[rtems-source-builder commit] sb/setbuilder: Correctly create build set tar files
Christian MAUDERER
christian.mauderer at embedded-brains.de
Wed Sep 28 13:42:04 UTC 2022
Hello,
with this patch, I don't get a tar for devel/qemu and for the
6/rtems-microblaze anymore. All other 6/rtems-* toolchains work without
problems. I haven't tested a lot of the other packages.
The bset for microblaze is a bit different from the other ones. But I'm
not yet sure what the relevant difference is.
@Chris: With your change: What is necessary that a bset can generate a
tar archive?
Best regards
Christian
Am 19.09.22 um 23:24 schrieb Chris Johns:
> Module: rtems-source-builder
> Branch: 5
> Commit: 828feec622c3ebfdf96a50f5789fcace93717f82
> Changeset: http://git.rtems.org/rtems-source-builder/commit/?id=828feec622c3ebfdf96a50f5789fcace93717f82
> Author: Chris Johns <chrisj at rtems.org>
> Date: Thu Sep 1 16:20:44 2022 +1000
> - Make a single tarfile for all buildsets built
> - Use the staging tree as the tarfile source
> - Use python's tarfile module
> - Create a config.file object without loading a .cfg file
> Updates #4716
> source-builder/sb/config.py | 5 ++--
> source-builder/sb/setbuilder.py | 58 +++++++++++++++++++++++++----------------
> 2 files changed, 39 insertions(+), 24 deletions(-)
> diff --git a/source-builder/sb/config.py b/source-builder/sb/config.py
> index 9250896..24590eb 100644
> --- a/source-builder/sb/config.py
> +++ b/source-builder/sb/config.py
> @@ -258,7 +258,7 @@ class file:
> re.compile('%select'),
> re.compile('%disable') ]
> - def __init__(self, name, opts, macros = None):
> + def __init__(self, name, opts, macros = None, load = True):
> log.trace('config: %s: initialising' % (name))
> self.opts = opts
> self.init_name = name
> @@ -267,7 +267,8 @@ class file:
> self.sf = re.compile(r'%\([^\)]+\)')
> self.set_macros(macros)
> self._reset(name)
> - self.load(name)
> + if load:
> + self.load(name)
> def __str__(self):
> diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> index 55bd86f..36fca46 100644
> --- a/source-builder/sb/setbuilder.py
> +++ b/source-builder/sb/setbuilder.py
> @@ -30,11 +30,14 @@ import glob
> import operator
> import os
> import sys
> +import tarfile
> import textwrap
> try:
> import build
> import check
> + import config
> import error
> import log
> import mailer
> @@ -259,21 +262,31 @@ class buildset:
> self.root_copy(_build.config.expand('%{buildroot}'),
> _build.config.expand('%{_tmproot}'))
> - def bset_tar(self, _build):
> - tardir = _build.config.expand('%{_tardir}')
> - if (self.opts.get_arg('--bset-tar-file') or self.opts.canadian_cross()) \
> - and not _build.macros.get('%{_disable_packaging}'):
> + def bset_tar(self, stagingroot):
> + if self.opts.get_arg('--bset-tar-file') or self.opts.canadian_cross():
> + # Use a config to expand the macros because it supports all
> + # expansions, ie %{_cwd}
> + cfg = config.file(self.bset, self.opts, self.macros, load=False)
> + prefix = cfg.expand('%{_prefix}')
> + tardir = cfg.expand('%{_tardir}')
> path.mkdir(tardir)
> - tar = path.join(tardir,
> - _build.config.expand('%s.tar.bz2' % \
> - (_build.main_package().name())))
> - log.notice('tarball: %s' % (os.path.relpath(path.host(tar))))
> + tarname = path.join(tardir,
> + path.basename('%s.tar.bz2' % (self.bset)))
> + log.notice('tarfile: %s' % (os.path.relpath(path.host(tarname))))
> if not self.opts.dry_run():
> - tmproot = _build.config.expand('%{_tmproot}')
> - cmd = _build.config.expand('"cd ' + tmproot + \
> - ' && %{__tar} -cf - . | %{__bzip2} > ' + \
> - tar + '"')
> - _build.run(cmd, shell_opts = '-c', cwd = tmproot)
> + tar = None
> + try:
> + tar = tarfile.open(tarname, 'w:bz2')
> + for filedir in sorted(path.listdir(stagingroot)):
> + src = path.join(stagingroot, filedir)
> + dst = path.join(prefix, filedir)
> + log.trace('tar: %s -> %s' % (src, dst))
> + tar.add(src, dst)
> + except OSError as oe:
> + raise error.general('tarfile: %s: %s' % (self.bset, oe))
> + finally:
> + if tar is not None:
> + tar.close()
> def parse(self, bset):
> @@ -500,8 +513,6 @@ class buildset:
> copy.copy(self.macros),
> format = 'xml',
> mail = mail)
> - if s == len(configs) - 1 and not have_errors:
> - self.bset_tar(b)
> else:
> deps += b.config.includes()
> builds += [b]
> @@ -540,7 +551,7 @@ class buildset:
> log.trace('_bset: %2d: %s: builds: %s' % \
> (nesting_count, self.install_mode(),
> ', '.join([b.name() for b in builds])))
> - if deps is None and not self.opts.no_install() and not have_errors:
> + if deps is None and not have_errors:
> for b in builds:
> log.trace('_bset: : %s: %r' % (self.install_mode(),
> b.installable()))
> @@ -550,7 +561,6 @@ class buildset:
> if self.staging():
> prefix = b.config.expand('%{stagingroot}')
> self.install(self.install_mode(), b.name(), buildroot, prefix)
> # Sizes ...
> @@ -604,16 +614,20 @@ class buildset:
> del b
> - # If builds have been staged install into the finaly prefix.
> + # If builds have been staged install into the final prefix.
> - if have_staging and not self.opts.no_install() and not have_errors:
> + if have_staging and not have_errors:
> stagingroot = macro_expand(self.macros, '%{stagingroot}')
> have_stagingroot = path.exists(stagingroot)
> - log.trace('_bset: %2d: install staging, present: %s' % \
> - (nesting_count, have_stagingroot))
> + do_install = not self.opts.no_install()
> + if do_install:
> + log.trace('_bset: %2d: install staging, present: %s' % \
> + (nesting_count, have_stagingroot))
> if have_stagingroot:
> prefix = macro_expand(self.macros, '%{_prefix}')
> - self.install(self.install_mode(), self.bset, stagingroot, prefix)
> + if do_install:
> + self.install(self.install_mode(), self.bset, stagingroot, prefix)
> + self.bset_tar(stagingroot)
> staging_size = path.get_size(stagingroot)
> if not self.opts.no_clean() or self.opts.always_clean():
> log.notice('clean staging: %s' % (self.bset))
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
