[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
Chris Johns
chrisj at rtems.org
Fri Sep 30 05:37:03 UTC 2022
On 30/9/2022 3:33 pm, Christian MAUDERER wrote:
> Am 30.09.22 um 05:49 schrieb Chris Johns:
>> On 29/9/2022 9:50 pm, Chris Johns wrote:
>>> On 29/9/22 9:45 pm, Christian MAUDERER wrote:
>>>> Hello Chris,
>>>> thanks for the quick patch. With this qemu and microblaze work again like
>>>> expected.
>>>> I tested all tools starting with devel/* and from the ones that work only
>>>> devel/autotools-internal didn't generate a tar archive. But that one has a
>>>> comment "Do not use via the command line" in the bset file so that is most
>>>> likely fine.
>>>> Some of other devel/* packages didn't build in my test setup, but I have never
>>>> tested or used them before so that is probably a problem of my build
>>>> environment
>>>> or maybe a known bug.
>>> Thanks for the testing. I will push to the devel branch and 5.
>> Tarfile creation is working however installing is not. I am working on fixing
>> this.
>> Chris
> Sorry that I missed that. I only tried to generate the tar archives.
Same. Testing a fix but it takes time to check properly.
I am wondering if I can create a test mode in the deployment repo. The hard part
is how to automatically check the build has worked.
