66, 0x73, 0x2d, 0x69,
+ 0x32, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x00, 0x20, 0x10, 0xb0, 0x00,
+ 0x00, 0x00, 0x00, 0x3d, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x01, 0xee, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x01, 0x86, 0xa0, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0x01, 0x70, 0x61, 0x63, 0x31, 0x39, 0x33, 0x78, 0x40,
+ 0x31, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x12,
+ 0x70, 0x2c, 0x70, 0x61, 0x63, 0x31, 0x39, 0x33, 0x34, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa6,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x02, 0xb5, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x03,
+ 0x63, 0x68, 0x61, 0x6e, 0x6e, 0x65, 0x6c, 0x30, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x02, 0xbf,
+ 0x00, 0x00, 0x27, 0x10, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x02, 0xcf, 0x56, 0x44, 0x44, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xd9, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x61, 0x6e, 0x6e, 0x65, 0x6c, 0x31,
+ 0x00, 0x00, 0x02, 0xbf, 0x00, 0x00, 0x27, 0x10, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x02, 0xcf, 0x56, 0x44, 0x44, 0x41,
+ 0x32, 0x35, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x02, 0xd9, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x63, 0x68, 0x61, 0x6e, 0x6e, 0x65, 0x6c, 0x32, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x27, 0x10, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
+ 0x00, 0x00, 0x02, 0xcf, 0x56, 0x44, 0x44, 0x32, 0x35, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0xd9,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x63, 0x68, 0x61, 0x6e,
+ 0x6e, 0x65, 0x6c, 0x33, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x02, 0xbf, 0x00, 0x00, 0x27, 0x10,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x02, 0xcf,
+ 0x56, 0x44, 0x44, 0x41, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x40, 0x32, 0x30, 0x31,
+ 0x31, 0x32, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x21, 0x6d, 0x69, 0x63, 0x72,
+ 0x6f, 0x63, 0x68, 0x69, 0x70, 0x2c, 0x6d, 0x70, 0x66, 0x73, 0x2d, 0x6d,
+ 0x61, 0x63, 0x62, 0x00, 0x63, 0x64, 0x6e, 0x73, 0x2c, 0x67, 0x65, 0x6d,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x00, 0x20, 0x11, 0x20, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0xc5,
+ 0x00, 0x00, 0x00, 0x46, 0x00, 0x00, 0x00, 0x47, 0x00, 0x00, 0x00, 0x48,
+ 0x00, 0x00, 0x00, 0x49, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06,
+ 0x00, 0x00, 0x02, 0xe9, 0x00, 0x04, 0xa3, 0x00, 0x00, 0x02, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x02, 0xfb,
+ 0x73, 0x67, 0x6d, 0x69, 0x69, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x01, 0xee, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x03, 0x04,
+ 0x70, 0x63, 0x6c, 0x6b, 0x00, 0x68, 0x63, 0x6c, 0x6b, 0x00, 0x00, 0x00,
+ 0x08, 0xf0, 0xd1, 0x80, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x03, 0x10, 0x00, 0x00, 0x00, 0x09,
+ 0x00, 0x00, 0x00, 0x01, 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74,
+ 0x2d, 0x70, 0x68, 0x79, 0x40, 0x39, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0xa6, 0x00, 0x00, 0x00, 0x09,
+ 0x00, 0x00, 0x00, 0x09, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x01, 0x67, 0x70, 0x69, 0x6f, 0x40, 0x32, 0x30, 0x31,
+ 0x32, 0x32, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x21, 0x6d, 0x69, 0x63, 0x72,
+ 0x6f, 0x63, 0x68, 0x69, 0x70, 0x2c, 0x6d, 0x70, 0x66, 0x73, 0x2d, 0x67,
+ 0x70, 0x69, 0x6f, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x01, 0xb4, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x01, 0xc5, 0x00, 0x00, 0x00, 0x0d,
+ 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x10,
+ 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x13,
+ 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x00, 0x16,
+ 0x00, 0x00, 0x00, 0x17, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x19,
+ 0x00, 0x00, 0x00, 0x1a, 0x00, 0x00, 0x00, 0x1b, 0x00, 0x00, 0x00, 0x1c,
+ 0x00, 0x00, 0x00, 0x1d, 0x00, 0x00, 0x00, 0x1e, 0x00, 0x00, 0x00, 0x1f,
+ 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x21, 0x00, 0x00, 0x00, 0x22,
+ 0x00, 0x00, 0x00, 0x23, 0x00, 0x00, 0x00, 0x24, 0x00, 0x00, 0x00, 0x25,
+ 0x00, 0x00, 0x00, 0x26, 0x00, 0x00, 0x00, 0x27, 0x00, 0x00, 0x00, 0x28,
+ 0x00, 0x00, 0x00, 0x29, 0x00, 0x00, 0x00, 0x2a, 0x00, 0x00, 0x00, 0x2b,
+ 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x03, 0x1b, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x01, 0xee, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x00, 0x19,
+ 0x00, 0x00, 0x00, 0x00, 0x20, 0x12, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x01, 0x90, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x03, 0x2b,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x09,
+ 0x00, 0x00, 0x00, 0xb4, 0x64, 0x69, 0x73, 0x61, 0x62, 0x6c, 0x65, 0x64,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64,
+ 0x72, 0x65, 0x73, 0x73, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23,
+ 0x73, 0x69, 0x7a, 0x65, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d,
+ 0x6f, 0x64, 0x65, 0x6c, 0x00, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69,
+ 0x62, 0x6c, 0x65, 0x00, 0x73, 0x65, 0x72, 0x69, 0x61, 0x6c, 0x31, 0x00,
+ 0x65, 0x74, 0x68, 0x65, 0x72, 0x6e, 0x65, 0x74, 0x30, 0x00, 0x73, 0x74,
+ 0x64, 0x6f, 0x75, 0x74, 0x2d, 0x70, 0x61, 0x74, 0x68, 0x00, 0x74, 0x69,
+ 0x6d, 0x65, 0x62, 0x61, 0x73, 0x65, 0x2d, 0x66, 0x72, 0x65, 0x71, 0x75,
+ 0x65, 0x6e, 0x63, 0x79, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x66,
+ 0x72, 0x65, 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x64, 0x65, 0x76,
+ 0x69, 0x63, 0x65, 0x5f, 0x74, 0x79, 0x70, 0x65, 0x00, 0x69, 0x2d, 0x63,
+ 0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x73,
+ 0x69, 0x7a, 0x65, 0x00, 0x69, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d,
+ 0x73, 0x65, 0x74, 0x73, 0x00, 0x69, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65,
+ 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x72, 0x65, 0x67, 0x00, 0x72, 0x69,
+ 0x73, 0x63, 0x76, 0x2c, 0x69, 0x73, 0x61, 0x00, 0x73, 0x74, 0x61, 0x74,
+ 0x75, 0x73, 0x00, 0x23, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
+ 0x74, 0x2d, 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65,
+ 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f,
+ 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65,
+ 0x00, 0x64, 0x2d, 0x63, 0x61, 0x63, 0x68, 0x65, 0x2d, 0x62, 0x6c, 0x6f,
+ 0x63, 0x6b, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d, 0x63, 0x61,
+ 0x63, 0x68, 0x65, 0x2d, 0x73, 0x65, 0x74, 0x73, 0x00, 0x64, 0x2d, 0x63,
+ 0x61, 0x63, 0x68, 0x65, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x64, 0x2d,
+ 0x74, 0x6c, 0x62, 0x2d, 0x73, 0x65, 0x74, 0x73, 0x00, 0x64, 0x2d, 0x74,
+ 0x6c, 0x62, 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x69, 0x2d, 0x74, 0x6c,
+ 0x62, 0x2d, 0x73, 0x65, 0x74, 0x73, 0x00, 0x69, 0x2d, 0x74, 0x6c, 0x62,
+ 0x2d, 0x73, 0x69, 0x7a, 0x65, 0x00, 0x6d, 0x6d, 0x75, 0x2d, 0x74, 0x79,
+ 0x70, 0x65, 0x00, 0x74, 0x6c, 0x62, 0x2d, 0x73, 0x70, 0x6c, 0x69, 0x74,
+ 0x00, 0x23, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x63, 0x65, 0x6c, 0x6c,
+ 0x73, 0x00, 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6f, 0x75, 0x74, 0x70,
+ 0x75, 0x74, 0x2d, 0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00, 0x72, 0x61, 0x6e,
+ 0x67, 0x65, 0x73, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70,
+ 0x74, 0x73, 0x2d, 0x65, 0x78, 0x74, 0x65, 0x6e, 0x64, 0x65, 0x64, 0x00,
+ 0x72, 0x65, 0x67, 0x2d, 0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00, 0x63, 0x61,
+ 0x63, 0x68, 0x65, 0x2d, 0x6c, 0x65, 0x76, 0x65, 0x6c, 0x00, 0x63, 0x61,
+ 0x63, 0x68, 0x65, 0x2d, 0x75, 0x6e, 0x69, 0x66, 0x69, 0x65, 0x64, 0x00,
+ 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75, 0x70, 0x74, 0x2d, 0x70, 0x61,
+ 0x72, 0x65, 0x6e, 0x74, 0x00, 0x69, 0x6e, 0x74, 0x65, 0x72, 0x72, 0x75,
+ 0x70, 0x74, 0x73, 0x00, 0x72, 0x69, 0x73, 0x63, 0x76, 0x2c, 0x6d, 0x61,
+ 0x78, 0x2d, 0x70, 0x72, 0x69, 0x6f, 0x72, 0x69, 0x74, 0x79, 0x00, 0x72,
+ 0x69, 0x73, 0x63, 0x76, 0x2c, 0x6e, 0x64, 0x65, 0x76, 0x00, 0x63, 0x6c,
+ 0x6f, 0x63, 0x6b, 0x73, 0x00, 0x6d, 0x61, 0x78, 0x2d, 0x66, 0x72, 0x65,
+ 0x71, 0x75, 0x65, 0x6e, 0x63, 0x79, 0x00, 0x62, 0x75, 0x73, 0x2d, 0x77,
+ 0x69, 0x64, 0x74, 0x68, 0x00, 0x64, 0x69, 0x73, 0x61, 0x62, 0x6c, 0x65,
+ 0x2d, 0x77, 0x70, 0x00, 0x63, 0x61, 0x70, 0x2d, 0x6d, 0x6d, 0x63, 0x2d,
+ 0x68, 0x69, 0x67, 0x68, 0x73, 0x70, 0x65, 0x65, 0x64, 0x00, 0x63, 0x61,
+ 0x70, 0x2d, 0x73, 0x64, 0x2d, 0x68, 0x69, 0x67, 0x68, 0x73, 0x70, 0x65,
+ 0x65, 0x64, 0x00, 0x63, 0x61, 0x72, 0x64, 0x2d, 0x64, 0x65, 0x74, 0x65,
+ 0x63, 0x74, 0x2d, 0x64, 0x65, 0x6c, 0x61, 0x79, 0x00, 0x6d, 0x6d, 0x63,
+ 0x2d, 0x64, 0x64, 0x72, 0x2d, 0x31, 0x5f, 0x38, 0x76, 0x00, 0x6d, 0x6d,
+ 0x63, 0x2d, 0x68, 0x73, 0x32, 0x30, 0x30, 0x2d, 0x31, 0x5f, 0x38, 0x76,
+ 0x00, 0x73, 0x64, 0x2d, 0x75, 0x68, 0x73, 0x2d, 0x73, 0x64, 0x72, 0x31,
+ 0x32, 0x00, 0x73, 0x64, 0x2d, 0x75, 0x68, 0x73, 0x2d, 0x73, 0x64, 0x72,
+ 0x32, 0x35, 0x00, 0x73, 0x64, 0x2d, 0x75, 0x68, 0x73, 0x2d, 0x73, 0x64,
+ 0x72, 0x35, 0x30, 0x00, 0x73, 0x64, 0x2d, 0x75, 0x68, 0x73, 0x2d, 0x73,
+ 0x64, 0x72, 0x31, 0x30, 0x34, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x69, 0x6f,
+ 0x2d, 0x77, 0x69, 0x64, 0x74, 0x68, 0x00, 0x72, 0x65, 0x67, 0x2d, 0x73,
+ 0x68, 0x69, 0x66, 0x74, 0x00, 0x73, 0x61, 0x6d, 0x70, 0x2d, 0x72, 0x61,
+ 0x74, 0x65, 0x00, 0x75, 0x6f, 0x68, 0x6d, 0x73, 0x2d, 0x73, 0x68, 0x75,
+ 0x6e, 0x74, 0x2d, 0x72, 0x65, 0x73, 0x00, 0x72, 0x61, 0x69, 0x6c, 0x2d,
+ 0x6e, 0x61, 0x6d, 0x65, 0x00, 0x63, 0x68, 0x61, 0x6e, 0x6e, 0x65, 0x6c,
+ 0x5f, 0x65, 0x6e, 0x61, 0x62, 0x6c, 0x65, 0x64, 0x00, 0x6c, 0x6f, 0x63,
+ 0x61, 0x6c, 0x2d, 0x6d, 0x61, 0x63, 0x2d, 0x61, 0x64, 0x64, 0x72, 0x65,
+ 0x73, 0x73, 0x00, 0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00,
+ 0x63, 0x6c, 0x6f, 0x63, 0x6b, 0x2d, 0x6e, 0x61, 0x6d, 0x65, 0x73, 0x00,
+ 0x70, 0x68, 0x79, 0x2d, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x67,
+ 0x70, 0x69, 0x6f, 0x2d, 0x63, 0x6f, 0x6e, 0x74, 0x72, 0x6f, 0x6c, 0x6c,
+ 0x65, 0x72, 0x00, 0x23, 0x67, 0x70, 0x69, 0x6f, 0x2d, 0x63, 0x65, 0x6c,
+ 0x6c, 0x73, 0x00,
+#endif /* __system_dtb_h */
2.25.1
