[rtems-source-builder commit] sb/setbuilder: Correctly create build set tar files
Wed Sep 28 23:40:01 UTC 2022
On 28/9/2022 11:42 pm, Christian MAUDERER wrote:
> Hello,
> with this patch, I don't get a tar for devel/qemu and for the 6/rtems-microblaze
> anymore. All other 6/rtems-* toolchains work without problems. I haven't tested
> a lot of the other packages.
> The bset for microblaze is a bit different from the other ones. But I'm not yet
> sure what the relevant difference is.
> @Chris: With your change: What is necessary that a bset can generate a tar archive?
It could be a bug if the tools builds work, ie 6/rtems-*. Please raise a ticket?
I changed the --bset-tar-file option to create a single tarfile of the final
staged output of a build. There were a few commits to get this right so I assume
you are testing on the latest?
Incremental tarfiles based on separate buildsets in a buildset may have worked
in some cases however there were some basic issues in how it was implemented.
When you add deployment requirements on top it did not match up well and it was
confusing. The best solution was to rebase the tarfile against the final staged
output as that is known to be correct in all cases.
I have created a https://git.rtems.org/chrisj/rtems-deployment.git repo and in
it a config test directory
(https://git.rtems.org/chrisj/rtems-deployment.git/tree/config/test). I will
look at adding a test to make sure we catch any issues.
Thanks
