[PATCH v2 0/4] Microchip PolarFire SoC support
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Tue Sep 20 06:50:43 UTC 2022
RTEMS SMP on the Microchip PolarFire Icicle Kit
Test Procedure:
1. Create the "config.ini" file with below content at rtems root
	[riscv/mpfs64imafdc]
	BUILD_TESTS = True
	RTEMS_POSIX_API=True
	RTEMS_SMP = True
	BSP_START_COPY_FDT_FROM_U_BOOT=False
	BSP_VERBOSE_FATAL_EXTENSION = False
2. Build RTEMS
	$ ./waf configure --prefix=$HOME/rtems-start/rtems/6
	$ ./waf
3. Convert .exe to .elf file
$ riscv-rtems6-objcopy 	build/riscv/mpfs64imafdc/testsuites/smptests/sm
p01.exe
 build/riscv/mpfs64imafdc/testsuites/smptests/smp01.elf
4. Generate the payload for the smp01.elf using the hss-payload-
generator with hart-entry-points/exec-addr: 0x1000000000
https://github.com/polarfire-soc/hart-software-services/tree/master/tools/hss-payload-generator
5. Programming the'payload.bin' for the eMMC/SD
 5.1) Board setting and FPGA Programing
https://github.com/polarfire-soc/polarfire-soc-documentation/blob/master/boards/mpfs-icicle-kit-es/updating-icicle-kit/updating-icicle-kit-design-and-linux.md
 5.2). Power Cycle the Microchip PolarFire Icicle Kit and stop at the
       HSS.
 5.3) type "mmc" and then "usbdmsc" on the HSS terminal(UART0).
 5.4) Load payload from the Host PC.
	$ sudo dd if=payload.bin of=/dev/sdb bs=512
 5.5) Quit USB and Reset the Icicle Kit
 5.6) Serial terminal UART1 displays the SMP example messages
*** BEGIN OF TEST SMP 1 ***
*** TEST VERSION: 6.0.0.ef33f861e16de9bf4190a36e4d18062c7300986c
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 12.1.1 20220622 (RTEMS 6, RSB 3cb78b0b815ba05d17f5c6
		5865d246a8333aa087, Newlib ea99f21)
CPU 3 start task TA0
CPU 2 running Task TA0
CPU 3 start task TA1
CPU 1 running Task TA1
CPU 3 start task TA2
CPU 0 running Task TA2
*** END OF TEST SMP 1 ***
Regards
Padmarao
On Mon, 2022-09-19 at 18:30 +0530, Padmarao Begari wrote:
> This patch set adds the Microchip PolarFire SoC BSP Variant
> support to RISC-V RTEMS.
> The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and
> a 64-bit RISC-V E51 monitor core SoC from Microchip, more
> info available here:
> 	https://www.microchip.com/en-us/products/fpgas-and-plds/
> 	system-on-chip-fpgas/polarfire-soc-fpgas#Overview
> This new BSP variant is added for the 4x U54 cores not for E51
> because the E51 monitor core is resreved for first stage
> bootloader (Hart Software Services).
> The boot HARTID configurable is implemented for the riscv BSP
> to work with individual hart(cpu core) or SMP.
> This BSP support components: 4 CPU Cores (U54), Interrupt
> controller (PLIC), Timer (CLINT), UART (16550-compatible)
> work fine on actual Microchip PolarFire SoC Icicle Kit.
> v2:
> - Add a license and copyright information in dtb header file
> - Use RISCV_BOOT_HARDID instead of RTEMS_BOOT_HARDID
> - Add '_RISCV_Map_hardid_to_cpu_index()' and
> '_RISCV_Map_cpu_index_to_hardid()' functions
> - Change bsp_fdt_get() instead of bsp_fdt_copy() function for dtb
> - Move dtb and dtb header configurable build option to the bsps
> Padmarao Begari (4):
>   bsps/riscv: Add device tree blob
>   spec/build/bsps: Add dtb support
>   bsps/riscv: Add Microchip PolarFire SoC BSP variant
>   bsps/shared/: Use device tree blob
>  bsps/riscv/riscv/clock/clockdrv.c             |   6 +-
>  bsps/riscv/riscv/config/mpfs64imafdc.cfg      |   9 +
>  bsps/riscv/riscv/dts/mpfs.dts                 | 365 +++++++++++
>  bsps/riscv/riscv/include/bsp/mpfs-dtb.h       | 602
>  bsps/riscv/riscv/include/bsp/riscv.h          |  14 +
>  bsps/riscv/riscv/irq/irq.c                    |  81 +++
>  bsps/riscv/riscv/start/bsp_fatal_halt.c       |   3 +
>  bsps/riscv/riscv/start/bspsmp.c               |   2 +-
>  bsps/riscv/riscv/start/bspstart.c             |  19 +-
>  bsps/riscv/shared/start/start.S               |   2 +
>  bsps/shared/start/bsp-fdt.c                   |   8 +
>  .../score/cpu/riscv/include/rtems/score/cpu.h |   2 +-
>  .../cpu/riscv/include/rtems/score/cpuimpl.h   |   2 +-
>  spec/build/bsps/optdtb.yml                    |  19 +
>  spec/build/bsps/optdtbheaderpath.yml          |  20 +
>  spec/build/bsps/riscv/optextirqmax.yml        |   5 +-
>  spec/build/bsps/riscv/optrambegin.yml         |   5 +-
>  spec/build/bsps/riscv/optramsize.yml          |   5 +-
>  spec/build/bsps/riscv/riscv/abi.yml           |   6 +
>  .../bsps/riscv/riscv/bspmpfs64imafdc.yml      |  19 +
>  spec/build/bsps/riscv/riscv/grp.yml           |   6 +
>  spec/build/bsps/riscv/riscv/optmpfs.yml       |  18 +
>  spec/build/bsps/riscv/riscv/optns16550max.yml |   3 +
>  spec/build/cpukit/cpuopts.yml                 |   2 +
>  spec/build/cpukit/optarchbits.yml             |   1 +
>  spec/build/cpukit/optboothartid.yml           |  19 +
>  spec/build/cpukit/optsmp.yml                  |   1 +
>  27 files changed, 1235 insertions(+), 9 deletions(-)
>  create mode 100644 bsps/riscv/riscv/config/mpfs64imafdc.cfg
>  create mode 100644 bsps/riscv/riscv/dts/mpfs.dts
>  create mode 100644 bsps/riscv/riscv/include/bsp/mpfs-dtb.h
>  create mode 100644 spec/build/bsps/optdtb.yml
>  create mode 100644 spec/build/bsps/optdtbheaderpath.yml
>  create mode 100644 spec/build/bsps/riscv/riscv/bspmpfs64imafdc.yml
>  create mode 100644 spec/build/bsps/riscv/riscv/optmpfs.yml
>  create mode 100644 spec/build/cpukit/optboothartid.yml
