[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
chrisj at rtems.org
chrisj at rtems.org
Thu Sep 29 08:52:38 UTC 2022
Closes #4730
source-builder/sb/setbuilder.py | 22 ++++++----------------
1 file changed, 6 insertions(+), 16 deletions(-)
diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
index 3e16111..5921eed 100644
--- a/source-builder/sb/setbuilder.py
+++ b/source-builder/sb/setbuilder.py
@@ -433,19 +433,11 @@ class buildset:
interrupted = False
- # If this is the outter most buildset it's files are installed. Nested
- # build sets staged their installed file. The staged files are install
- # when the outtter most build finishes.
+ # If installing switch to staging. Not sure if this is still
+ # needed.
- if nesting_count != 1:
- if self.installing():
- self.macros['install_mode'] = 'staging'
- # Only the outter build set can have staging to install. Get the staging
- # root via the config because it could require a valid config.
- have_staging = False
+ if self.installing():
+ self.macros['install_mode'] = 'staging'
try:
configs = self.load()
@@ -453,7 +445,7 @@ class buildset:
log.trace('_bset: %2d: %s: configs: %s' % (nesting_count,
self.bset, ', '.join(configs)))
- if nesting_count == 1 and len(configs) > 1:
+ if nesting_count == 1:
# Prepend staging areas, bin directory to the
# path. Lets the later package depend on the earlier
@@ -485,8 +477,6 @@ class buildset:
'=' * (74 - len(configs[s]))))
bs = buildset(configs[s], self.configs, opts, macros)
bs.build(deps, nesting_count, mail)
- have_staging = True
del bs
elif configs[s].endswith('.cfg'):
if mail:
@@ -620,7 +610,7 @@ class buildset:
# If builds have been staged install into the final prefix.
- if have_staging and not have_errors:
+ if not have_errors:
stagingroot = macro_expand(self.macros, '%{stagingroot}')
have_stagingroot = path.exists(stagingroot)
do_install = not self.opts.no_install()
2.37.1
