[rtems-source-builder commit] sb/setbuilder: Correctly create build set tar files
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Sep 29 06:42:31 UTC 2022
Hello Chris,
thanks for the response.
Am 29.09.22 um 01:40 schrieb Chris Johns:
> On 28/9/2022 11:42 pm, Christian MAUDERER wrote:
>> Hello,
>> with this patch, I don't get a tar for devel/qemu and for the 6/rtems-microblaze
>> anymore. All other 6/rtems-* toolchains work without problems. I haven't tested
>> a lot of the other packages.
>> The bset for microblaze is a bit different from the other ones. But I'm not yet
>> sure what the relevant difference is.
>> @Chris: With your change: What is necessary that a bset can generate a tar archive?
> It could be a bug if the tools builds work, ie 6/rtems-*. Please raise a ticket?
The tool builds work except for the 6/rtems-microblaze.
> I changed the --bset-tar-file option to create a single tarfile of the final
> staged output of a build. There were a few commits to get this right so I assume
> you are testing on the latest?
I used the current master during the tests. I reverted only the single
"Correctly create build set tar files" commit to check whether it was
the relevant one. Without this single commit but all others still in
place the qemu tar file is created.
> Incremental tarfiles based on separate buildsets in a buildset may have worked
> in some cases however there were some basic issues in how it was implemented.
> When you add deployment requirements on top it did not match up well and it was
> confusing. The best solution was to rebase the tarfile against the final staged
> output as that is known to be correct in all cases.
I'm not sure whether I understand that, but that is because I never
analyzed how the source builder generates the tar files. I'll try to
read a bit more documentation and sources.
Best regards
Christian
> I have created a https://git.rtems.org/chrisj/rtems-deployment.git repo and in
> it a config test directory
> (https://git.rtems.org/chrisj/rtems-deployment.git/tree/config/test). I will
> look at adding a test to make sure we catch any issues.
> Thanks
> Chris
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
