[RTEMS SMP ISVV] : Timer Server
Fri Sep 23 11:55:44 UTC 2022
On 23.09.22 13:19, Luis Alves wrote:
> Dear RTEMS community,
> I’m part of the team performing the Independent Software Verification
> and Validation (ISVV) of the RTEMS SMP Qualification Data Pack (which is
> being provided through https://rtems-qual.io.esa.int/
> <https://rtems-qual.io.esa.int/>).
> While trying to setup tests to assert the overall “Timer Server”
> feature, one has realized that:
>   * Although rtems_timer_initiate_server() is mentioned within section
>     4.10 of the SW Configuration File (SCF) as a pre-qualified item
>     (“/which may be directly used by applications/”), one gets build
>     issues while trying to use it, as it depends on rtems_timer_create().
Yes.
>   * The same SCF (within section 4.9.3) also says: “/The
>     rtems_task_create() directive is pre-qualified, however, it is only
>     available if a custom stack allocator is configured. It is
>     recommended to use rtems_task_construct() instead/”:
>       o Isn’t this contradictory, as:
>           + Both rtems_timer_initiate_server() and tems_task_create()
>             are listed within SCF section 4.10 and
>           + at the start of section 4.10, it is said that listed items
>             are “/pre-qualified items .. which may be directly used by
>             applications/”?
For the current pre-qualified feature set of RTEMS, if you want to use
rtems_timer_initiate_server(), then you have to provide a custom stack
allocator.
>   * Given this, shouldn’t rtems_timer_initiate_server() natively use of
>     rtems_task_construct() rather than rtems_timer_create() as advised?
If you don't want to change the API of rtems_timer_initiate_server(),
how can you do this?
>   * This makes other two functions listed within SCF section 4.10 as not
>     directly usable, namely rtems_timer_server_fire_after() and
>     rtems_timer_server_fire_when() as those are to be used in
>     conjunction with rtems_timer_initiate_server().
You can use them, if you provide a custom stack allocator.
>   * In a nutshell, this compromises the overall “Timer Server” feature
>     in the qual-only setup of the QDP.
I just makes it a bit inconvenient to use. One option would be to
provide a new directive to construct the timer server, for example
rtems_timer_server_construct().
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
