[PATCH v2 0/4] Microchip PolarFire SoC support
Padmarao.Begari at microchip.com Padmarao.Begari at microchip.com
Tue Sep 20 05:59:51 UTC 2022
Hi Alan,
> On Mon, 2022-09-19 at 12:49 -0400, Alan Cudmore wrote:
> EXTERNAL EMAIL: Do not click links or open attachments unless you
> know the content is safe
> Hi Padmarao,
> The patches apply cleanly and build for me. What is the recommended
> config.ini file for this BSP?
> I used:
> [riscv/mpfs64imafdc]
> BUILD_TESTS=True
> RTEMS_POSIX_API=True
> RTEMS_SMP=True
> BSP_START_COPY_FDT_FROM_U_BOOT=False
> BSP_DTB_IS_SUPPORTED=True
> BSP_DTB_HEADER_PATH=bsp/mpfs-dtb.h
Yes We can use same like your config.ini file, working fine for me.
The BSP is enabled the 'BSP_DTB_IS_SUPPORTED' and 'BSP_DTB_HEADER_PATH'
by default so I used like below:
BUILD_TESTS=True
RTEMS_SMP=True
> I don't have a Polarfire SoC board, but is there a QEMU platform to
> run this on?
Yes QEMU Platform is there for the Microchip PolarFire SoC Icicle Kit
but I didn't test it.
Regards
Padmarao
> When this is in, I will rebase my k210 variant and eventually get it
> submitted!
> Thanks,
> Alan
> On Mon, Sep 19, 2022 at 9:00 AM Padmarao Begari <
> padmarao.begari at microchip.com> wrote:
> > This patch set adds the Microchip PolarFire SoC BSP Variant
> > support to RISC-V RTEMS.
> > The PolarFire SoC is the 4x 64-bit RISC-V U54 cores and
> > a 64-bit RISC-V E51 monitor core SoC from Microchip, more
> > info available here:
> >         https://www.microchip.com/en-us/products/fpgas-and-plds/
> >         system-on-chip-fpgas/polarfire-soc-fpgas#Overview
> > This new BSP variant is added for the 4x U54 cores not for E51
> > because the E51 monitor core is resreved for first stage
> > bootloader (Hart Software Services).
> > The boot HARTID configurable is implemented for the riscv BSP
> > to work with individual hart(cpu core) or SMP.
> > This BSP support components: 4 CPU Cores (U54), Interrupt
> > controller (PLIC), Timer (CLINT), UART (16550-compatible)
> > work fine on actual Microchip PolarFire SoC Icicle Kit.
> > v2:
> > - Add a license and copyright information in dtb header file
> > - Use RISCV_BOOT_HARDID instead of RTEMS_BOOT_HARDID
> > - Add '_RISCV_Map_hardid_to_cpu_index()' and
> > '_RISCV_Map_cpu_index_to_hardid()' functions
> > - Change bsp_fdt_get() instead of bsp_fdt_copy() function for dtb
> > - Move dtb and dtb header configurable build option to the bsps
> > Padmarao Begari (4):
> >   bsps/riscv: Add device tree blob
> >   spec/build/bsps: Add dtb support
> >   bsps/riscv: Add Microchip PolarFire SoC BSP variant
> >   bsps/shared/: Use device tree blob
> >  bsps/riscv/riscv/clock/clockdrv.c             |   6 +-
> >  bsps/riscv/riscv/config/mpfs64imafdc.cfg      |   9 +
> >  bsps/riscv/riscv/dts/mpfs.dts                 | 365 +++++++++++
> >  bsps/riscv/riscv/include/bsp/mpfs-dtb.h       | 602
> >  bsps/riscv/riscv/include/bsp/riscv.h          |  14 +
> >  bsps/riscv/riscv/irq/irq.c                    |  81 +++
> >  bsps/riscv/riscv/start/bsp_fatal_halt.c       |   3 +
> >  bsps/riscv/riscv/start/bspsmp.c               |   2 +-
> >  bsps/riscv/riscv/start/bspstart.c             |  19 +-
> >  bsps/riscv/shared/start/start.S               |   2 +
> >  bsps/shared/start/bsp-fdt.c                   |   8 +
> >  .../score/cpu/riscv/include/rtems/score/cpu.h |   2 +-
> >  .../cpu/riscv/include/rtems/score/cpuimpl.h   |   2 +-
> >  spec/build/bsps/optdtb.yml                    |  19 +
> >  spec/build/bsps/optdtbheaderpath.yml          |  20 +
> >  spec/build/bsps/riscv/optextirqmax.yml        |   5 +-
> >  spec/build/bsps/riscv/optrambegin.yml         |   5 +-
> >  spec/build/bsps/riscv/optramsize.yml          |   5 +-
> >  spec/build/bsps/riscv/riscv/abi.yml           |   6 +
> >  .../bsps/riscv/riscv/bspmpfs64imafdc.yml      |  19 +
> >  spec/build/bsps/riscv/riscv/grp.yml           |   6 +
> >  spec/build/bsps/riscv/riscv/optmpfs.yml       |  18 +
> >  spec/build/bsps/riscv/riscv/optns16550max.yml |   3 +
> >  spec/build/cpukit/cpuopts.yml                 |   2 +
> >  spec/build/cpukit/optarchbits.yml             |   1 +
> >  spec/build/cpukit/optboothartid.yml           |  19 +
> >  spec/build/cpukit/optsmp.yml                  |   1 +
> >  27 files changed, 1235 insertions(+), 9 deletions(-)
> >  create mode 100644 bsps/riscv/riscv/config/mpfs64imafdc.cfg
> >  create mode 100644 bsps/riscv/riscv/dts/mpfs.dts
> >  create mode 100644 bsps/riscv/riscv/include/bsp/mpfs-dtb.h
> >  create mode 100644 spec/build/bsps/optdtb.yml
> >  create mode 100644 spec/build/bsps/optdtbheaderpath.yml
> >  create mode 100644 spec/build/bsps/riscv/riscv/bspmpfs64imafdc.yml
> >  create mode 100644 spec/build/bsps/riscv/riscv/optmpfs.yml
> >  create mode 100644 spec/build/cpukit/optboothartid.yml
