[PATCH 1/7] bsp/aarch64: New entry for Raspberry pi 4B AArch64 BSP
Mohd Noor Aman nooraman5718 at gmail.com
Thu Sep 22 06:20:37 UTC 2022
This commit adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family. Currently only IPL64 ABI is supported. IPL32 Supported will be added in the near future.
 spec/build/bsps/aarch64/raspberrypi/abi.yml   | 21 +++++
 .../aarch64/raspberrypi/bspraspberrypi4.yml   | 78 +++++++++++++++++++
 2 files changed, 99 insertions(+)
 create mode 100644 spec/build/bsps/aarch64/raspberrypi/abi.yml
 create mode 100644 spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml b/spec/build/bsps/aarch64/raspberrypi/abi.yml
new file mode 100644
index 0000000000..9ed4a961a7
--- /dev/null
+++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) Copyright (C) 2022 Mohd Noor Aman
+default:
+- -mcpu=cortex-a72
+- -march=armv8-a
+default-by-variant: []
+includes: []
+description: |
+  ABI flags
+links: []
+enabled-by: true
+name: ABI_FLAGS
+type: build
\ No newline at end of file
diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
index 0000000000..8b4447db46
--- /dev/null
+++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
@@ -0,0 +1,78 @@
+arch: aarch64
+bsp: raspberrypi4b
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2022 Mohd Noor Aman
+cppflags: []
+enabled-by: true
+family: raspberrypi
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - bsps/aarch64/raspberrypi/include/bsp.h
+  - bsps/aarch64/raspberrypi/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/aarch64/raspberrypi/include/bsp/irq.h
+  - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
+source:
+- bsps/aarch64/raspberrypi/console/console.c
+- bsps/aarch64/raspberrypi/start/bspstart.c
+- bsps/aarch64/raspberrypi/start/bspstarthooks.c
+- bsps/aarch64/raspberrypi/start/bspstartmmu.c
+- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+- bsps/aarch64/shared/cache/cache.c
+- bsps/shared/dev/clock/arm-generic-timer.c
+- bsps/shared/dev/irq/arm-gicv2.c
+- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/dev/serial/arm-pl011.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/irq/irq-handler-install.c
+- bsps/shared/irq/irq-generic.c
+- bsps/shared/irq/irq-lock.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspreset-arm-psci.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/start/wkspaceinitone.c
+- bsps/shared/start/mallocinitmulti.c
+- bsps/shared/start/bspgetworkarea-default.c
+links:
+- role: build-dependency
+  uid: ../grp
+  uid: ../start
+  uid: ../optmmupages
+  uid: ../optgtusevirt
+  uid: ../optgtuseps
+  uid: abi
+  uid: ../../optcachedata
+  uid: ../../optcacheinst
+  uid: ../../opto2
+  uid: ../../bspopts
+  uid: linkercmds
+  uid: ../../obj
+  uid: ../../objirq
+type: build
2.34.1
