[PATCH] bsps/arm: Fix start in hypervisor mode
Chris Johns
chrisj at rtems.org
Wed Sep 21 03:12:18 UTC 2022
On 20/9/2022 9:12 pm, Sebastian Huber wrote:
> Only clear the HSCTLR[TE] bit to take exceptions in A32 state. Keep the
> other HSCTLR bits as is since they control the current execution.
> Assume that the chip or boot loader did initialize this register
> correctly.
I think this change should have a ticket that describe the reason you found the
problem and on which ARM variant(s)? I think a ticket would help someone dealing
with a boot loader that does not set this register correctly.
> Add comments.
> bsps/arm/shared/start/start.S | 21 ++++++++++++---------
> 1 file changed, 12 insertions(+), 9 deletions(-)
> diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
> index 32b168917a..c7fad5ae58 100644
> --- a/bsps/arm/shared/start/start.S
> +++ b/bsps/arm/shared/start/start.S
> @@ -249,22 +249,25 @@ _start:
> mov sp, r3
> sub r3, r3, r1
> + /* Set HVBAR */
> ldr r0, =bsp_start_hyp_vector_table_begin
> mcr p15, 4, r0, c12, c0, 0
> + /* Set HVC, HCPTR, and HSTR to zero */
> mov r0, #0
> mcr p15, 4, r0, c1, c1, 0
> mcr p15, 4, r0, c1, c1, 2
> mcr p15, 4, r0, c1, c1, 3
> - * HSCTLR.TE
> - * optional start of hypervisor handlers in Thumb mode
> - * orr r0, #(1 << 30)
> - mcr p15, 4, r0, c1, c0, 0 /* HSCTLR */
> - mrc p15, 4, r0, c1, c1, 1 /* HDCR */
> - and r0, #0x1f /* Preserve HPMN */
> - mcr p15, 4, r0, c1, c1, 1 /* HDCR */
> + /* Clear HSCTLR[TE] to take exceptions in A32 state */
> + mrc p15, 4, r0, c1, c0, 0
> + bic r0, #(1 << 30)
> + mcr p15, 4, r0, c1, c0, 0
> + /* Set HDCR to zero except HDCR[HPMN] */
> + mrc p15, 4, r0, c1, c1, 1
> + and r0, #0x1f
> + mcr p15, 4, r0, c1, c1, 1
> /* Prepare SVC mode for eret */
> mrs r0, cpsr
