[PATCH 2/7] bsp/aarch64: Linker file for Raspberry pi 4B AArch64 BSP
    Mohd Noor Aman
    nooraman5718 at gmail.com
    Thu Sep 22 06:20:38 UTC 2022
Linker sections for RAM and MMU is added. RAM starts from 0x80000 in the arm64 bit mode for Raspberry pi 4B and MMU from 0x0.
 .../bsps/aarch64/raspberrypi/linkercmds.yml   | 76 +++++++++++++++++++
 1 file changed, 76 insertions(+)
 create mode 100644 spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
new file mode 100644
index 0000000000..8598b89cba
--- /dev/null
+++ b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
@@ -0,0 +1,76 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: config-file
+content: |
+  /* SPDX-License-Identifier: BSD-2-Clause */
+   * Copyright (C) 2022 Mohd Noor Aman
+   * Redistribution and use in source and binary forms, with or without
+   * modification, are permitted provided that the following conditions
+   * are met:
+   * 1. Redistributions of source code must retain the above copyright
+   *    notice, this list of conditions and the following disclaimer.
+   * 2. Redistributions in binary form must reproduce the above copyright
+   *    notice, this list of conditions and the following disclaimer in the
+   *    documentation and/or other materials provided with the distribution.
+   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+   * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+   * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+   * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+   * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+   * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+   * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+   * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+   * POSSIBILITY OF SUCH DAMAGE.
+  MEMORY {
+  RAM_MMU  : ORIGIN = 0x0, LENGTH = (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
+  RAM      : ORIGIN = 0x80000, LENGTH = 1024M
+  REGION_ALIAS ("REGION_START",          RAM);
+  REGION_ALIAS ("REGION_VECTOR",         RAM);
+  REGION_ALIAS ("REGION_TEXT",           RAM);
+  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
+  REGION_ALIAS ("REGION_RODATA",         RAM);
+  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
+  REGION_ALIAS ("REGION_DATA",           RAM);
+  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
+  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
+  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
+  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+  REGION_ALIAS ("REGION_BSS",            RAM);
+  REGION_ALIAS ("REGION_WORK",           RAM);
+  REGION_ALIAS ("REGION_STACK",          RAM);
+  REGION_ALIAS ("REGION_NOCACHE",        RAM);
+  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
+  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
+  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+  bsp_vector_table_in_start_section = 1;
+  bsp_translation_table_base = ORIGIN (RAM_MMU);
+  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
+  OUTPUT_FORMAT ("elf64-littleaarch64")
+  OUTPUT_ARCH (aarch64)
+  INCLUDE linkcmds.base
+copyrights:
+- Copyright (C) 2022 Mohd Noor Aman
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
2.34.1
