[PATCH] c-user: Add application config info directives
Fri Sep 23 06:55:40 UTC 2022
On 23/9/2022 4:34 pm, Sebastian Huber wrote:
> On 23.09.22 00:04, Chris Johns wrote:
>> On 22/9/2022 6:18 pm, Sebastian Huber wrote:
>>> On 17/09/2022 09:31, Chris Johns wrote:
>>>>> +.. index:: rtems_configuration_get_rtems_api_configuration()
>>>>> +.. _InterfaceRtemsConfigurationGetRtemsApiConfiguration:
>>>>> +rtems_configuration_get_rtems_api_configuration()
>>>>> +Gets the Classic API Configuration Table of this application.
>>>> Would a comment here that the header file xxx.h describes the fields
>>>> in the
>>>> returned structure?
>>> The API data structures are fully specified and documented.
>> We do not have doxygen links online and we do not have suitable links
>> in a
>> release. So I am not sure how this helps unless you know part of all
>> of the
>> answer to the question ... where is it defined?
> For example:
> https://git.rtems.org/rtems-central/tree/spec/rtems/config/if/api-table.yml
>>> What is missing is
>>> the Sphinx documentation generation support. One option would be to
>>> add a
>>> "Types" section to the manager chapters and document the
>>> corresponding types in
>>> this section.
>> I was after something a little simpler. For the structs a file name
>> the struct
>> is in so a user can quickly find it without needing to understand any
>> of the
>> code, headers or how we do things.
> It wouldn't be hard to generate some documentation for types. There are
> some options to do this.
Oh OK, nice.
> Do we want a single chapter with all Classic API types?
> Do we want a section per manager for the types?
> Which types should be documented?
> I would document them in a single chapter and only structs.
There are 2 cases in relation to this thread and patch. Having something
documented with the macro that is the right type and then a simple means
to step from a specific function/macro to the fields if a struct. Does
this make sense?
I have not consider any more so I am not sure how we handle all the
types. Maybe Joel or Gedare do. :)
