[PATCH] sb/set-builder: Fix staging and tar file generation with a single config build
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Sep 30 05:33:55 UTC 2022
Am 30.09.22 um 05:49 schrieb Chris Johns:
> On 29/9/2022 9:50 pm, Chris Johns wrote:
>> On 29/9/22 9:45 pm, Christian MAUDERER wrote:
>>> Hello Chris,
>>> thanks for the quick patch. With this qemu and microblaze work again like expected.
>>> I tested all tools starting with devel/* and from the ones that work only
>>> devel/autotools-internal didn't generate a tar archive. But that one has a
>>> comment "Do not use via the command line" in the bset file so that is most
>>> likely fine.
>>> Some of other devel/* packages didn't build in my test setup, but I have never
>>> tested or used them before so that is probably a problem of my build environment
>>> or maybe a known bug.
>> Thanks for the testing. I will push to the devel branch and 5.
> Tarfile creation is working however installing is not. I am working on fixing this.
> Chris
Sorry that I missed that. I only tried to generate the tar archives.
Best regards
Christian
embedded brains GmbH
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRB 157899
