[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
Christian MAUDERER
christian.mauderer at embedded-brains.de
Thu Sep 29 11:45:51 UTC 2022
Hello Chris,
thanks for the quick patch. With this qemu and microblaze work again
like expected.
I tested all tools starting with devel/* and from the ones that work
only devel/autotools-internal didn't generate a tar archive. But that
one has a comment "Do not use via the command line" in the bset file so
that is most likely fine.
Some of other devel/* packages didn't build in my test setup, but I have
never tested or used them before so that is probably a problem of my
build environment or maybe a known bug.
Best regards
Christian
Am 29.09.22 um 10:52 schrieb chrisj at rtems.org:
> From: Chris Johns <chrisj at rtems.org>
> Closes #4730
> source-builder/sb/setbuilder.py | 22 ++++++----------------
> 1 file changed, 6 insertions(+), 16 deletions(-)
> diff --git a/source-builder/sb/setbuilder.py b/source-builder/sb/setbuilder.py
> index 3e16111..5921eed 100644
> --- a/source-builder/sb/setbuilder.py
> +++ b/source-builder/sb/setbuilder.py
> @@ -433,19 +433,11 @@ class buildset:
> interrupted = False
> - # If this is the outter most buildset it's files are installed. Nested
> - # build sets staged their installed file. The staged files are install
> - # when the outtter most build finishes.
> + # If installing switch to staging. Not sure if this is still
> + # needed.
> - if nesting_count != 1:
> - if self.installing():
> - self.macros['install_mode'] = 'staging'
> - # Only the outter build set can have staging to install. Get the staging
> - # root via the config because it could require a valid config.
> - have_staging = False
> + if self.installing():
> + self.macros['install_mode'] = 'staging'
> try:
> configs = self.load()
> @@ -453,7 +445,7 @@ class buildset:
> log.trace('_bset: %2d: %s: configs: %s' % (nesting_count,
> self.bset, ', '.join(configs)))
> - if nesting_count == 1 and len(configs) > 1:
> + if nesting_count == 1:
> # Prepend staging areas, bin directory to the
> # path. Lets the later package depend on the earlier
> @@ -485,8 +477,6 @@ class buildset:
> '=' * (74 - len(configs[s]))))
> bs = buildset(configs[s], self.configs, opts, macros)
> bs.build(deps, nesting_count, mail)
> - have_staging = True
> del bs
> elif configs[s].endswith('.cfg'):
> if mail:
> @@ -620,7 +610,7 @@ class buildset:
> # If builds have been staged install into the final prefix.
> - if have_staging and not have_errors:
> + if not have_errors:
> stagingroot = macro_expand(self.macros, '%{stagingroot}')
> have_stagingroot = path.exists(stagingroot)
> do_install = not self.opts.no_install()
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
