[rtems-source-builder commit] sb/setbuilder: Correctly create build set tar files
Christian MAUDERER christian.mauderer at embedded-brains.de
Thu Sep 29 08:01:28 UTC 2022
Am 29.09.22 um 09:52 schrieb Chris Johns:
> On 29/9/22 5:13 pm, Christian MAUDERER wrote:
>> Am 29.09.22 um 08:56 schrieb Chris Johns:
>>> On 29/9/2022 4:55 pm, Christian MAUDERER wrote:
>>>> Am 29.09.22 um 08:54 schrieb Chris Johns:
>>>>> On 29/9/2022 4:42 pm, Christian MAUDERER wrote:
>>>>>>> It could be a bug if the tools builds work, ie 6/rtems-*. Please raise a
>>>>>>> ticket?
>>>>>> The tool builds work except for the 6/rtems-microblaze.
>>>>> Thanks, I will take a look.
>>>> I just checked it: There is the same behavior for devel/dtc (which is much
>>>> faster to build). Without the patch an archive is created. With the patch it
>>>> doesn't create one.
>>> Awesome, that will help.
>> In case of dtc, it seems to not work because dtc is in
>>    devel/dtc-1.6.1-1.cfg
>> which ends in a ".cfg" and not in a ".bset".
>> The bset_tar(...) function is only called if the have_staging is set here:
>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/setbuilder.py?id=161b7f108c3daa0f71ac289ba048a68b730d422c#n623
>> That variable seems to be only set to True here:
>> https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/setbuilder.py?id=161b7f108c3daa0f71ac289ba048a68b730d422c#n489
>> And that statement is in a
>>    if configs[s].endswith('.bset')
>> Does that mean that only bsets can be packed?
> It means the build is not being staged and so no bset tar generation. At a guess
> a single package in a build does not need to be staged so that step is missed.
> Just a bug. If you could please raise a ticket and assign to me I will take care
> of this.
https://devel.rtems.org/ticket/4730#ticket
Is there anything I can help with solving that?
Best regards
Christian
> Nice work getting it down to here. I appreciate it. >
>> I think having a tarball for tools like qemu or dtc could be quite useful too.
> Agreed.
>> PS: Not sure yet why microblaze is affected too. That maybe is another case.
> Thanks. Getting to it with rtems-deployment repo but I hit 5 verses devel branch
> issues.
> Chris
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
