[RTEMS SMP ISVV] : Timer Server
Luis Alves lmbalves at gmail.com
Fri Sep 23 11:19:55 UTC 2022
Dear RTEMS community,
I’m part of the team performing the Independent Software Verification and
Validation (ISVV) of the RTEMS SMP Qualification Data Pack (which is being
provided through https://rtems-qual.io.esa.int/).
While trying to setup tests to assert the overall “Timer Server” feature,
one has realized that:
   - Although rtems_timer_initiate_server() is mentioned within section
   4.10 of the SW Configuration File (SCF) as a pre-qualified item (“*which
   may be directly used by applications*”), one gets build issues while
   trying to use it, as it depends on rtems_timer_create().
   - The same SCF (within section 4.9.3) also says: “*The
   rtems_task_create() directive is pre-qualified, however, it is only
   available if a custom stack allocator is configured. It is recommended to
   use rtems_task_construct() instead*”:
      - Isn’t this contradictory, as:
         - Both rtems_timer_initiate_server() and tems_task_create() are
         listed within SCF section 4.10 and
         - at the start of section 4.10, it is said that listed items
are “*pre-qualified
         items .. which may be directly used by applications*”?
      - Given this, shouldn’t rtems_timer_initiate_server() natively use of
   rtems_task_construct() rather than rtems_timer_create() as advised?
   - This makes other two functions listed within SCF section 4.10 as not
   directly usable, namely rtems_timer_server_fire_after() and
   rtems_timer_server_fire_when() as those are to be used in conjunction with
   rtems_timer_initiate_server().
   - In a nutshell, this compromises the overall “Timer Server” feature in
   the qual-only setup of the QDP.
Can the community help to clarify these points, and tell us what and how
can one improve the RTEMS SMP QDP w.r.t. this (at the documentation and
qual-only implementation level)?
Thanks in advance for the clarifications,
Kind Regards
Luís Alves
Critical Software
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220923/5202edcf/attachment-0001.htm>
