[PATCH 3/7] bsp/aarch64: IRQ headers for raspberry pi 4B
Mohd Noor Aman
nooraman5718 at gmail.com
Thu Sep 22 06:20:39 UTC 2022
These are same IRQs from the rapsberry pi 3. All the IRQs are same as of now. More GIC-400 related interrupts would be required in future but currently these are enough for basic BSP.
bsps/aarch64/raspberrypi/include/bsp/irq.h | 109 +++++++++++++++++++++
1 file changed, 109 insertions(+)
create mode 100644 bsps/aarch64/raspberrypi/include/bsp/irq.h
diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h b/bsps/aarch64/raspberrypi/include/bsp/irq.h
new file mode 100644
index 0000000000..effec1b040
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
@@ -0,0 +1,109 @@
+ * @file
+ * @ingroup raspberrypi_interrupt
+ * @brief Interrupt definitions.
+ * Copyright (c) 2013 Alan Cudmore
+ * Copyright (c) 2022 Mohd Noor Aman
+ * http://www.rtems.org/license/LICENSE
+#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
+#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
+#ifndef ASM
+#include <rtems.h>
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <dev/irq/arm-gic-irq.h>
+#if defined(RTEMS_SMP)
+#include <rtems/score/processormask.h>
+#endif
+ * @defgroup raspberrypi_interrupt Interrrupt Support
+ * @ingroup RTEMSBSPsARMRaspberryPi
+ * @brief Interrupt support.
+#define BCM2835_INTC_TOTAL_IRQ (64 + 8)
+#define BCM2835_IRQ_SET1_MIN 0
+#define BCM2835_IRQ_SET2_MIN 32
+#define BCM2835_IRQ_ID_GPU_TIMER_M0 0
+#define BCM2835_IRQ_ID_GPU_TIMER_M1 1
+#define BCM2835_IRQ_ID_GPU_TIMER_M2 2
+#define BCM2835_IRQ_ID_GPU_TIMER_M3 3
+#define BCM2835_IRQ_ID_USB 9
+#define BCM2835_IRQ_ID_AUX 29
+#define BCM2835_IRQ_ID_SPI_SLAVE 43
+#define BCM2835_IRQ_ID_PWA0 45
+#define BCM2835_IRQ_ID_PWA1 46
+#define BCM2835_IRQ_ID_SMI 48
+#define BCM2835_IRQ_ID_GPIO_0 49
+#define BCM2835_IRQ_ID_GPIO_1 50
+#define BCM2835_IRQ_ID_GPIO_2 51
+#define BCM2835_IRQ_ID_GPIO_3 52
+#define BCM2835_IRQ_ID_I2C 53
+#define BCM2835_IRQ_ID_SPI 54
+#define BCM2835_IRQ_ID_PCM 55
+#define BCM2835_IRQ_ID_UART 57
+#define BCM2835_IRQ_ID_SD 62
+#define BCM2835_IRQ_ID_BASIC_BASE_ID 64
+#define BCM2835_IRQ_ID_TIMER_0 64
+#define BCM2835_IRQ_ID_MAILBOX_0 65
+#define BCM2835_IRQ_ID_DOORBELL_0 66
+#define BCM2835_IRQ_ID_DOORBELL_1 67
+#define BCM2835_IRQ_ID_GPU0_HALTED 68
+#define BCM2835_IRQ_ID_GPU1_HALTED 69
+#define BCM2835_IRQ_ID_ILL_ACCESS_1 70
+#define BCM2835_IRQ_ID_ILL_ACCESS_0 71
+#define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_NS_PPI 30
+#define BSP_VPL011_SPI 32
+#define BSP_INTERRUPT_VECTOR_COUNT BCM2835_INTC_TOTAL_IRQ
+#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
+#define BSP_IRQ_COUNT (BCM2835_INTC_TOTAL_IRQ)
+static inline rtems_status_code bsp_interrupt_set_affinity(
+ rtems_vector_number vector,
+ const Processor_mask *affinity
+ (void) vector;
+ (void) affinity;
+ return RTEMS_UNSATISFIED;
+static inline rtems_status_code bsp_interrupt_get_affinity(
+ Processor_mask *affinity
+ (void) vector;
+ _Processor_mask_From_index( affinity, 0 );
+#endif
+#endif /* ASM */
+#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
2.34.1
