Successful Hello world from RPi4B AArch64 over serial
Joel Sherrill joel.sherrill at gmail.com
Mon Sep 19 20:35:41 UTC 2022
On Mon, Sep 19, 2022, 1:23 PM Alan Cudmore <alan.cudmore at gmail.com> wrote:
> I built the TF-A binary, your dev branch, used the config.txt described
> below, and was able to run unlimited.exe. (I’m using a Pi4b 2GB)
> Great milestone!
This is great news! Now to get it merged for others.
Are any other peripherals from previous Pi generations the same? Curious if
wired networking might be low hanging fruit.
--joel
> Alan
> *From: *Noor Aman <nooraman5718 at gmail.com>
> *Sent: *Monday, September 19, 2022 11:11 AM
> *To: *William Moore <WKMoore at gmail.com>; Alan Cudmore
> <alancudmore at gmail.com>; Hesham Moustafa <heshamelmatary at gmail.com>;
> rtems-devel at rtems.org <devel at rtems.org>
> *Subject: *Successful Hello world from RPi4B AArch64 over serial
> Hey everyone,
> I've managed to get RTEMS6 on the Raspberry pi 4B rev 1.4. Every test ran
> fine except for minimum.exe, It gave a fatal error.
> Here's my setup for running RTEMS6 on RPi4B:
> TF-A is required to enable GIC on RPi. I had tried to use armstub-gic.S (
> https://github.com/raspberrypi/tools/blob/master/armstubs/armstub8.S) but
> it didn't work out. TF-A on other hand did work pretty well.
> Steps to get TF-A binary are described here:
> https://trustedfirmware-a.readthedocs.io/en/latest/plat/rpi4.html
> Config.txt section:
> arm_64bit=1
> enable_uart=1
> gpio=22-27=np
> enable_jtag_gpio=1
> dtoverlay=disable-bt
> kernel=kernel8.img
> enable_gic=1
> armstub=bl31.bin
> RTEMS6
> My branch (noov-dev): https://github.com/0xnoor/rtems/tree/noor-dev
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220919/c31530dd/attachment.htm>
