[PATCH] c-user: Add application config info directives
    Sebastian Huber
    Fri Sep 23 07:04:56 UTC 2022
On 23.09.22 08:55, Chris Johns wrote:
>> Do we want a single chapter with all Classic API types?
>> Do we want a section per manager for the types?
>> Which types should be documented?
>> I would document them in a single chapter and only structs.
> There are 2 cases in relation to this thread and patch. Having something
> documented with the macro that is the right type and then a simple means
> to step from a specific function/macro to the fields if a struct. Does
> this make sense?
The types can be fixed by using an inline function instead of a macro.
For directives which need a macro implementation, we could add an
additional real function just like for rtems_build_name().
> I have not consider any more so I am not sure how we handle all the
> types. Maybe Joel or Gedare do. 😄
The missing types documentation is also relevant to other functions, for
example:
https://docs.rtems.org/branches/master/c-user/task/directives.html#rtems-task-construct
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
