[PATCH 4/7] bsp/aarch64: BSP and TM27 headers for the Raspberry pi 4B AArch64 BSP
Mohd Noor Aman
nooraman5718 at gmail.com
Thu Sep 22 06:20:40 UTC 2022
This commits includes tm27 and bsp headers. Only GIC-400 and UART1 address is defined in the bsp.h . Other UARTS addresses would be included soon in future.
bsps/aarch64/raspberrypi/include/bsp.h | 73 +++++++++++++++++++++++++
bsps/aarch64/raspberrypi/include/tm27.h | 46 ++++++++++++++++
2 files changed, 119 insertions(+)
create mode 100644 bsps/aarch64/raspberrypi/include/bsp.h
create mode 100644 bsps/aarch64/raspberrypi/include/tm27.h
diff --git a/bsps/aarch64/raspberrypi/include/bsp.h b/bsps/aarch64/raspberrypi/include/bsp.h
new file mode 100644
index 0000000000..d94a0432d5
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/bsp.h
@@ -0,0 +1,73 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64Raspberrypi4
+ * @brief Core BSP definitions
+ * Copyright (C) 2022 Mohd Noor Aman
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
+#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
+ * @addtogroup RTEMSBSPsAArch64
+#include <bspopts.h>
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
+#define BSP_ARM_GIC_DIST_BASE 0xFF841000
+#define BSP_RPI4_PL011_BASE 0xFE201000
+#define BSP_RPI4_PL011_LENGTH 0x200
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
diff --git a/bsps/aarch64/raspberrypi/include/tm27.h b/bsps/aarch64/raspberrypi/include/tm27.h
index 0000000000..653f88ed01
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/tm27.h
@@ -0,0 +1,46 @@
+ * @file
+ * @brief BSP tm27 header
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <dev/irq/arm-gic-tm27.h>
+#endif /* __tm27_h */
\ No newline at end of file
2.34.1
